Old Dec 06, 2012, 10:05 AM
Joined Jan 2011
If i remember right a lot of guys used the blue wonder on 3s for 3d ships,so im fairly certain youd be fine.most sites will give the specs of motors.
stingeragents is offline Find More Posts by stingeragents
Old Dec 06, 2012, 12:36 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
XDm,
The Blue Wonder should work OK, but it will not fly that lively. The tried and true 2212-6 or D2826 2200kv motors on 3S with a 6X4E prop really is the way to go on these birds. They give right at 24 ounces of thrust and performance is awesome!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Dec 06, 2012, 02:53 PM
Joined Apr 2012
Originally Posted by crxmanpat View Post
XDm,
Pat
Thanks Pat. I'm going to continue my efforts to talk him into getting a bigger motor and leaving the BW on the bench for another day. I'm also trying to talk him into Tom's F-22 instead of the F-18, but he's retired Navy, so that may be a bigger challenge than the new motor...
XDmToter is offline Find More Posts by XDmToter
Old Dec 06, 2012, 04:31 PM
Joined Apr 2012
I ran across this Cargo Twin at parkjets.com, and it got me thinking.... I need a Fat Albert to go along with my Blue Angels TomHe F-18...
Anyone know of a C-130 plan? My quick search didn't reveal much.
The Cargo-Twin is pretty close, so I could probably just mod this plan...
Old Dec 28, 2012, 08:29 AM
Joined Sep 2012
F-18E Super Hornet Diamondbacks
Hello everyone.
My name is Rafał. I'am from Poland.
I changed in the CAD plans from www.parkjets.com and built my first military model F-18E Super Hornet.
Equipment:
- Motor Turnigy D2826-6 2200kv Outrunner Motor - 1 pc
- Propeller APC 6x4 - 1 pc
- Servo Turnigy TG92 - 2 pcs
- 35-40A regulator with heatsink Hobby King - 1 pc
- Battery. Li-Po 1500 mAh Turnigy 25-30C - 1 pc
F 18E Super Hornet FLY presentation (3 min 35 sec)
RAFALR30 is offline Find More Posts by RAFALR30
Old Dec 28, 2012, 10:20 AM
This is BAT country!
M.Gonyea's Avatar
United States, MI, Ovid
Joined Nov 2003
Gorgeous!
M.Gonyea is offline Find More Posts by M.Gonyea
Old Jan 01, 2013, 11:41 PM
United States, CA, Long Beach
Joined Sep 2011
nice jet!
articulatekevin is offline Find More Posts by articulatekevin
Old Feb 09, 2013, 09:48 AM
Joined Oct 2012
I read on athread to spay the hinge tape with adheasivebefore aplying, or the tape won"t stick to the foam.
jimkayos is offline Find More Posts by jimkayos
Old Feb 09, 2013, 09:52 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I use 3M Blenderm. No need to spray any adhesive as it sticks very well. I even sell it on my site:
http://www.nicohobbies.com/store/ind...roducts_id=235
Pat
Old Feb 09, 2013, 10:05 AM
Joined Oct 2012
I think he was going cheap with reguler packing tape,which would not stick to foam.
Old Feb 09, 2013, 11:09 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I've used packing tape in the past, and it does stick to foam initially, but comes loose after a while. After I switched to Blenderm I never looked back.
Pat
Old Feb 09, 2013, 12:17 PM
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
I've used blenderm as well and it does stick quite well on foam too. Recently I came across a method that some guys have been using for a while with Beacon Foam Tac glue. Some use it as a bonding agent under the blenderm (you need to let it dry a bit and then apply the tape over it) some use only the Foam tac and make a flexible hinge. Here's a video a guy made on YouTube. I have since tried it and it works just like the video shows. It's actually quite amazing and it's water proof therefore great for seaplanes.
When you try to pull it apart it breaks the foam not the glue. The only problem is that it seems difficult for some folks to get outside of the USA.
Beacon Foam Tac Glue (Hinge Video) (5 min 22 sec)
AirmanAirhead is offline Find More Posts by AirmanAirhead
Old May 14, 2013, 07:36 PM
Joined Aug 2012
Need help!!!!!
HELLO IM IN THE PROCESS OF BUILDING THIS.. BUT THE TOP AND BOTTOM FUSE PEACES. WILL NOT ALIGN RIGHT.. THE TABS TO THE SLOTS.. could someone tell me..if you have to curve the nose of the plane to get them to fit.. or whats the secret.. SCRATCHING MY HEAD.... PLEASE HELP!!!
phamtomflyer is offline Find More Posts by phamtomflyer
Old May 15, 2013, 06:00 PM
KEEP CALM AND FLY ON
ESG2010's Avatar
United States, VA, Virginia Beach
Joined Nov 2012
Phantom,
I've built two of these F-18's, If you followed the "cut" and "tab" lines, should fit nice and snug, there is a slight "curve" sloping down the nose but nothing that would make it seem out of sorts, without pictures it's difficult to trouble shoot what you have done.
Best Regards,
ESG2010
ESG2010 is offline Find More Posts by ESG2010
Old May 15, 2013, 06:35 PM
ESG2010's Avatar
Joined Nov 2012
FA-18 and F22
Pics of f-18 and F-22
F-18 Super Hornet ParkJet RCParkflyer Pusher Prop Jet Models 19 Jun 02, 2007 11:34 PM
Sold F-18 Super Hornet papamac Aircraft - Electric - Airplanes (FS/W) 8 Feb 09, 2006 04:39 AM
6mmFlyRC's EDF 135% F-18E Super Hornet CBflyguy Electric Ducted Fan Jet Talk 8 Sep 13, 2005 09:37 AM
EAM F-18 Super Hornet- I'm scared!!! ttnissan Electric Ducted Fan Jet Talk 5 Jun 16, 2003 04:00 PM
EJF - press releases, ejets.tv, F-18 ARF, F-18 Super Hornet for 90 mm EDF Robert Wagoner Electric Ducted Fan Jet Talk 4 Jun 24, 2002 12:11 PM
