Old Jan 31, 2008, 04:10 PM
RocketRob is offline
Find More Posts by RocketRob
Size Matters!
RocketRob's Avatar
San Francisco Bay Area
Joined Dec 2002
Lancer CG?
I have finishedmy 72" span Lancer from Bob Holman plans and have it set up for rc.
Does anyone have any suggestions for initial CG?
Thanks Rob
RocketRob is offline Find More Posts by RocketRob
Old Jan 31, 2008, 08:02 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Poke the numbers into this CG calculator. Start with the static margin set to 10% and then do it again for 3 or 4% and that would be your preffered CG range.
http://www.geistware.com/rcmodeling/cg_super_calc.htm
BMatthews is offline Find More Posts by BMatthews
Old Jan 31, 2008, 10:20 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
CG for Lancer
Thanks Rob
I agree with 10%. I've used Plane Geometry for Lancer CGs. It says 5.5 inches from the L.E. at the wing root for a lancer 72. I'm pretty sure we used this numer on a Mates model and it worked great.
Can we see some photos?
I'm a real fan of these models. Look and fly great.
Enjoy
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Feb 01, 2008, 06:45 AM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
Thanks guys!
I'll get some photos, but we have had such rain for the month of January - I havn't been able to get her outside.
Currently it balances at the forward spar which is around 3" from leading edge.
It is powered by an inverted webra .28 diesel swinging a 10x6 prop
Old Feb 01, 2008, 10:41 AM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
Lancer 72
Some Lancers
California Condor is offline Find More Posts by California Condor
Old Feb 02, 2008, 02:38 AM
kasra is offline
Find More Posts by kasra
Palo Alto, CA, USA
Joined Nov 2000
Beautiful Lancers Eut
Here is the one I got from Eut a couple of years ago. It has an MPX brushless motor. It is one of my prized possessions that I only fly on calm sunny days.
kasra is offline Find More Posts by kasra
Latest blog entry: Car Show
Old Feb 02, 2008, 06:20 AM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
Hey Kasra,
That plane gets prettier every time I see it!
Kasra's Lancer was the inspiration for my Littlest Lancer which became the inspiration for my 72" Lancer.
Where is your CG relative to Main Wing Cord?
Old Feb 02, 2008, 12:33 PM
Old Timer
Joined Apr 2001
Hey Kasra, did you recover the left stabilizer?
Old Feb 02, 2008, 08:28 PM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
3''aft leading edge works out to 33% MAC front wing - just a bit in front of the main spar
Flew very well
Plenty of power from the .28 Webra Diesel
10x6 apc 11,600 static
the calc program lists 4.04 lbs thrust and 65mph pitch speed
Old Feb 02, 2008, 08:52 PM
Old Timer
Joined Apr 2001
Good looking Lancers. Rocket
Old Feb 02, 2008, 10:07 PM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
Thanks Man!
Old Feb 03, 2008, 05:12 AM
kasra is offline
Palo Alto, CA, USA
Joined Nov 2000
Hi Rob, Nice looking Lancers. I like that hot red color I measured my CG at 3.75 inches tonight from the leading edge at the fuselage. The plane flies nose heavy and I will move the CG to 4" next. I don't know about 5.5 inches. That sounds a little too far.
Eut, I have not touched the airframe. Could you measure the CG on one of your Lancers please?
Kasra
Old Feb 03, 2008, 03:45 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Rearward CG
Kasra
I'm pretty confident on the number at 5.5 inches. I've Used Plane Geometry a lot and have never come unstuck. Lancer has a generous tailplane and moment which lets the CG go back. The problem with forward CG is it makes for a one speed model. As soon as the pace goes on the nose comes up. It is too stable. I like to work the CG back to where the model only just pulls out of the dive when left alone. This way it si more sensitive to thermals too. 5.5 inches will still give positve recovery though as 10% margin is still nicely positive and is a good general seating before you start tuning.
Try working back to this and you will be rewarded with a more responsive and flaoty model when in lift. You may want to reduce elevator through as the sensitivity improves.
Allan
PS I would like to hear the veiws of a Master like Eut too!
Old Feb 05, 2008, 08:12 AM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
Kasra - Allan,
I think you guys both might be right.
I believe Allan is referring to the 72" span while Kasra is flying the 48-50" span?
Either way I have a rather large aft cg to explore!
Old Feb 17, 2008, 10:08 PM
Size Matters!
RocketRob's Avatar
Joined Dec 2002
Some Aerials
4.04 lbs thrust in a 3lb, 1oz airframe and 65 mph pitch speed - Diesel
Not your grandaddys Lancer
Discussion Lancer CG? RocketRob Vintage & Old-Timer Designs 5 Jan 30, 2008 12:18 AM
