Old Oct 05, 2011, 06:57 AM
alkoo is online now
Find More Posts by alkoo
speedfreek
alkoo's Avatar
Newcastle, Australia
Joined Apr 2003
Going to need to cut those elevons down BJ.
alkoo is online now Find More Posts by alkoo
Old Oct 05, 2011, 07:17 AM
dingo is offline
Find More Posts by dingo
knee ligaments are over rated
dingo's Avatar
Melbourne , Outer East .
Joined Dec 2003
The top looks good . The fibre glass tape doesn`t last long once it gets a bit of sun on it . Drop around 1 night & I`ll show you how to put some step hinges on .
dingo is offline Find More Posts by dingo
Old Oct 05, 2011, 08:01 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Yah.... thought so Wazz.
Crap... have to pull them off and redo, maybe. Still tempted just to hook it all up and at least have a fly with it. Change them if/when needed.
Dingo - I remember you showing me those step hinges when I picked the JD up. Stuffed if I can remember now. Might give you a bell and drop around so you can see for yourself if you think it's worth flying as it is. No speed records to attempt here - just some frontside fun with something that's probably going to penetrate a bit more wind than my present L-plater fleet.
BTW - it's not what I'd call 'fibreglass tape' as such. It's that 90deg cross-hatched Scotch-Tough stuff. Sticks like st to a blanket...
BJ
BJ64 is offline Find More Posts by BJ64
Old Oct 05, 2011, 09:20 AM
batballs is offline
Find More Posts by batballs
Blue Sky Mining
batballs's Avatar
Australia, VIC, Ballarat
Joined Feb 2009
Originally Posted by BJ64 View Post
Here ya go...
(Closeups aren't all that flash)
Bottom hinge was done with the aileron flipped over and sitting on the top of the wing, then a single full-length run of fibre tape.
Top hinge was then just a single full-length run of fibre tape.
In the side-on's, you can see I didn't sand the bottom of the ailerons - so they stick out in a pointed 'V' a bit...
BJ
PS - the pics in that link Spotter - are they what you guys call 'Step Hinges' ?
How to skin a cat method 42: Cut off the front edge of your elevon back to the bottom leading edge - the non hinged bit. I think you'll find the new elevons can now be step hinged to the bottom surface of the wing and give you the right profile without a heap of sanding. The elevons may be a little narrower than design but I think it will be close enough although I'm not familiar with the jw profile.
edit: clearer with a picture - but it does look narrow.
batballs is offline Find More Posts by batballs
Old Oct 05, 2011, 02:10 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
That sounds like a good way nick. Took me a while to work out what you were saying tho!
Nice looking plane BJ!
josh18 is offline Find More Posts by josh18
Old Oct 05, 2011, 03:06 PM
gizzo is offline
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
I was going to mention the Tape v sun issue but Bruce got there first. Its fine to use it(IME) if the glass tape is covered with some coloured Zagi tape, keeps the UV out. If your pulling the elevons off again, another thing thats worthwhile (particularly for us crashers ) is to snip an inch or two off the outboard end of the elevon, and fix the short piece solidly to the wing. Hot glue or goop, then some tape, should do. That'll help save servos and elevons in the inevitable cartwheel landing/arrival.
Nice covering job, BTW.
gizzo is offline Find More Posts by gizzo
Old Oct 05, 2011, 05:44 PM
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
All the responses above are great suggestions, and all of them would work.
A couple of caveats:
If you do decide to cut your elevons, make sure the new forward edge is dead straight. If it isn't, it will bind somewhere.
UV does affect fibre tape, but in practice it takes quite a while before it "browns off" and loses it's stick. I usually have to rebuild long before fibre tape goes off. Little squares of packing tape resolves the issue completely.
Those elevons look quite short in the chord already. Might be worth buying another set of elevons and covering them ready for when you snap the end off those ones.
To delay the inevitable snap off the end of the elevon, just cut them 1/2" short of the wingtip. JW's fly perfectly well with a much shorter elevon.
Use clear sellotape to seal the gap after doing step hinges.
spotterone is offline Find More Posts by spotterone
Old Oct 06, 2011, 04:31 AM
Peteren is offline
Find More Posts by Peteren
Australia, SA, Whyalla
Joined Apr 2011
Sorry to intrude on the building discussion but for what itís worth here is my second attempt at slope soaring.
Vid is just under 4 minutes, cut down from the 30 minutes of flight time.
The clock in the camera is wrong and I have had to call on expert help (the Missus) to get it right for the next time
Slope soar (3 min 39 sec)
Peteren is offline Find More Posts by Peteren
Old Oct 06, 2011, 04:55 AM
batballs is offline
Blue Sky Mining
batballs's Avatar
Joined Feb 2009
Don't be sorry. That's a nice video and nice flying!
Old Oct 06, 2011, 05:16 AM
Ezza is offline
Find More Posts by Ezza
DS= -$ & :-)
Ezza's Avatar
Byron Bay, Australia
Joined Feb 2006
Good flying! Nice to see a new face and slope. Looks really good.
Eric
Ezza is offline Find More Posts by Ezza
Old Oct 06, 2011, 05:35 AM
gizzo is offline
gizzo's Avatar
Adelaide, Australia
Nice one Pete. Is that Mt Laura?
Old Oct 06, 2011, 05:38 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Nice vid
Is that from off the hills by the side of the Iron Knob road there somewhere?
BJ
Old Oct 06, 2011, 06:12 AM
Peteren is offline
Joined Apr 2011
Cheers Guyís, yes itís the longer lower hill on the S/E side of Mt Laura facing the Iron Knob road
Old Oct 06, 2011, 07:36 AM
gizzo is offline
gizzo's Avatar
Adelaide, Australia
Hey Pete have you been out to that hill on the S side of town, about 10k out? Has a quarry at the bottom and you see it on the road to Cowell. Often wondered about it when we'd go to Tumby but never went in there. Maybe I'll come over next time the other half has clinical placement in Whyalla.
Old Oct 07, 2011, 04:30 AM
Peteren is offline
Joined Apr 2011
Yes Gizzo, know the one, it's on the Eight Mile Creek rd.
Only problem is it's on private property and there is nil access to the top.
Would do no harm to request access permission but it would be a hell of a hike to the top
Send me a pm anytime you plan to come over to arrange some flight time
Cool Victorian Slopetrash - Veeedeeeo samotage Slope 16 Jan 09, 2008 04:41 PM
