Old Sep 16, 2009, 08:19 AM
DvMourik is offline
Find More Posts by DvMourik
Joined Aug 2009
Originally Posted by KoziFlyer
I am running 1 servo for each elevator. So 2 servos for the elevator. The rudder control is a bit dodgy but I never use rudder anyways.
Thanks alot... i was thinking of the same ... 2 servo's...
Will fix that first before i start with the maiden.
DvMourik is offline Find More Posts by DvMourik
Site Sponsor
Old Sep 16, 2009, 12:53 PM
brett1984 is offline
Find More Posts by brett1984
RC Airliner Man
brett1984's Avatar
United Kingdom, Dudley
Joined May 2007
a380
Brett here you go, any airbus you like its all there. They even give you scale fuselage ribs!!
http://www.airbus.com/en/services/cu...lity-planning/
MFP A300 01 May 1998
MFP A300-600 01June 1998
MFP A300-F4/-600 01June 1998
MFP A310 01 May 1998
MFP A318 01 Dec 2007
MFP A319 01 Dec 2007
MFP A320 01 Dec 2007
MFP A321 01 Dec 2007
MFP A330 01 Feb 2009
MFP A340-200/-300 01 May 2007
MFP A340-500/-600 01 May 2007
MFP A350
MFP A380
when are you going to start building your a380?
In about 2 weeks, once I have the plans done and material delivered. The Depron and glue alone is going to cost me almost $300AUD
Cheers!!
hi koziflyer, thanks for that will have to import the images in cad and trace them, i'll have ago at making the plan befor i can give you a date when i start building.......
brett1984 is offline Find More Posts by brett1984
Old Sep 16, 2009, 04:04 PM
RC Airliner Man
brett1984's Avatar
Joined May 2007
boeing 737-500 formers almost done
hi everybody, been working on the 737 formers today only took about 45 minutes. i have still got to add a second skin to the formers to allow for the 3mm depron sheeting. that shouldnt take long.
will post pics of the 747 tomorrow as i forgot today.
Old Sep 17, 2009, 01:50 PM
RC Airliner Man
brett1984's Avatar
Joined May 2007
pics of 747
heres some pics of my 747, pics are abit crappy as taken in the dark, well it was going dark. hope you like
Old Sep 17, 2009, 02:38 PM
teha99 is offline
Find More Posts by teha99
Real name's Teja :)
teha99's Avatar
USA, NJ, East Brunswick
Joined May 2008
WOW! How did you get the nose so scale? Also, do you have to use balsa, if yes what type is it? Will the dimensions of the balsa be on the 737 plans?
thanks,
teja
teha99 is offline Find More Posts by teha99
Old Sep 17, 2009, 03:08 PM
RC Airliner Man
brett1984's Avatar
Joined May 2007
thanks
thanks,
teja
hi teja, the plane looks better in person, cant wait to finish, i used balsa in the wings and depron is good for small models as spars but in larger models and where more weight is involded i moved to balsa, for the wings i used what ever i had in my shed, but in the tail and fin, i used some, 1/16th balsa sheet as spars, and in the fin 1/4 by 3/8 balsa strip. light weight and strong.
i will share all info for the 737 with you.
Old Sep 17, 2009, 03:12 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
Thanks for the fast reply Brett.
When I tried to build your 747, I had the nose all messed up, so I gave up and quit.
For future references, what type of power system would be sufficient for the 737, maybe 45 inch WS? I would like to know so I can start saving! I would like to buy from hobbyking as they have the cheapest prices.
Teja
Old Sep 17, 2009, 03:28 PM
RC Airliner Man
brett1984's Avatar
Joined May 2007
Teja
hi teja, if built light you could try using 2 of these55 mm edf and a sutiable speed controller. i use hobby city as well for my rc gear
Old Sep 17, 2009, 03:33 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
So 2 15 amp brushless escs would do? or 2 20 amo, or one 30 amp for both if possible?
Teja
Old Sep 18, 2009, 01:39 AM
DvMourik is offline
Joined Aug 2009
Hey Kozi,
I made my elevator the same as yours today... 2 servo's and yeah that's much better...
I wanted to start on the grassfield today but it really don't have the power to get off the field. The wheels are too small in combination with the trust.
So will try it tonight again on some sort of concrete... let's see if it will take off..
Site Sponsor
Old Sep 18, 2009, 01:40 AM
DvMourik is offline
Joined Aug 2009
Wowwwww that looks great Brett.... you're a great builder...
Let's hope it will fly great too....
Site Sponsor
Old Sep 18, 2009, 03:45 AM
KoziFlyer is offline
Find More Posts by KoziFlyer
Globemaster Maiden Time
KoziFlyer's Avatar
Melbourne
Joined Jun 2007
I'll give you the plans of the A380 once I'm done. I owe you one for the plans you provided for the 747!!
What is your 747's wingspan? Great clean work by the way, should come out real smooth.
KoziFlyer is offline Find More Posts by KoziFlyer
Old Sep 18, 2009, 12:55 PM
RC Airliner Man
brett1984's Avatar
Joined May 2007
a380
hi kozi flyer, thanks that would be great, have you done the plan in cad??? the wing span of mine is 54.5 inches
and thanks for the comment guys... will give you more pics soon, be fore i sheet the rear fuselage got to wire the lights in before i seal it up.....
Old Sep 18, 2009, 09:02 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
How would the cockpit be sheeted with the windows for the 737? That picture posted on the top of the thread named 737 plan, is that final? It looks complete to me, except maybe for the wing ribs?
Teja
Also, maybe the title of this thread should change because we have a 737 on it! And possibly an A380.
Old Sep 20, 2009, 11:38 AM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
Any updates?
Discussion Plug in removable wings for depron park jets ram3500-rcu Pusher Prop Jet Models 22 Feb 12, 2006 07:23 PM
Question Searching plan for depron impeller jet / Or building Steves f18 with an impeller??? German_wing Foamies (Kits) 1 Jan 24, 2005 08:34 AM
Question Plan for depron jet trainer RicoJ Electric Ducted Fan Jet Talk 5 Nov 03, 2004 02:09 AM
Missing wing ribs in Corsair plan... Please help. NetForce2K Parkflyers 1 May 09, 2003 09:12 PM
Need a plan converted from dwg to dxf dirtdiver Electric Plane Talk 1 Feb 27, 2003 09:12 PM
