Espritmodel.com Heli Air
Old Aug 13, 2008, 05:39 AM
ambinobambino's Avatar
Cottesloe, Western Australia
Joined Jul 2008
do you buy a "pusher prop" specifically or just a regular prop
ambinobambino is offline Find More Posts by ambinobambino
Old Aug 13, 2008, 06:10 AM
Joined Jul 2008
battery?
speed controller?
Old Aug 13, 2008, 07:03 AM
Joined Jul 2008
i think ill get a dx6 that comes with an AR6200 for $179
Old Aug 14, 2008, 03:53 AM
Globemaster Maiden Time
KoziFlyer's Avatar
Melbourne
Joined Jun 2007
Finish your plane first then include the electronics, u can always cut the foam out to add servos later. Once I finish mine i will show you all my setup specifications.
KoziFlyer is offline Find More Posts by KoziFlyer
Old Aug 14, 2008, 12:34 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Servos are cheap and you can fill the plane with servos before buying a radio.
Hobbycity in HK has great $4 servos. you can get cheap contol horns, clevises, Y-harnesses and servo extensions from them, too.
It's good to have at least one servo handy, so you can properly engineer the mounting and actuation of the servo and control surfaces and run things like control rods to the correct location.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Aug 15, 2008, 03:41 AM
KoziFlyer's Avatar
Melbourne
Joined Jun 2007
True UNGN is right. Pick up some cheap servos for measuring placement.
Old Aug 18, 2008, 04:42 AM
Joined Jul 2008
im not really sure what u mean
Old Aug 18, 2008, 07:54 AM
Joined Jul 2008
what template did u use for the wing sheeting because the curved wing ribs would demand more surface area than the print-out template provides (if that makes sense)
Old Aug 19, 2008, 06:58 AM
Joined Jul 2008
where r u buying ur power 25?
infact where are u buying everything. Im buying everything now because i dont like the idea of cutting it up. too complicated
what is the mah needed of 3s battery??????
and do u need a battery for the motor and a battery for the receiver? or just one?
(pic) how would both sides of the elevator move if only one is attached to the servo?
Old Aug 26, 2008, 06:03 AM
Joined Jul 2008
beginning to sheet
i am using aquadhere (water soluble and dries clear)
i cut the 3 mm depron in 6mm widths (much more effective than you'd think)
it looks better than what it looks like in picture
i will fill cracks with glue and sand, looks great
Old Aug 26, 2008, 10:07 AM
Joined Jul 2008
scale hump
i will also modify the f4 rib/frame for more scale, the previous f4 is quite incorrect and has no proper hump. i designed it myself so use at your own risk (if you want to) ok now i have made the front thinner, i dont care if it effects anything like aerodynamics or balance, it looked so not scale, now its so much better.
i think you all should consider this before you sheet. Here are the pics
Old Aug 30, 2008, 09:43 AM
Joined Jul 2008
looks sooooo 747-400ish!
i guarantee that it looks 1000 times better in real life.
so, what i did was remove f2 and made my cockpit go from f4b to f3 and. the sticking out cockpit bit overlaps the sheeting between f1 and f3. bottom is normal. my radio and receiver just arrived (spektrum dx6 and ar6200), everything else will be a month.
thanks so much brett!
Old Sep 01, 2008, 12:31 AM
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Hello,
I build a little "Pusher B747 years ago and I maid the front section from rosired foam. Alot easier and smoother that planking I think
http://static.rcgroups.com/forums/at...60-P_03_SM.JPG
Rudi
Rudi is offline Find More Posts by Rudi
Old Sep 01, 2008, 05:21 AM
Joined Jul 2008
wow looks good
but as i said, im an absolute noob
btw i just bought all the electronics ($650) lol
not too bad and i also just got this awesome wireless video camera off ebay for $26 incl. shipping!!. lol i just found out it has sound. it has absolutely crystal clear video, a must buy for rc people!
Old Sep 01, 2008, 12:46 PM
Christchurch, New Zealand
Joined Jun 2006
Be very, very careful about range checking with that camera on board! If I'm not mistaken, it's a 2.4Ghz transmitter... that's very likely to give you interference problems. Turn the camera on first, then your RC transmitter, that will give the DX6i a chance to get a free channel. Mount the camera antenna as far from the receiver as you can get it, and range check very carefully.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Discussion Plug in removable wings for depron park jets ram3500-rcu Pusher Prop Jet Models 22 Feb 12, 2006 07:23 PM
Question Searching plan for depron impeller jet / Or building Steves f18 with an impeller??? German_wing Foamies (Kits) 1 Jan 24, 2005 08:34 AM
Question Plan for depron jet trainer RicoJ Electric Ducted Fan Jet Talk 5 Nov 03, 2004 02:09 AM
Missing wing ribs in Corsair plan... Please help. NetForce2K Parkflyers 1 May 09, 2003 09:12 PM
Need a plan converted from dwg to dxf dirtdiver Electric Plane Talk 1 Feb 27, 2003 09:12 PM
