Old Jan 24, 2008, 02:01 AM
Cha0sEngine is offline
Find More Posts by Cha0sEngine
PA-Electric Shocks Rocks
Cha0sEngine's Avatar
UK
Joined Sep 2003
Direct Drive Tail (T-rex 450 size heli)
Has anyone tried a direct drive tail on a 450?
i am thinking about trying it and while i can make a motor to do the job, i was wondering if anyone has tried off the shelf motors for this?
I guess one of the considerations is correct size shaft (to fit the tail linkage components onto) and also removable shaft because a stock motor shaft is unlikley to be long enough..
so.. has anyone used off the shelf for a DD tail motor??
Cha0sEngine is offline Find More Posts by Cha0sEngine
Old Jan 24, 2008, 06:05 AM
Super_Hornet is offline
Find More Posts by Super_Hornet
Singapore
Joined Jan 2004
Is there any reason u want a direct drive tail rotor for TRex450 ?
SH
Super_Hornet is offline Find More Posts by Super_Hornet
Old Jan 24, 2008, 06:23 AM
UK
Joined Sep 2003
not particularly.. just wanted to try it.. i only hover and do circuits so there wont be anything funky involved.
Old Jan 24, 2008, 06:51 AM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
someone did a brushless tail conversion wth there t-rex. i remember seeing a thread about it but it hasnt been around for a while. try searching google.
heligrom is offline Find More Posts by heligrom
Old Jan 24, 2008, 07:27 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Why take a step backwards?
Gino CP is offline Find More Posts by Gino CP
Old Jan 24, 2008, 07:47 AM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
Maybe he is thinking of keeping the pitch controll.
The weight of a small brushless may not be to much more than what you could remove. It also leaves some interesting mix options (or as in my case confusion)!
A Monell is offline Find More Posts by A Monell
Old Jan 24, 2008, 09:30 AM
UK
Joined Sep 2003
ahh.. yeah i obviously wasnt too clear..
yes i intend to have servo controlled pitch with the existing mechanism.
its just that the drive for the tail will be DD instead of belt.
hence needing a long shaft on the motor (to fit the slider and such like on)
that way i can either have constant tail throttle.. or mix it with the main motor throttle in some way.
Old Jan 24, 2008, 10:19 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Beltless is still alive and working well
Seven running locally
http://www.rcgroups.com/forums/showthread.php?t=492675
Reflex1 is offline Find More Posts by Reflex1
Old Jan 24, 2008, 10:42 AM
Almaz is offline
Find More Posts by Almaz
Almaz's Avatar
United States, IL, Chicago
Joined Nov 2006
I might be wrong but using 2 motors will be less efficient and would require more power from the battery than just using a belt.
Almaz is offline Find More Posts by Almaz
Old Jan 24, 2008, 11:18 AM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Scale guys do it quite a bit. It can be a royal pain trying to create the mechanical gearing to do a raised tail so a lot of people just use a brushless motor for that. You don't see it to much on non-scale helis.
L0stS0ul is offline Find More Posts by L0stS0ul
Old Jan 24, 2008, 03:44 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Without any number, it's hard to say so. It might be the other way around. On my bigger heli, belt tension is pretty heavy, I think tail motor would be much better.
thanhTran is offline Find More Posts by thanhTran
Old Jan 24, 2008, 05:31 PM
Singapore
Joined Jan 2004
I tried using motor to drive the tail for TRex 450 size before.
This is what u need:
A outrunner motor that allow u to remove the main shaft (motor). GWS motor is one of them.
A longer 3mm shaft. U can use those micro size heli like Honey Bee CP/CP2 main shaft.
Modify the existing TRex tail casing in order to have the main shaft hold it in place. (a shaft collar or pulley that hold the shaft so it does not slide in and out)
The motor is mounted in the opposite side of the tail blades.
Thus, u can use back the normal TRex tail hub, slider, blade grips and blades.
U need another ESC for the tail motor. U need it to be able to run in Governor mode.
Personal Opinion:
Compare to belt, I rather go for belt. For elevated tail with belt is actually very easy.
Using tail motor does not look scale on the tail side. Spin up and power down also do not look scale (main and tail spin up/down independently).
If your tail ESC governor is not that good, it suffers from tail wagging when u move your tail due to motor is hunting.
If u want to have higher tail authority, u can always go for higher tail RPM by changing the tail ratio or use multibladed tail instead.
SH
Old Jan 25, 2008, 01:42 AM
UK
Joined Sep 2003
cheers guys thats exactly what i was looking for.. i knew id seen it somewhere before. :-)
Old Jan 25, 2008, 08:45 AM
darthdrk is offline
Find More Posts by darthdrk
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
I run my scales using a motor driven tailrotor on my scales. Looks great and works very well. On my 450 size helis Im using an AXE CP N-60 high authority brushed tail motor. While the motor is turning unless you have freeze frame stop vision, you cant tell about the tail rotor while its spinning. Personally, it dosent look bad just sitting either. Heres a few pics:
Some good things Ive found using the electric tailmotors: You can run at main rpms at a higher pitch and lower rpm without loosing tail authority. Every Heli with an elevated tail hasi it in a different location or height. If you use a belt driven tail, you would need a specific tailboom/belt mod for each model. Example: The Blackhawk tailboom is much taller than the UH-1 Huey and also at a different angle. How does it perform, so far Im having a blast with mine. Fwd flight is excellent also. Flying scale you have to remember youre not doing blinding piros, flips.
darthdrk is offline Find More Posts by darthdrk
Old Jan 25, 2008, 11:45 AM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
Personal Opinion:
SH
What power rating would the tail need to have? How many watts? GWS motors are a bit on the heavy side, it'll throw off the balance quite a bit. Got any motors you tried that worked you can suggest?
rcboosted is offline Find More Posts by rcboosted
Discussion Is there a shaft-drive for T-rex 450 available?? geekdisk Mini Helis 21 Oct 11, 2009 03:52 PM
Discussion Cp Pro VS T-Rex 450 First Heli Rexor Micro Helis 15 Feb 23, 2007 01:28 PM
Help! Lenght of tail drive belts for Walkera 60 and T-Rex 450? EWo_Ge Mini Helis 2 Oct 17, 2006 08:13 AM
Question Mounting 9650 on tail of T-Rex 450 ormandj Mini Helis 2 Jul 21, 2006 12:43 PM
