Old Feb 01, 2008, 02:08 PM
anci3nt is offline
Find More Posts by anci3nt
Free Flying
anci3nt's Avatar
Joined Nov 2006
Oh ok. From your posted RC-cam link, you described a very different setup. Did you get the same 9.8 km results with your "live conditions" setup? If that's the case, I think that's a new range record for FPV RC control using stock RC radio gear, even more so with a 3W 2.4 GHz video TX onboard.
anci3nt is offline Find More Posts by anci3nt
Old Feb 01, 2008, 02:10 PM
cfe7 is offline
Find More Posts by cfe7
Failureisalwaysanoption
cfe7's Avatar
Norway
Joined Nov 2006
Forums must be home of the sceptics. This time itís my own fault.
The story on RC Cam forum is not complete. I didnít follow up the thread after my first posts.
Day 1 I went out with 2 RX in a plastic box. Everything went well, so day 2 I took my Twin Star to the same location. Day 2 was more than 2 weeks after day 1. I couldnít fly earlier because of a lot of military activity (F-16).
This time we got the aircraft in the air and flew for a few minutes. No problems occurred. The Norwegian Army had an exercise going on just 800 meters away from the place I was flying. They had a lot of radios transmitting, but no problems as mentioned earlier.
I just remembered we're way off topic now.
scrtsqrl and Impulze you might need your own personal "Ghost" (homebrew) instead of more wing area on the EasyStar.
Note the special designed video camera platform on top of the vertical fin.
Transparent cover and powerful lights inside the wings and fuselage will make this plane visible in the dark sky. Then it suddenly disappears when the lights go out by the flip of a switch(that's where the name comes from).
cfe7 is offline Find More Posts by cfe7
Old Feb 01, 2008, 04:57 PM
jbourdon is offline
Find More Posts by jbourdon
United Kingdom, England, Derby
Joined May 2007
cfe7, that's a very interesting design. is it hard to build? never created a plane before, but would love to create a custom easystar like that...
would prefer a dome-like camera mount on the "pilot seat" rather than the tail
jbourdon is offline Find More Posts by jbourdon
Old Feb 02, 2008, 02:37 AM
anci3nt is offline
Free Flying
anci3nt's Avatar
Joined Nov 2006
Not really skeptic, just very interested in what you needed to do to get range like that. Many here fly to the link limits and your distance is almost twice the best here (with stock gear)! Since this is a very interesting topic but off topic, perhaps you could share what measures you took to get range like that in the Long Range Personal Record. We would be very grateful for any suggestions!
Old Feb 02, 2008, 03:05 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Concur. Very interesting. Please share.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Feb 02, 2008, 11:57 AM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Anyone know how a "long wing" Easystar or an Easystar w/ EG wings behave in wind?
Old Feb 02, 2008, 01:44 PM
jbourdon is offline
Joined May 2007
scrtsqrl, I don't know yet, but I ordered an EG to cannibalize the wings and maybe the tail kit. will let you know
Old Feb 06, 2008, 04:15 AM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
The Big EasyStar (0 min 26 sec)
Old Feb 06, 2008, 04:31 AM
Ginger Adam is offline
Find More Posts by Ginger Adam
I'm Ginger & called Adam
Ginger Adam's Avatar
Hereford, UK
Joined Oct 2002
There is more drag, so going into the wind is a little more difficult (even more of the 'kiting' behavior than the standard EZ*) but there is less wing rock (polar momentum, I guess?) which makes video smoother.
General flying, I find the downwind turns* a little troublesome (take them wider), and landing in a tight spot can be tough. Hand-catching is usually easier due to the lower flightspeed.
Adam
* no such thing, but you probably know what I mean.
Ginger Adam is offline Find More Posts by Ginger Adam
Old Feb 06, 2008, 01:49 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Adam
If you had to choose, which pair of wings would you use in higher winds, long or short?
Why are downwind turns "troublesome"?
What is "Kiting"?
