n/a Posts
Re: How to make a brass nameplate?
Tony Jeffree wrote:
> On Tue, 22 Jan 2008 09:58:18 +0000, NoSpam <nomail@hursley.ibm.com> > wrote: > >> I need to make a brass nameplate with (not surprisingly) a name on it, >> but I don't have a CNC mill. >> Is it possible to use pcb etching techniques (use a Word processing >> package to print a master then somehow transfer it onto the brass as a >> resist layer)? Or is there a better way that everyone except me knows >> about? Or is this something to outsource? > > Should be possible to use the laser toner resist approach - basically > what you do is print the resist on a laser printer onto glossy photo > paper and then iron it onto the metal. [...] This method should work, as it does for PCBs. You may find the transferred toner (which has some of the paper coating stuck on it) can float off during etching - deeper the etch, worse the chances - it's hard to get it to adhere well & evenly to the metal. > Not sure how well the PCB etchants (ferric chloride for example) work > on brass, but I'm sure you can find something that will work. Should be fine, ferric chloride will etch copper & zinc in a more controlled way than acid. Here are some good pages: http://www.ganoksin.com/borisat/nena...ed-etching.htm http://www.ganoksin.com/borisat/nena...nsfer_etch.htm hth Guy |
n/a Posts
On Jan 22, 3:58=A0am, NoSpam <nom...@hursley.ibm.com> wrote:
> I need to make a brass nameplate with (not surprisingly) a name on it, > but I don't have a CNC mill. > Is it possible to use pcb etching techniques (use a Word processing > package to print a master then somehow transfer it onto the brass as a > resist layer)? Or is there a better way that everyone except me knows > about? Or is this something to outsource? Sandblast etching would also work. http://www.sandcarver.org/introduction.htm |
| Thread Tools | |
| How to make scale smoke from electric powered planes. | KOMET 44 | Electric Plane Talk | 0 | Sep 08, 2001 07:05 PM |
| How to make scale WW I aircraft wheels? | trevsie | Scale Electric Planes | 4 | Jun 19, 2001 02:51 PM |
| How to make the new APC Electric props fit your adapter | Joe Elston | Electric Plane Talk | 6 | Jun 17, 2001 01:56 AM |
| How to make cowling ? | vicman | Beginner Training Area (Aircraft-Electric) | 5 | Jun 13, 2001 02:22 AM |
| How to make ASF videos? | risto | Electric Plane Talk | 4 | Jun 06, 2001 01:00 PM |
