Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Plane Talk
Old Jan 24, 2008, 11:15 PM   #1
Prop me up
cloud-9's Avatar
Carbon Fiber fuselage for Slow Stick?
Has anybody done this? What CF do you use? Any instructions anywhere?
Thanks a lot.
Jim
cloud-9 is offline Find More Posts by cloud-9   Reply With Quote
Old Jan 24, 2008, 11:30 PM   #2
Does fiberglass count?
Sir Raleigh is offline Find More Posts by Sir Raleigh   Reply With Quote
Old Jan 25, 2008, 04:49 AM   #3
Prop me up
cloud-9's Avatar
Do you mean the stock fuse that comes in the kit? That's fiberglass. I was looking for something more rigid without adding weight.
Jim
Old Jan 25, 2008, 08:26 AM   #4
Who says' EPP dont break?
hot glue's Avatar
Send a message via AIM to hot glue
I wouldnt do it. The old fuse you would have to but the new one is great. My friend uses it and he crashes all the time and its fine. And my uncle has a park 480 on his stock.
hot glue is offline Find More Posts by hot glue   Reply With Quote
Old Jan 25, 2008, 12:00 PM   #5
Prop me up
cloud-9's Avatar
Originally Posted by hot glue
I would do it. The old fuse you would have but the new one is great. My friend uses it and he crashes all the time and its fine. And my uncle has a park 480 on his stock.
Hi, sorry, didn't quite understand. You mean you would need a stiffer fuse if you had the old aluminum boom but the fiberglass one is OK?
A 480? Wow, I thought I was overpowering with a Scorpion 2215-22.
Jim
Old Jan 25, 2008, 12:16 PM   #6
There is square CF tubing out there...if memory serves Big help. How about a CF arrow shaft? They're cheap, available at Wally, and could be modified for the SS mounts. One guy had cut sections of an aluminum SS fuse and slipped the CF tube inside and glued it in place. Seemed to work fine adapting the round tubing to the square holes.
roidspop is offline Find More Posts by roidspop   Reply With Quote
Old Jan 25, 2008, 12:27 PM   #7
Trying to defy gravity...
jimsky's Avatar
My Combat Slow Stick has a CF arrow shaft inside the aluminum fuse...works great. It's saved the fuse from crashes that would would have destroyed the stock fuse.
Jimsky
jimsky is offline Find More Posts by jimsky   Reply With Quote
Old Jan 25, 2008, 12:39 PM   #8
See? Thanks Jimsky! I had an arrowshaft fuse on a plane I built, and I actually managed to break it in a crash, right in front of the forward wing pylon. Stuck a dowel in it, epoxied it back together and wrapped the break area with nylon roving and CA.
Old Jan 25, 2008, 01:49 PM   #9
Even with my fiberglass fuse I put a square hardwood stick all the way through it. The stick only added 1 oz additional weight.
Old Jan 25, 2008, 03:46 PM   #10
Dr Kiwi's Avatar
My original aluminum fuselages have 4mm carbon fiber tubes, encased in balsa sandwiches, within them.
Dr Kiwi is offline Find More Posts by Dr Kiwi   Reply With Quote
Old Jan 25, 2008, 04:42 PM   #11
hot glue's Avatar
Jim
Yea, The CF is strong and so is the aluminum but it would bend when you crashed it. Do you have the CF fuse or the aluminum?
Old Jan 26, 2008, 03:08 AM   #12
Prop me up
cloud-9's Avatar
Jimsky
Any chance anyone knows where to get an aluminum one? Actualy I think I can find square CF, that should be fine.
Jim
Old Jan 26, 2008, 07:01 AM   #13
I believe the old syle aluminum fuselages for the SS have gone the way of valuable antiques. Those that are still around are kept out of harms way and only brought out for trusted friends to see but not touch.
I bought up several of the one piece type when they were being phased out and still have three in a box hid in my office. These are being horded and saved for some yet unknown future exotic SS project.
Bob
Bayward is offline Find More Posts by Bayward   Reply With Quote
Old Jan 26, 2008, 08:24 AM   #14
Prop me up
cloud-9's Avatar
Bob
When aluminum is more valuable than gold
We love our hobby....
Jim
Old Jan 26, 2008, 01:29 PM   #15
Our LHS has aluminum fuselages for $10.00 if anyone's interested. I don't know how many, maybe 4 or 5. I saw them hanging on a rack behind the counter.
Question Makeing a fuselage for the Slow Stick Mchone, Jake GWS (Grand Wing Servo) 18 Feb 10, 2008 01:07 PM
Help! carbon fiber fuselage for Speed Stick (previously Slow Stick) 1130cagle GWS (Grand Wing Servo) 2 Mar 14, 2007 08:14 PM
Discussion Carbon Fiber fuselage boom for Slow Stick CrashingDutchman GWS (Grand Wing Servo) 31 Oct 30, 2006 03:04 PM
Carbon Fiber reinforced wing for slow stick RidgeTop Parkflyers 0 May 29, 2004 05:13 PM
Carbon Fiber reinforced wing for slow stick RidgeTop Aerial Photography 0 May 27, 2004 09:56 PM
Congratulations SimpleM!
