Old Jan 29, 2008, 10:25 AM
ajreynolds is offline
Find More Posts by ajreynolds
I need a bigger garage...
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Question
Measuring lipo internal resistance
I was wondering what the proper way is to measure lipo internal resistance. I was thinking of hooking up a taillight bulb as the load on a pack and measuring voltage and current then calculating the resistance. Do I need to then subtract out the resistance of the bulb itself to get the total internal resistance of my pack?
Andy
ajreynolds is offline Find More Posts by ajreynolds
Old Jan 29, 2008, 11:58 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Check here:
http://www.rcgroups.com/forums/showt...ipo+resistance
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jan 29, 2008, 11:59 AM
jfrickmann is online now
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
I think the bulb resistance is a little hard to get as it varies with the temperature of the glow wire. If you measure current and volts under load as well as resting, then you can estimate the inner resistance. But that will tend to overestimate the inner resistance, as there is also some diffusion resistance in the electrolyte which causes a voltage drop as well.
jfrickmann is online now Find More Posts by jfrickmann
Old Jan 29, 2008, 03:53 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
LIPO Z ( impedance) changes differently as a load when charged and as a source when it drains
if U R concerned about hi-resistance interface , check your COLD solder joints by re-doing it or look at those spot welds on the aluminum TABs with the nickel TABs and RE
-TIN them with Harris aluminum soldering flux
hall woo is offline Find More Posts by hall woo
Old Jan 29, 2008, 04:13 PM
ajreynolds's Avatar
USA, CA, San Diego
Joined Mar 2005
Thanks for the responses, everyone. That link that Glen posted is just what I was looking for, as it's the reason I asked. I wanted to figure out IR on some of my packs that the manufacturer doesn't provide specs on, so I can put them in Motocalc.
Andy
Kokam lipo pack internal resistance edthedoc Batteries and Chargers 1 Jan 18, 2005 08:33 AM
lipo voltage drop / internal resistance / lifetime question vladn Batteries and Chargers 5 Jun 08, 2004 11:12 PM
Internal Resistance of LiPo Cells? FlyingW Batteries and Chargers 0 Jul 30, 2003 08:35 AM
Measuring Internal Resistance RC Man Batteries and Chargers 4 Jan 02, 2003 09:02 AM
Measuring internal resistance? JBowling Batteries and Chargers 3 Oct 09, 2002 11:20 AM
