Old Apr 02, 2012, 07:26 AM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
Thank you for the plans. Here is how my model is coming up. So far the weight is 400 grams without electronics.
mrexcel is offline Find More Posts by mrexcel
Old Aug 23, 2012, 09:13 AM
Aviator001 is offline
Find More Posts by Aviator001
United Kingdom, Scunthorpe
Joined Dec 2011
Thinking about building this, i have a bit of xp in scratch building. i am looking for a bit of a challenge. is this good???
thxs
Aviator001
Aviator001 is offline Find More Posts by Aviator001
Old Oct 10, 2012, 12:08 PM
bps is online now
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I need one of these to haul up my Space Shuttle Challenger 1/42 scale. This just about fits the bill, just needs a bit of tweeking. 4 380's with 5" props and taller gear should do the trick. Maybe I will even build molds and just form it. Plans in hand and I am ready! Currently I release the shuttle from a Sig Senior Kadet, just does not seem right to use this combo though!
bps is online now Find More Posts by bps
Old Oct 10, 2012, 07:30 PM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Where is the cg on this plane, I do not see it noted on the plans? Help!
Old Oct 12, 2012, 06:06 AM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
Found it by reading through the posts 180mm from the trailing edge of the wing center section.
I have started cutting the plywood fuse crutch, tracing the fuse formers and wing ribs. Have also decided to go with a non scale undercarriage using 3 1/8" wire nose gear with 2" light foam wheels. Our field is grass and I might stand a chance of taking off from it with this set up. The nose gear units will provide more shock absorbing action. Should have this bird ready by early spring.
Old Mar 24, 2013, 11:27 AM
mikitaly is offline
Find More Posts by mikitaly
mikitaly's Avatar
Italy, Lombardy, VA
Joined Jan 2013
Good, congratulations! hello Michele
mikitaly is offline Find More Posts by mikitaly
Old May 18, 2013, 08:30 PM
Salman Khattak is offline
Find More Posts by Salman Khattak
United States, MD, Salisbury
Joined Mar 2013
I am building one of these with dollar tree foam board at 50% I am going to put a pusher prop on the back
Salman Khattak is offline Find More Posts by Salman Khattak
Old Aug 09, 2013, 03:55 PM
DominykasLT is offline
Find More Posts by DominykasLT
DominykasLT's Avatar
Joined Aug 2013
Hello guys. My name is Dominykas, i am from Lithuania and i am making this airplane and i have 2 questions :
1. How to install front wheel & servo.
2.Can i use 2x 64mm EDF's like that http://www.hobbyking.com/hobbyking/s...v_45A_ESC.html
Thanks.
DominykasLT is offline Find More Posts by DominykasLT
Old Aug 10, 2013, 05:27 AM
Joined Aug 2013
Questions about B747
Hello, my name is Dominykas, i am from Lithuania.
I am making this cool Boeing 747 and i've got 3 questions:
1. How to install front steering wheel with servo?
2.How to connect 2 elevators to 1 servo?
3. Can i use 2x 64mm EDFs like http://www.hobbyking.com/hobbyking/s...v_45A_ESC.html
Dominykas
Old Aug 12, 2013, 06:37 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You can Y the Pushrod to go from 1 servo to 2 elevators or run 2 sleeved pushrods from one larger servo.
This is how many small jets run their elevator servo.
UNGN is offline Find More Posts by UNGN
Old Jun 29, 2014, 10:42 AM
Jimmy__B is offline
Find More Posts by Jimmy__B
JimmyB
Jimmy__B's Avatar
United Kingdom, England, Farnham
Joined Apr 2013
Here's my build....
Dr mad thrust 50mm EDF's x 2
Jimmy__B is offline Find More Posts by Jimmy__B
Old Aug 12, 2014, 03:43 AM
Plummet Airlines is offline
Find More Posts by Plummet Airlines
Don't forget to scream
Joined Sep 2012
My Build
Hi guys and gals,
i've been following this thread for a few months now wanting to start my own build. I've had some 70mm fans laying around for a while now. they came with hobbyking models and weren't quite powerful enough as a single, but i think will perform well in this quad setup.
I'm just starting out to become a L/AME, so the livery will be whoever employs me (or the QANTAS "City of Longreach" 747-400 if i get picked up by a company not operating the jumbo)
a few notable changes i'll be making
-150% size to utilise 70mm fans
-plane will have 4 functional engines and run on 4S (perhaps a switch to select between 2 and 4 engines)
-modified fuselage formers as per earlier posts
-the plane will be made/transported in 4 sections
++++the empenage will be removable
++++the wing sections outboard of engines 2 & 3 will be removable
++++the middle fuselage, nose, and central section of the wing will be a single piece
-i'll be moving/modifying the W2 and W3 formers to coincide with the engine mount pillar to simplify inner wing workings
-slotted fowler flaps (to be determined)
-18 wheel landing gear with gear doors
-4mm marine ply will replace the specified 3mm ply, for extra rigidity
- all spars and wing formers will be ply
one thing i noticed, i dont agree with the wing spar drawn at the bottom of SHEET 2. it travels close to the trailing edge at the wing root. i think it seems to tall, but i could be wrong
Plummet Airlines is offline Find More Posts by Plummet Airlines
Old Sep 04, 2014, 02:04 PM
bps is online now
bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
My 747 flew last night using two 3400kv motors and 5.5" props. This set up blew through (2) 2.2 amp 3s batteries in 3 minutes. One battery for each motor. Flew fine with plenty of speed with this set up. Nice gentle flight characteristics with the CG about 40% of wing cord. Our flying field is grass so ground clearance was the real issue. I am considering switching to EDF units to help with ground clearance. Power system as is is overworked.
Old Sep 05, 2014, 02:55 PM
marcowithag is offline
Find More Posts by marcowithag
Joined Sep 2014
thank you for the plans
I'm really thankful for these plans.
Here a picture of mine at the moment.
marcowithag is offline Find More Posts by marcowithag
Discussion Plug in removable wings for depron park jets ram3500-rcu Pusher Prop Jet Models 22 Feb 12, 2006 07:23 PM
Question Searching plan for depron impeller jet / Or building Steves f18 with an impeller??? German_wing Foamies (Kits) 1 Jan 24, 2005 08:34 AM
Question Plan for depron jet trainer RicoJ Electric Ducted Fan Jet Talk 5 Nov 03, 2004 02:09 AM
Missing wing ribs in Corsair plan... Please help. NetForce2K Parkflyers 1 May 09, 2003 09:12 PM
Need a plan converted from dwg to dxf dirtdiver Electric Plane Talk 1 Feb 27, 2003 09:12 PM
