Old Jun 06, 2001, 08:12 PM
futurvet is offline
Find More Posts by futurvet
Ames, Iowa 50010
Joined Jun 2001
Upgraded Zagi 400X.....now I need some help.
I upgraded my Zagi to the Promax 4014 motor, Jeti 250 speed control and Master Airscrew 5.5 x 4 prop. Problem is.....it gets HOT, HOT, HOT!!!! Now the motor seems to be sticking after running and the prop must be turned by hand before it will start again. Do the brushes need to be cleaned? Any suggestions would be appreciated. Thanks in advance.
Todd
futurvet is offline Find More Posts by futurvet
Old Jun 06, 2001, 09:19 PM
A4tune8One is offline
Find More Posts by A4tune8One
Joined Mar 2001
My 4014 runs a little warm with a 1700mah battery. You are running way to small of a prop. The cobalt 400 turns about the same rpm as a speed 400 but can turn a much bigger prop. Step up to a 6 or 7 inch prop, pull a few more amps, oil your motor occasionally and hold on.
A4tune8One is offline Find More Posts by A4tune8One
Discussion I need some help. I just bought new batteries now I need motor help? STREETRIDAZ Electric Power Cars 3 Apr 16, 2007 08:13 AM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
A-10 glitching issue...need some help!!! David Hogue Electric Ducted Fan Jet Talk 5 Aug 07, 2001 09:51 PM
Sky Scooter first flight but need some help Dauntae Foamies (Kits) 2 Jun 14, 2001 08:59 PM
need some help finishing my mini ifo. Jeremy_D Parkflyers 4 May 28, 2001 05:49 PM
