Old Jan 24, 2008, 08:40 AM
DelUK is offline
Find More Posts by DelUK
Slope convert/addict
DelUK's Avatar
Romford, Essex. UK
Joined Mar 2006
Flaperons vs. Spoilerons for landing
Just trying to canvass opinions from guys with far more experience than I on this subject. What is the preferred option, or does it depend on many factors as I suspect ?
I am fairly new to slope soaring, and so far have only flown aileron gliders with a Y-lead connected to the aileron channel (i.e. no differential or flaperon/spoileron mix). I am building my first scale glider (2.5m ASW-28) and will be using the ailerons as flaperons/spoilerons to assist with landings. Having read through various threads, it seems some people use flaperons to land, although most advocate spoilerons to kill lift and airspeed.
DelUK is offline Find More Posts by DelUK
Old Jan 24, 2008, 08:56 AM
soarluck is offline
Find More Posts by soarluck
soarluck's Avatar
Canada .the great
the problem that i have with flaperons is that they decrease your control or roll/rate and most importly ,,they encorage tip stalls unlike spoilers that kill more lift ,ofter quick decent ,and they dont strip servo gears on landing
soarluck is offline Find More Posts by soarluck
Old Jan 24, 2008, 10:02 AM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Spoilerons would work great on something that doesnt have seperate flaps or spoilers. The key is:
1) Getting enough throw with the spoilerons and still having some throw left for spoilers (use enough output arm) and:
2) Elevator compensation. Maybe someone who is flying the same plane can chime in with their comp throw. To find it, open up your ele comp program and fly the plane. When youre three mistakes high, pop out the spoilerons, and see if the plane pitches up or down, and adjust the compensation. Youre looking for a mushy "sit" on approach. With enough spoileron throw and compensation, you can get a very draggy, steep approach with good roll response.
slopemeno is online now Find More Posts by slopemeno
Old Jan 24, 2008, 10:18 AM
h.eberbach is offline
Find More Posts by h.eberbach
Bremen/Germany
Joined Apr 2004
DelUK,
the rule is simple:
If your plane has ailerons only, then brake action is done by bringing them into an "up position". Otherwise you will definitely encounter serious(!) problems as and how "soarluck" already explained.
If your plane has both ailerons and flaps, you put the ailerons up and the flaps down, also called "butterfly" or "crow".
Yet a warning for both cases: On most planes, bringing the ailerons up reverses the torque in the aileron section of the wing from "nose down" to "nose up". In this configuration, the resulting overall torque of the wing is more "nose up" and has to be compensated by some elevator down trim. The amount of trim change may be between a few % to up to 30%. Recommendation: crank in some considerable down trim and try at altitude.
If properly trimmed, "aileron up" landings are extremely stable and safe around the longitudal axis.
Happy landings
Herbert
h.eberbach is offline Find More Posts by h.eberbach
Old Jan 24, 2008, 06:27 PM
iflytailies is offline
Find More Posts by iflytailies
aka Schleppmeister
PA
Joined Feb 2006
I use up spoilers on all my glider
iflytailies is offline Find More Posts by iflytailies
Old Aug 16, 2008, 01:26 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
nice i found this thread from "google"
just what I needed to read
so ailerons up 45 degrees
elevator down to 15 degrees
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 16, 2008, 11:46 PM
aka Schleppmeister
PA
Joined Feb 2006
you need to "experience" the elevator compensation needed on your plane. Some need more, some less compensation
Old Aug 17, 2008, 01:10 AM
David22 is offline
Joined Apr 2008
i figure i will be way up ther to adjust spoileron and elevator.
but i still am not sure about the steering with spoilerons up
from another thread I have been told to do some more programming ?
in order to use ailerons to steer
Old Aug 17, 2008, 01:13 AM
kwmtrubrit is online now
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
I've only flown with true spoilers, not spoilerons, so I'm not sure how spoilerons affect the nose pitching down compared to spoilers. When spoilers are deployed, the nose pitches down. The elevator could be raised to compensate for this if necessary. Is it the other way round for spoilerons (as shown above), or am I looking at a crash waiting to happen?
Always ready to learn,
Keith
kwmtrubrit is online now Find More Posts by kwmtrubrit
Old Aug 17, 2008, 01:19 AM
David22 is offline
Joined Apr 2008
lol now I am really mixed up
kind of like when you first start the rc hobby wondering if up right aileron turns the plane right.
and then you get a v tail only and the opposite is true
know what i mean
hope you have patience if you do
this should not be this complicated
Old Aug 17, 2008, 01:24 AM
aka Schleppmeister
PA
Joined Feb 2006
yes, with ailerons both up you should still have enough "reserve" so your ailerons are still functional. Some radios will never go over 100% servo travel, even with spoilers deployed (for example the Multiplex Royal Evo). When you apply full spoilers, make sure you still have enough servo travel available with full aileron travel up and down. If your servos jam or your pushrod touches the wing you have to reduce the spoilers throw. Adjust your spoilers so that your ailerons, servos, and pushrods can move freely when fully deflected.
Old Aug 17, 2008, 01:34 AM
David22 is offline
Joined Apr 2008
I like your idea it is simple
so no need for reverse differential
i think there is more than one way to land a plane with just ailerons and no rudder?
soaring usa sent me a dvd and they mentioned what you say
i guess that is why 45 degrees allows for further movement?
i think i should set mine to say 35 40 degrees to give me better stability
but faster landing right
this is crazy
problems with no flaps
Old Aug 17, 2008, 06:10 PM
David22 is offline
Joined Apr 2008
just for anyone else having the same questions
this helps
http://www.rcgroups.com/forums/showthread.php?t=376428
Old Aug 18, 2008, 09:44 AM
CygnusX1 is offline
Find More Posts by CygnusX1
Dave
CygnusX1's Avatar
Putnam Valley, NY
Joined Sep 2007
I have spoilerons setup on both of my sailplanes. Both have only ailerons on the wings. I find that with the spoilerons in use, the roll response to the stick is much slower, however, the sailplane seems to stay fairly flat and requires little input anyhow. Somehow, the spoilerons, make the plane stay more stable as if it had more dihedral. It definitely took some high altitude testing to get the spoileron/elevator mixes correct. The amount of mix was completely different for each plane.
CygnusX1 is offline Find More Posts by CygnusX1
Old Aug 18, 2008, 10:01 AM
David22 is offline
Joined Apr 2008
ok cool I am understanding now thanks
so the recommended landing settings are aileron - 27 mm and elevator +2mm
really means aileron up 27 mm and elevator down 2 mm
right? those are my spoiler settings?
also it says for standard flight
aileron (inner side) + 5mm, -15mm (inner side, what is that, mesurement from close to the fuse)
elevator +5 mm, -5mm
exponential 40%
what does this mean?
and there is one for speed which reads ailerons(inner side) up -1.5 mm and elevator down +1 mm
Flaperons vs. Spoilerons drone Electric Sailplanes 17 Aug 17, 2008 01:44 AM
Poll flaperons or spoilerons best for GWS Corsair? alexeames Electric Warbirds 7 Sep 19, 2006 03:32 PM
Flaperons vs. Spoilerons treelander Beginner Training Area (Aircraft-Electric) 5 Sep 19, 2005 12:45 PM
Flaperons vs. Spoilerons? dklassen 3D Flying 32 Feb 06, 2004 07:29 PM
Flaperons vs. Spoilerons? dklassen Sport Planes 3 Feb 04, 2004 10:24 PM
