Old Jan 24, 2008, 05:47 PM
theBOZman is offline
Find More Posts by theBOZman
__Jackass Savant__
theBOZman's Avatar
United States, CA, Oxnard
Joined Feb 2005
Help!
Blue foam in Ventura county, CA *found*.
Anybody know of a source for foam in the Ventura county area? every place I'm finding is down in LA or further.
Thanks in advance,
Boz
theBOZman is offline Find More Posts by theBOZman
Old Jan 24, 2008, 06:01 PM
Crashaholic is offline
Find More Posts by Crashaholic
trying to kick the habit
United States, CA
Joined Mar 2006
Yo Boz, if you find some, hook me up too!
Crashaholic is offline Find More Posts by Crashaholic
Old Jan 24, 2008, 06:38 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
We might need to employ Target as our mule.
Old Jan 24, 2008, 07:14 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
There's an Allied Building Supply branch in Ventura. See if they'll get the Anaheim branch to throw some Deckmate+ or Hiload 60 on a truck next time they're bringing other stuff to Ventura. That's how I get mine in Long Beach.
Nauga,
who is a little closer
nauga is offline Find More Posts by nauga
Old Jan 24, 2008, 07:25 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
I assume the highload60 is the preferred foam?
It looks like deckmate plus is around 25psi. It looked rather porous. Does it need alot of filler/prep? What do they cut like???
Thanks Nauga.
Old Jan 24, 2008, 07:30 PM
United States, CA
Joined Mar 2006
If you can get them to truck it, have them throw a few sheets on for me
Old Jan 24, 2008, 07:32 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
I'll let you know.
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
Most of my comments pertain to cutting wings. Deckmate+ is 25 psi. I have Hiload 60 and DM+ but only use Hiload if someone asks for something special. DM+ is more than adequate for slope wings with reasonable thickness and either wood sheeting or glass or both, and is a lot easier to cut (less heat, faster cuts). I'm not sure what you have in mind as far as porosity...it needs to be covered or filled. I also use DM+ (or even 15 psi Deckmate) for shaping mold plugs - glass over foam to make it smooth and shiny. HTH.
Nauga,
with another fuse plug in the works (2 this month!)
Old Jan 24, 2008, 07:35 PM
__Jackass Savant__
theBOZman's Avatar
Joined Feb 2005
I am just transitioning into the glass thing so I was going to start of doing "lost foam" on the fuse. The image I saw online ---> looked more like oasis or swiss cheese than foam.
For wings I will probably need to get a vac setup going but I was going to try to rough it for the first few. I thought some foam has different kerf rates on high ratio wings, so I dint know if the 25psi cut crappy...
Thanks again.
Old Jan 24, 2008, 07:51 PM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
The cheaper the better then! Deckmate (with or without the +) is perfect for lost foam - carve/sand it to shape, then cover it with Zagi tape to seal. The tape smooths the foam AND keeps the acetone you'll use to lose the foam from softening the glass.
Nauga,
and his lost brain squadron
Old Jan 24, 2008, 07:56 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Deckmate is also a HELL of alot cheaper than Hi60. 2'x8'x2" DM is $9.65. The same size for Hi60 is $27.20. Yes, DM is fine for most applications at 25 PSI; compared to EPS which I believe is around 2PSI.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Jan 24, 2008, 10:21 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
I was able to find a 4' x 8' sheet of blue foam (the crappy kind that moves around when you shape it) for relatively cheap from Santa Barbara Insulation on Calle Cesar Chavez here in S.B. Probably fine for lost-foaming stuff
Steve
surfimp is offline Find More Posts by surfimp
Old Jan 24, 2008, 10:27 PM
Chief High Horse is offline
Find More Posts by Chief High Horse
Chief High Horse's Avatar
Orange County, CA
Boz,
go with deckmate.
http://www.alliedbuilding.com/about/...egid=&em=&zip=
The Ventura location is listed on that page.
The DM or DM+ are much easier to learn on, and work with.
For bagging supplies
http://www.joewoodworker.com/
Remember with vacuum sometimes less is more.
Chief High Horse is offline Find More Posts by Chief High Horse
Old Jan 25, 2008, 09:00 AM
markktm is offline
Find More Posts by markktm
only easy day was yesterday
markktm's Avatar
USA, CA, Livermore
Joined Apr 2006
I find your price down there interesting, Allied wants $25 for a 2X2X8 sheet of 25PSI in San Leandro.
I found it for $13 at a local lumber yard.
Mark
markktm is offline Find More Posts by markktm
Old Jan 25, 2008, 09:17 AM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Which lumber yard, Mark?
slopemeno is offline Find More Posts by slopemeno
Blue or Pink foam in Australia ? _AL_ The Builders Workshop 5 Nov 29, 2012 09:48 PM
Where to Get Blue or Pink Foam in SoCal? screamin' eagle Slope 2 Feb 19, 2005 10:09 PM
Question Blue or Pink foam in Houston Radian Composites Fabrication 1 Oct 14, 2004 05:29 PM
blue/pink foam supplier in UK andy_rutter Foamies (Kits) 5 Sep 15, 2004 08:48 AM
Any Action in Ventura County, CA? twentysomething Electric Plane Talk 4 Dec 05, 2001 10:01 PM
