Old Jan 21, 2008, 06:52 PM
STANG KILLA SS is offline
Find More Posts by STANG KILLA SS
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
E-Flite Extra 260 VS Fliton Extra 260 mini
same price same size. which would yall recomend?
E-Flite Extra 260 3D 480
http://www.e-fliterc.com/Products/De...ProdID=EFL2475
Fliton Extra 260 Mini
http://fliton.com/new/product/extra.asp
E-flite
AUW 2629 oz
wing area 375 sq in
Fliton
AUW 22 - 24 oz
wing area 335 sq. in
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Jan 21, 2008, 07:07 PM
FlyCush is offline
Find More Posts by FlyCush
Joined Nov 2007
Fliton
FlyCush is offline Find More Posts by FlyCush
Old Jan 21, 2008, 07:12 PM
MICKEL is online now
Find More Posts by MICKEL
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
I'm going out on a limb here in a way, I haven't flown the Fliton. But I bet it comes in at the heavier end of the spectrum as compared to EFlites 260 with the same equipment/setup. The more wing area and consequently lower loading (again same setup) tells me I would like the EFlite better.
FO4 will have his Fliton built soon I'm sure. Maybe we can do a comparison.
MICKEL is online now Find More Posts by MICKEL
Old Jan 21, 2008, 07:33 PM
Gregg28 is offline
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
What do you want to do? From what has been written, they are both good planes, but good for different things.
Gregg28 is offline Find More Posts by Gregg28
Old Jan 21, 2008, 08:06 PM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
You can't go wrong with either. The extra wing area of the E-Flite will make it up for the extra weight. They both look great, too.
Malves is offline Find More Posts by Malves
Old Jan 21, 2008, 08:08 PM
marky1 is offline
Find More Posts by marky1
Cleveland
Dont mean to hijak the thread but, what about the e-flite versus the extreme flight extra?
marky1 is offline Find More Posts by marky1
Old Jan 21, 2008, 08:44 PM
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Extreme Flight for shizzle. But the other is 7oz lighter and I fly it better, go figure.
EFlite= 20+ amp setup for 3d
EF Extra =35+ amp setup f0r 3d
Old Jan 22, 2008, 12:41 AM
Fatherof4 is offline
Find More Posts by Fatherof4
Raised on 80's Pattern
Fatherof4's Avatar
Rancho Santa Margarita, CA
Joined May 2006
Mickel,
I got the older Fliton Extra 330 mini. The 260 is a newer and larger model. But I liked your tongue in cheek humor!! You know it will be close to year before I get to the Extra.....AM on the workbench. Give me two months....
FO4
Fatherof4 is offline Find More Posts by Fatherof4
Old Jan 22, 2008, 01:09 AM
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Foot is very comfortably residing in my pie hole.
Old Jan 22, 2008, 08:47 AM
Killeen TX
Joined Dec 2006
CARE to elaborate?
ill be after high alpha 3d. particularly im looking for one with SUPER stable harriers with little wing rock.
not really into pattern aerobatics.
father, i origonally wanted teh 330mini, but now want the larger 260 for the added stability/weight/ wind capabilities. and also the 330mini had so many "problems" with the kit.
the extreme planes are way too big. the 42" is pretty much my max. i dont want to buy all new esc, batterys, motors etc. looking to keep what i got.
Old Jan 22, 2008, 09:08 AM
AllBread is offline
Find More Posts by AllBread
Like a boss!
AllBread's Avatar
United States, CO, Denver
Joined Sep 2007
That might rule out the E-flite, then. Myself and others found that it had an unusually high amount of wing rock in harrier flight. Check the E-flite thread about it.
AllBread is offline Find More Posts by AllBread
Old Jan 22, 2008, 09:14 AM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
CARE to elaborate?
I have not flown either of these planes, but from what I have gleaned from the threads:
The Fliton 260 Mini has some trouble with snapping and high-alpha. Great pattern plane, but not really great 3D.
The E-Flite 260 seems to be better at 3D, but I just have not heard enough Hoo-Hah to warrent trying one.
In case you have not noticed, I am a HUGE fan of the Fliton Extra 330 Mini. Yes, there are 'problems' with the kit, but they are not deal breakers for me. They plane is fantastic for harriers and high alpha along with just about everything else.
Old Jan 22, 2008, 10:35 AM
Fatherof4's Avatar
Joined May 2006
Stang,
Like you I have gear ready to go in a new plane. My Hacker 20-20l, Hacker x-20, and TP Prolights 1320 are perfect for the Extra 330 mini according to the threads. Therefore, I bought that plane. I am not worried about the modifications (not problems) that need to be done. There is a great thread detailing what needs to be done.
I think you are going the right direction, find a plane that fits the gear you have.
Mickel above has the EFlight and he is a GREAT pilot. Mickel, what say you?????
FO4
Old Jan 22, 2008, 11:27 AM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Completely true. The rudder is very sensitive on the Fliton 260 and to much rudder input while in HA flight could easily result in a snap. Small inputs of rudder during HA is what this plane needs.
There is also a fair amount of wing rock in harrier but it can be controlled with aileron control. Nice pattern plane, O.K. 3D airplane.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Jan 22, 2008, 11:57 AM
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
FO4: Thanks for the kindness! (He flies very well himself watch the vid )
EFlite Extra 260:
Rolls are fast, so fast that a full speed to 1/4 (knife edge) looks killer as it rips by on its wing. (KE has a little pull to the gear on mine.)
Loops are graceful but by pulling too hard on the elevator, it will fall out. Going over the top (waterfall) and it will elevator down pretty smoothly. Outside loops run off course a bit unless I use corrective inputs.
In high aplha I can "fly" out the rock with constant input; inverted it has almost no rock at all. High-alpha rollers are sweet, circles or straight ahead.
Snaps are lenient in that full throttle corner sticking results in a semi-wild manuever. (Now the EF Extra, that one snaps wicked-bad, doubles and triples)
Spins are ok upright, inverted ones look better (flatter).
Hovers are easy to lock in, and it will torque quickly, so be ready to face its belly a couple times depending on how long you keep it there.
In my experience Extras are a little pitch sensitive and a hard rudder blast will definitely throw it around (into trouble) in a heartbeat.
Discussion E-flite Brio 10 Vs Extra 260 3D 480 OzparkPilot 3D Flying 2 Nov 19, 2007 08:02 PM
Video E-Flite Extra 260 foamy WingsWest328 Electric Plane Talk 0 Jan 25, 2007 03:23 PM
Video E-Flite Extra 260 foamy WingsWest328 Electric Plane Talk 0 Jan 20, 2007 10:17 PM
