Old Jan 31, 2008, 01:32 PM
David MPS is offline
Find More Posts by David MPS
Quebec, Canada
How to install prop on EZ*
Hi !
I checked in the manual and in the "foamie Kit" section in this forum and I didn't find it
How to install a APC 6x4 on brushless motor ?
Is it possible to screw it on shaft ?
Does exist an adpator ?
I don't bought anything at this time, because I want buy all in the same time to save in time and money(shipping)
And is it possible to hold the motor without glue it ?
thank you !
David MPS is offline Find More Posts by David MPS
Old Jan 31, 2008, 01:41 PM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
First off you need to use glue to hold the motor, use Shoe Goop Glue type of stuff that can be removed later. Depending on the motor you choose you will need an adaptor that fits on the shaft of motor, and the apc prop gets secured to that adaptor.
Here is what I bought that works for me all products are at LightFlightRC.com
ARC-28-37-4 Motor - $49.99 28mm motor 1800Kv fits right into EZstar
SP 30 Amp ESC - $16.95
3.2mm Prop Adaptor - $3.50
igorp is offline Find More Posts by igorp
Old Jan 31, 2008, 01:52 PM
Quebec, Canada
Is it that ?
http://www.lightflightrc.com/HTML/products/Wobbly32.htm
Old Jan 31, 2008, 06:41 PM
Finder is offline
Find More Posts by Finder
Zoom!
Bay Area, San Francisco
Joined Aug 2006
If you're using a brushless inrunner motor, chances are it'll have a 3.2mm shaft. You'll want an adapter similar to this:
http://www3.towerhobbies.com/cgi-bin...?&I=LXMSG3&P=0
If you have a conservative setup, I find 3M double sided tape works just fine holding the motor in place. On a 400+ watt setup, you'll want to secure that motor in good! Personally, I just wrap the motor in masking tape and CA that sucker in good.
Cheers!
Finder is offline Find More Posts by Finder
Old Jan 31, 2008, 06:47 PM
Quebec, Canada
Thank you Finder !!!! That what I want !
If you think double side tape is enough I will try it.
Like I said, I don't have the plane in my hand, the fuselage is it splitted by the middle ?
Old Jan 31, 2008, 08:22 PM
Finder is offline
Zoom!
Joined Aug 2006
If you do plan on using tape, make sure it's the thin industrial strength stuff. Yes, the fuselage comes split down the middle.
Cheers!
Old Feb 01, 2008, 12:42 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
That is exactly what I am using... don't forget to reverse the prop... it's a pusher now not a puller
JMSTECH is offline Find More Posts by JMSTECH
Old Feb 01, 2008, 08:10 AM
Quebec, Canada
and if I want fly backward ?
Thanks guy !
I calculate all stuff , and i'm little bit over 1000$.........
and I'm owner of little hobbyshop
Old Feb 01, 2008, 12:44 PM
Finder is offline
Zoom!
Joined Aug 2006
Doing things the right way the first time comes out cheaper in the long run, even if it takes longer to research, save up, build, etc... If I knew what I know now, I'd be $1000+ richer. eg. Why I started with an Optic6 radio, I'll never know. Don't get me wrong, I love it as a non-fpv transmitter, but my goal was full pan/tilt FPV in the first place. Stupidity at it's best... that's me!
Good luck with the build!
Old Feb 01, 2008, 01:16 PM
Quebec, Canada
You're right finder, starting with the best , you save money in long run....
And VRFlyer live close to me, and I can contact him anytime. He have a very big knowledge about FPV, I'm glad to know him
Old Feb 01, 2008, 11:28 PM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Hey if you can fly your bird back ward... I will yield to you and call you THE GREAT ONE!!!
Old Feb 02, 2008, 09:33 PM
Quebec, Canada
How to install gearbox on Wattage SC400 Dezynco Power Systems 3 Feb 22, 2004 06:08 PM
How to install HS85 on Voyager? dom Electric Heli Talk 2 Jun 26, 2003 01:50 PM
How to keep prop on, but still remove it? KnifeEdge51 Power Systems 2 May 27, 2003 09:37 PM
how to install heatsink on ICS 300? L.I.A. Parkflyers 3 May 03, 2003 09:24 PM
Noob question: How to install a prop BoleyWv Parkflyers 22 Apr 15, 2003 06:30 PM
