This thread is privately moderated by Crazy Eight, who may elect to delete unwanted replies.
Old Jan 27, 2008, 02:34 PM
The "K"minator
Crazy Eight's Avatar
Frostbite Falls,MN
Joined Sep 2006
Typhoon 2,Lightening for indoors
Beginning of Typhoon 2 project to lose weight for indoor flying.
The canopy and the cowl will probably be used as is.
Crazy Eight is offline Find More Posts by Crazy Eight
Old Jan 27, 2008, 02:48 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Rudder and horizontal tail feathers after lightening,before covering.
Old Jan 27, 2008, 05:00 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Looks like I'm going to use 6mm depron for the tail feathers and ailerons.
I used Black Baron covering because it's low temp for foam,but too heavy.
http://www3.towerhobbies.com/cgi-bin...?&I=LXB209&P=7
Old Jan 28, 2008, 01:17 AM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
After hollowing it out a bit,and removing all the plastic pieces,the fuselage is now 76.9gm
Old Jan 28, 2008, 01:22 AM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Stock ailerons,16.1gm each
6mm depron ailerons 8.5gm each
Old Jan 28, 2008, 03:07 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Picture of 6mm depron aileron.
Old Jan 29, 2008, 12:13 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Canopy/hatch is a little heavy 14.1gm,I'll make one from 3mm depron.
Old Jan 29, 2008, 12:16 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
The stock cowl will be used.10.5gm
Old Jan 29, 2008, 07:09 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
I did a little more hollowing on the fuselage,it's now 68.2gm,it originally was 108.8gm
Old Jan 29, 2008, 10:11 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
motors
Old Jan 30, 2008, 09:49 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
6mm depron horizontal stab and elevator 12.3gm
Old Jan 30, 2008, 10:11 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
13.5gm with decals
Old Jan 30, 2008, 11:47 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
A little more hollowing on the fuse.
Old Jan 30, 2008, 11:52 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Decal placement reference
Old Jan 31, 2008, 09:24 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Fuselage with decals and rudder 73.5gm
Discussion Typhoon / Oscar 2 class for as cheap as pos under $2000 Jonjoe Submarines 10 Feb 06, 2008 01:53 AM
Question Best glue for Typhoon 2 styro? kenmalecki Parkflyers 17 Jan 11, 2008 10:01 AM
For Sale FS: Parkzone Typhoon 2 RTF OR Trade for a gyro... fiveoboy01 Aircraft - Electric - Airplanes (FS/W) 5 Sep 17, 2007 02:41 PM
Sold TYPHOON 15 and 2 Mounts for it harvey Aircraft - Electric - Airplanes (FS/W) 13 Jun 16, 2005 08:54 PM
370mAH - NiMH (2/3AAA) for sale jerzy Aircraft - Electric - Airplanes (FS/W) 0 Sep 21, 2001 05:28 PM
