Old Dec 27, 2002, 07:16 PM
nadt770 is offline
Find More Posts by nadt770
AMA L68621; WA2LLX
United States, NY, Lake Katrine
Joined Apr 2001
AMD F-14 or SU-35 conversion
Anybody convert one of these to e-power yet?
nadt770 is offline Find More Posts by nadt770
Old Dec 28, 2002, 12:18 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
How did you plan on powering them? They are jet models, did you plan on EDF power or prop?
GregG is offline Find More Posts by GregG
Old Dec 28, 2002, 10:43 AM
nadt770 is offline
AMA L68621; WA2LLX
Joined Apr 2001
Greg,
At this point it is just a mental exercise but it would be a simple prop instalation. Tracktor for the F-14, pusher for the SU-35(drooping nose would give it to much down thrust). What do you think?
John
Old Dec 29, 2002, 09:38 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Let's start with a wing span and wing area measurements. It helps to know the airfoil and/or % thickness. The airframe weight or flying weight is also required. How much money would you be willing to spend to get it flying at the level you'd like?
Using one of the 'Calc programs (Ecalc or MotoCalc) and your figures for the above will point you in the right direction.
Old Dec 29, 2002, 11:02 AM
nadt770 is offline
AMA L68621; WA2LLX
Joined Apr 2001
span=40'
area=256
airfoil=MH-22
weight(as slope flier)=32oz RTF
loading(as slope flier)=17.9oz/sq. ft.
Slope fliers slammed this bird big time. I'm not sure if it was 'caus of wing loading or just plain doggy handling qualities. Maybe it's more suited to e-power. Or maybe it's more suited to the trash can? It sure is cool looking though.
John
Old Dec 29, 2002, 10:15 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I just ran it up in Motocalc with a geared Endoplasma and 8-CP1700. It said it would fly but the wing loading was pretty high (30 oz/sq.ft.). I then tried it again with lighter cells and a S480. The watt/lb didn't look too good and the wing loading was still at 26. This is probably not the best model to convert but would probably work if you can get it to the flight speed and then don't mind a pretty fast landing speed. Otherwise it doesn't look too promising as a hand launched plane.
Old Dec 30, 2002, 12:23 AM
nadt770 is offline
AMA L68621; WA2LLX
Joined Apr 2001
Oh well, thanks for the input anyhow.
J.
Discussion F-22 or Su-27 Kits available gghisleri Electric Ducted Fan Jet Talk 24 Aug 15, 2010 08:03 PM
Discussion After A-4...can we get an F-4 or an F-14 or F-15 please? kahloq GWS (Grand Wing Servo) 30 May 02, 2007 12:09 PM
Amd Su-35..... Ado Slope 3 Mar 05, 2003 06:17 PM
Question Anyone flown the AMD Su-35 Superflanker? Ben74 Slope 2 Sep 18, 2002 10:18 AM
Schreiner F-18 or 123% F-14 wanted LotusTRBO Aircraft - Electric - Airplanes (FS/W) 1 Jul 05, 2002 11:08 AM
