Old Jan 30, 2008, 05:38 PM
bub9797 is offline
Find More Posts by bub9797
bub9797's Avatar
Archbald, PA
Joined Mar 2006
Help needed with Dumas 1930 Chris Craft
Hi all:
If any of you have built the Dumas 1930 24' CC Runabout maybe you can help. I'm stuck at the part where you put the substrate planking on the bow deck. The instructions seem to want you to run the planks all the way to the edge of the sheer, but the in the picture it looks like the planking should butt evenly with the sheer on the same level. I called Dumas and the fellow said he thought the planks should go out to the edges of the boat but this doesn't seem right. Any input would be greatly appreciated.
Signed,
Confused
bub9797 is offline Find More Posts by bub9797
Old Feb 11, 2008, 03:29 PM
Bud Faulkner is offline
Find More Posts by Bud Faulkner
Bud Faulkner's Avatar
Mt Airy Maryland
Joined Aug 2004
I think the sub planking should stop at the inside edge of the sheer and when the mahogany sheer piece is added it butts up to the sub planking and the mahogany deck and white plastic strips are added with one between the mahogany sheer and deck planking.
Bud
Bud Faulkner is offline Find More Posts by Bud Faulkner
Old Feb 13, 2008, 06:39 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
bub,
If ya look at sheet 2 of your blueprints, the cross section at the bow shows what bud is saying, the foredeck ply butts up to the sheer. That ply surface wants to be the same height so when the mahogany goes on, you have a smooth surface to cover. You may have to fair the frames in that area in order get it to work.
woodybob is offline Find More Posts by woodybob
Old Feb 13, 2008, 08:07 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Here's the picture from the Dumas website:
The sub deck goes all the way out to the edge of the sheer; except where the side coaming starts, the the sub deck planking goes to the edge of the coaming.
CG Bob is offline Find More Posts by CG Bob
Old Feb 14, 2008, 11:06 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Like this...
Old Apr 13, 2010, 04:14 PM
saywhen1948 is offline
Find More Posts by saywhen1948
Lake Tahoe
Joined Apr 2010
I'm building the same model and have glued the planking even with the sheers but now I'm stuck on the hatches. I'm not sure when to glue the C-2 and the C-3's to the jigs or when to cut them as shown in figure 24. I'm hoping you might have some advice or photos that would help.
Mark
PS Any idea how to attach photos...I'm asked to use a http/ URL and I'm not sure how to do that.
saywhen1948 is offline Find More Posts by saywhen1948
Old Apr 13, 2010, 05:47 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
See if this will help...
How to UPLOAD IMAGES
http://www.rcgroups.com/forums/showthread.php?t=610209
http://www.rcgroups.com/forums/showthread.php?t=545544
Old Apr 13, 2010, 09:43 PM
Lake Tahoe
Joined Apr 2010
Image upload test (1930 Chris Craft Dumas)
Thanks for the help on loading photos. This is my first model given to me by my father. I was a little blown away when I opened the box for the first time and took a look at all those little pieces of wood...thought Dad was giving me a little payback for all the tools I forgot to put back when I was a kid. Now if I can only figure out what I'm suppose to do with the hatches I'll be a happy camper. I'm thinking the jigs are just to get the bend in H1 and H2 and that's all I need them for. I'm also a little confused about the 5 minute epoxy...I know it's different than the CyA but is it Ambroid original liquid cement or something else? The directions also say I should use a razor or band saw and since I don't have either which would be better to purchase? Lastly (for now) will the engine hatch eventually be made into a port and starboard hatches because I remember seeing port and starboard engine hatches on someone else amazing model. Any advise and photos will be appreciated.
Mark
Old Apr 13, 2010, 09:53 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Congrats on passing the photo test. Fo'c'sle looks perfect.
Old Apr 13, 2010, 10:08 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
I split the hatch and used micro piano hinges. If I remember correctly Dumas has you build it as one piece. Basically you need to build a frame for the hatch in the boat then build hatch frames that get covered with mahogany. I think I made the one piece hatch cover then sawed it in half with a very fine saw. Think of it as a door frame in the boat, then build up the hatch frame to follow the deck shape.
Old Apr 14, 2010, 05:53 AM
RussellTate is offline
Find More Posts by RussellTate
RussellTate's Avatar
Sydney Australia
Joined May 2009
Hey Woodybob, can I get you to spill the beans again on your suppliers!
I'd love to put a micro piano hinge (or at least have a try!) on my next boat build the Sterling Century Sea maid
thanks Russell
RussellTate is offline Find More Posts by RussellTate
Old Apr 14, 2010, 09:27 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
M.A.C.K. Products and Dumas have piano hinges.
Old Apr 14, 2010, 12:50 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
MACK and Dumas hings are 3/8 inch wide. I get narrow ones from doll house supply Last ones I got about 2 years ago I purchased 2 sizes 3/16 and 1/4 inch.
I use them on my run-a-bouts and Sea Maids.
GILL RC is offline Find More Posts by GILL RC
Old Apr 14, 2010, 03:40 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
I got these from Oakridge Hobbies 15 years ago, I don't they carry them anymore, not listed on their website anyway. They were tough to find too.
Old Apr 14, 2010, 06:53 PM
Sydney Australia
Joined May 2009
Thanks guys, at least I know what i'm looking for i'll try and source those thinner ones
appreciate the advice (as always)
Help needed with a plan... Please ! NetForce2K Parkflyers 1 Jun 04, 2002 12:59 PM
Help needed with biplane dimensions Rekit Power Systems 2 Apr 11, 2002 11:22 PM
Hornet Help Needed With Ccpm Mixing JUSTGLUEIT Electric Heli Talk 3 Apr 09, 2002 08:55 PM
Quick help needed with HF9, GWS gyro on the Housefly ruf Electric Heli Talk 1 Feb 01, 2002 10:47 PM
Picalo help needed with triming...I think mrtim Electric Heli Talk 1 Sep 08, 2001 02:49 AM
