Old Jan 30, 2008, 08:56 PM
niner555 is offline
Find More Posts by niner555
niner555's Avatar
Memphis, TN
Joined Jul 2006
Build Log
GWS A-4 kit bash..... IAF A-4H single seat conversion!
This is my first build log, so go easy on me
When I saw GWS's A-4 prototype a long time ago, I knew I had to have it when they finally started shipping. Of course I am never happy with anything in it's stock form, so my ultimate GWS A-4 foamy EDF would be no exception. Here is the basic outline of what I will be trying to accomplish and the hardware I will use to make it fly much faster than GWS ever intended this chunk of foam to go !
The airframe:
* I have always admired the Israeli Air Force and for years they flew the A-4H extensively. I did some research and found some really great pics...so I chose to modify the GWS A-4 into a single seat A-4H model with a paint scheme from 1967, around the time of the Six-Day War.
* I will be setting this jet up to be as light as practical....as I will be hand-launching it.
* Since the inlet ducting is WAY oversized for the Minifan I will be using, the inlets will be cut-down to not only reduce drag, but make the jet more scale in appearence....more on that later. I will be also be making full fiberglass inlet ducting for maximum EDF efficiency.
* For strength and ding resistance I will be glassing the whole airframe with a single layer of .56 oz. glass.
* Paint will be custom mixed acrylic....cheap and simple to apply with a brush.
The powerplant:
* My tried and true Wemotec minifan with an ARC 28-47-2 motor running on a 7S, 2100mah lipo set-up. This gives me right at 880 watts, 50 oz. static thrust, and 8 minutes of mixed flying. My outlet is set-up for 80% of FSA. This is a great power package....I recommend it to anyone!
* Suppo 70 amp ESC.....it's way cheap, but has performed flawlessly to date.
Matt
niner555 is offline Find More Posts by niner555
Old Jan 30, 2008, 09:20 PM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
OK, first things first....
Before I build anything, I like to know where I am starting from. I measured all the important dimensions and came to the following conclusions:
* To get the single seat conversion looking right, I will have to extend the inlets forward about 1 1/2 in. and the canopy will obviously have to be trimmed and sculpted back into the airframe.
* I made a template to measure the inlet cross sectional area. After tracing it on some graphing paper, it's easy enough to count squares and get a good estimate of the area.
The area came to 3.13 in.sq. per side for a total of 6.26 in. of area. Since a minifan is right at 4.52 in. sq., that makes the stock inlets 138% of FSA !!!!! WAY too big and draggy....it will be fixed!
* The wing measures out to be only 8% thick....not too bad...should be fairly efficient for high-speed flight.
Matt
Old Jan 30, 2008, 09:29 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
dang, i knew the fsa was bigger, but not that big!! guess ill be sizing them down to scale
corsair nut is offline Find More Posts by corsair nut
Old Jan 30, 2008, 11:37 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
C/N you forgot to sell him one of your A-4 single seat canopies
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 30, 2008, 11:48 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
signing on...7 cells?...i like it!...
gunracer is offline Find More Posts by gunracer
Old Feb 01, 2008, 12:03 AM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
very nice...i'll have to give your single seater mod a try...
Old Feb 01, 2008, 12:14 AM
jridge is offline
Find More Posts by jridge
Pine, Colorado
Joined Oct 2003
Nice. And you've already got a single seat canopy pulled or did you buy one from Corsair Nut?
jridge is offline Find More Posts by jridge
Old Feb 01, 2008, 01:12 AM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
it looks like the stocker cut back...
Old Feb 01, 2008, 06:08 AM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
Thanks, it is just the stock canopy trimmed down. I had to angle/trim the rear of the canopy down about 1/8 in. to get the rear hump to blend in right. I just eyeballed it till the transition looked smooth.
Matt
Old Feb 02, 2008, 02:52 PM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
After looking at some additional photos of the A-4H, I think I may have over estimated the amount the intakes needed to be moved forward. It appears that the lack of an intake splitter plate is what makes it appear that the stock GWS intakes are too far back.
Well, since I needed to reduce the inlet size of the intakes to better match my Minifan's FSA anyway, I decided to install scale sized splitter plates and at the same time size them to get a final air inlet area of 100% FSA.
They are not difficult to make, but are very tedious and time consuming. I think they are worth the effort, IMHO they really add a nice scale look and are very functional as well.
Matt
Old Feb 02, 2008, 03:23 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Nice!
So are you going to move the cockpit back now?
skyhawk is offline Find More Posts by skyhawk
Old Feb 02, 2008, 04:30 PM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
Originally Posted by skyhawk
Nice!
I think I will leave it as-is. Here is a photo of a square-tail A-4H that has a canopy that appears to be moved farther forward than the color illustration I have at the beginning of this thread.
Since the photographed A-4 looks more like the way my GWS A-4 is without anymore modifications, I think I will follow the photo Makes my life easier this way than having to move the canopy back .....
It isn't 100% scale, but it's close enough to make me happy.
Matt
Old Feb 02, 2008, 05:52 PM
Cap232ac is offline
Find More Posts by Cap232ac
there is no spoon...
Cap232ac's Avatar
Pueblo, Colorado
Joined Jul 2005
'picked up some Depron today for the duct work. I like your intakes. It's enough to inspire me to do the same.
Aaron
Cap232ac is offline Find More Posts by Cap232ac
Old Feb 02, 2008, 10:50 PM
niner555 is offline
niner555's Avatar
Memphis, TN
Joined Jul 2006
Cool...It's nice that GWS has done most of the hard work for us with this airframe. We can spend our time on the detail/scale stuff and make something unique.
Good luck on your project.
Matt
Aaron
Discussion CMP 140-size P-40E conversion/kit bash. Lynxman Electric Warbirds 690 May 08, 2016 10:44 AM
Discussion Spitfire - GWS kit bash J.E. Johnson Electric Warbirds 66 Sep 30, 2006 02:52 PM
Build Log Terry Slope conversion kit-bash Endless Sloper Slope 5 May 17, 2006 11:57 PM
F/S single and Dual conversion Xtals HItec/GWS NoM'rcrashPlease Aircraft - General - Radio Equipment (FS/W) 1 Aug 07, 2004 10:28 PM
WTT: AERC F-4 Kit for a GWS A-10 Kit ggatti Aircraft - Electric - Airplanes (FS/W) 0 Jul 07, 2003 09:48 PM