Thanks for the info. It's all good.
Old Feb 06, 2008, 02:23 PM
Hereford, UK
Joined Oct 2002
I use the bigger wingset whenever I can, simply because the slower I fly the better pictures I take with it.
Downwind turns on a standard EZ* can sometimes drop the inside wing and also rudder response is 'mushy', the bigger wings seem to make the EZ* turn more slowly, so this is amplified.
'Kiting' is when you put power on but instead of going forwards you go up - not always a bad thing. Standard EZ* will often do this into the wind, you simply feed a little 'down' in to offset.
I'll see if I can get some onboard footage of the 78" wing (weather permitting) as I've just set up an EZ* for FPV
Adam
What is "Kiting"?
Old Feb 07, 2008, 12:12 AM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Ok, got it.
One more question:
What CG do you use? Same one?
Thank you.
Old Feb 07, 2008, 02:39 AM
Hereford, UK
Joined Oct 2002
No change - the wingset can be fitted to any EZ* (I have 4) so I often swap them around with no changes to CoG. I tend to run the EZ* tail heavy as this seems to make them fly more responsively and also more slowly - probably a preference thing YMMV
One of my planes (a particularly light one) did need a little weight on the nose when moving up to the 78" otherwise it suffered 'mini-stalls'.
I'll get some pics of the wingset this weekend and post them here - if the weather is good enough I'll do some back2back onboard vid.
Adam
Ok, got it.
One more question:
Thank you.
Old Feb 07, 2008, 10:31 AM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Adam,
Thanks again. That'll be awesome.
I thought it'd be cool to have an aluminum spar...But AFTER I bought one, I asked myself: will this long piece of metal in the plane cause any issues w/ radio control or video? Thoughts, anyone?
Old Feb 07, 2008, 01:24 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Here she is ready to go. Just waiting for good weather. The mod went pretty straight forward per the example here. The key is to ensure that the leading and trailing edges were in correct alignment. To keep a refence, I marked up where they were on both sides of the fuse w/ a permanent marker.
I trimmed one wing down first using a simple box cutter and block sand paper. Once I got it to fit, I lined up the two wings, marked up the other and trimmed away. That went more quickly.
I am using a 1m long aluminum tube for the center spar.
I finally installed a brushless system. I got it from www.LightFlightRC.com. It is an ARC 28-37-3, 30 Amp ESC, & 29mm Aluminum Spinner. I'll be using a 6 X 5.5 APC Prop. I simply cut along the centerline above the motor with an x-acto knife. I also cut around the engine, separating the double sided tape that was securing the stock motor to the airframe. I then worked it loose. I then slipped the new motor in, securing it with two pieces of double sided tape at the 3 & 9 o'clock position, then taped up the cut along the centerline. I used the two wires leading from what was the old ESC in the cockpit to feed the new ESC. I then ran the servo wire down the side of the fueslage and into the Rx located in the bay just below the motor mount, under the wing. I'm using 2300 mAH 2 Cell LiPos from www.microwireless.net. I tested the motor system today with the standard wings and got around 1 hour and 8 minutes of flight time.
Easystar Brushless Motor Mod (2 min 15 sec)
Overall net weight gain is around 3 ozs, for an all up weight of 30 ozs.
I'm able to switch between the wingsets. The orange tail extension is removable as well. Currently, it is secured w/ velcro. I will use magnets when I get them.
How to launch big wing? Arctic@1M Flying Wings 12 Apr 28, 2005 07:05 PM
Slow Stick, Big Wing dylancoffin Parkflyers 3 Oct 26, 2004 01:48 PM
Big wing djindivik Flying Wings 14 Aug 17, 2004 07:37 PM
big wing (combat/speed) for spare axi 2820/10 yorbenator Flying Wings 4 Jul 13, 2004 05:55 PM
Making a big wing strong enough FlyingW Electric Plane Talk 1 Jan 24, 2003 10:02 PM
