Old Jan 22, 2008, 03:59 PM
dusty IV is offline
Find More Posts by dusty IV
dusty IV's Avatar
Joined May 2004
Epoxy resin vs polyu
I have a model planked in obechi. I usually use epoxy resin with fiberglass to strength this surface.
Some where in the distant past I think I read that you can use water based polyurethane. Does anybody have a comparison on this?
dusty IV is offline Find More Posts by dusty IV
Old Jan 22, 2008, 11:19 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Epoxy and glass will be stronger than the Polycrylic and glass, but the epoxy is harder to sand compared to the polycrylic. I have done it on several models and it is fairly easy to work with and easy to get a nice finish. The nice thing is that it is single component, easy clean up, and easy to sand/fill/primer. You will not get the durability of an epoxy/glass surface but I find it is easier overall to build lighter and gain some durability.
Troy is offline Find More Posts by Troy
Old Jan 23, 2008, 12:47 AM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
It kind of depends on what sort of internal structure your wing has. If it has a good solid spar system and doesn't need the additional strength, use poly, as it's lighter and easier to deal with, and will give a very nice surface. If you need additional strength, go for the epoxy finish, and maybe add some lightweight glass.
Good Luck,
DLD
DLD is offline Find More Posts by DLD
Old Jan 23, 2008, 12:41 PM
dusty IV is offline
dusty IV's Avatar
Joined May 2004
Actually its on the nose of a sorta Kadet Senior. The 123 battery is very heavy and I wanted some extra strength. Planning on using 3/4 oz fiberglass over the Obechi. The Obechi is prone to splintering compared to balsa so it needs something to hold it together.
The plane gets covered in Oracover including the nose. The poly sounds like it might work so I'll give it a try. Maybe I should build up two samples before messing up the plane.
Old Jan 25, 2008, 06:42 AM
Double Pappa is offline
Find More Posts by Double Pappa
Blue Collar DLG Marshall
Greensboro, NC
Joined Jun 2007
In what you are describing the strength will come from the glass and the poly will simply keep it attached and solid. I use WBPU with a variety of materials to give my foam wings are hard skin. Not as hard as epoxy but, as mentioned, perfect in every other way.
Double Pappa is offline Find More Posts by Double Pappa
Old Jan 26, 2008, 03:38 AM
marfish is offline
Find More Posts by marfish
"just one more pass"
marfish's Avatar
Bakersfield, Ca.
Joined Sep 2005
Hmmm.... Polyurethane and polycrylic are vastly different substances. Don't get them confused.
The urethane is a glue and expands as it cures.
The polycrylic is a type of varnish clear coat and not meant to be a glue though it does a respectable job of keeping the glass adhered to the substrate.
Marlan
marfish is offline Find More Posts by marfish
Old Jan 26, 2008, 06:09 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
But for finishing an exterior surface using single component Polyurethane (Gorilla glue eg) would be a mess. The water based polycrylic is a very easy system to use with light glass and easy to control weight and later prep for paint. I sheet wood over foam with Poly-U often with glass reinforcements but would never consider it on the exterior due to foaming and rubbery sanding surface.
Old Jan 27, 2008, 01:19 AM
marfish is offline
marfish's Avatar
Bakersfield, Ca.
Joined Sep 2005
No issue there. It works well for that.
Marlan
Old Jan 27, 2008, 01:56 AM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
Here is an example of how you Can use polyurethane(Elmer's Ultimate) and glass, if you have a mold.
http://www.rcgroups.com/forums/showp...5&postcount=33
I've built the pod using epoxy and glass as well. The PU and glass seems much less brittle after crashes and hard landings - still going strong with just scrapes and scratches. Your application is different, but just showing it can be used in molding.
HELModels is offline Find More Posts by HELModels
Thin epoxy resin for LEG spars Dunqun Slope 13 Nov 18, 2004 09:15 AM
What thins epoxy resin? Jeff Charlot Slope 34 Oct 14, 2004 07:55 PM
Ripmax SP Epoxy Resin Neil Stainton Electric Plane Talk 3 Sep 19, 2003 05:14 PM
Help to locate Epoxy resin & Glass The Baron Scale Kit/Scratch Built 1 Dec 18, 2002 09:42 PM
