Old Mar 01, 2008, 07:40 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks great!
Keep going.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Mar 07, 2008, 12:37 AM
nem3 is offline
Find More Posts by nem3
Joined Mar 2002
Well I have the canopy plate and canopy completed. After reading and thinking about Ron's post, relaxing a little. I started thinking about his question about the battery tray. So I did a little figuring. I designed the F22 around using a 3S3P Evolite 2100 setup. As such I made the battery tray able to accomodate the packs, and long enough to be able to move them 2 and 1/2 times there length forward or backwards. Now since some or most of you will not be running that setup. I tried to find what you folks would or could run. Here is a list of the batteries that will fit, their oriention and quantity.
Evolite 2100 3S - Horizontal - 6
EVO25 3300 3S - Horizontal - 2
EVO25 3300 4S - Vertical - 2
EVO25 3300 5S - Vertical - 2
EVO25 3700 3S - Horizontal - 2
EVO25 3700 4S - Vertical - 2
EVO25 3700 5S - Vertical - 2
EVO25 4350 3S - Horizontal - 1 - If tray is made longer
EVO25 4350 5S - Horizontal - 1 - If tray is made longer
EVO30 2000 3S - Horizontal - 4 - Maybe 6 if dimensions numbers are accurate
EVO30 3200 3S - Horizontal - 4
EVO30 3200 6S - Vertical - 2 - Should fit.
TP6000-3S3P - Horizontal - 1
TP6000-4S3P - Horizontal - 1
TP6000-5S3P - Horizontal - 1 - If tray is made longer
TP3300-3SXV - Horizontal - 2
TP3300-4SXV - Vertical - 2
TP3300-5SXV - Vertical - 2
TP3300-6SXV - Vertical - 2
TP3850-3SXV - Horizontal - 2
TP3850-4SXV - Vertical - 2
TP3850-5SXV - Vertical - 2
Now the battery tray is currently 310mm long. Unfortunately in order to make it longer I will need to decrease the width of the lower half as it already intersects the intake ducts. The nice thing is that the lower section is 74mm wide, so I could make the 4350 fit twice.
The real question is what capacity lipo's you folk's run on dual 70mm fan setups.
nem3 is offline Find More Posts by nem3
Old Mar 07, 2008, 06:35 AM
MEV_F4 is offline
Find More Posts by MEV_F4
MEV_F4's Avatar
Melbourne.Aus
Joined Oct 2006
You would proberly use an typical HET twin setup
2 x het 6904 fanunit with 2W20
2 x TS54 ESC
2 x 4S1P 2200 Fullymax 25C lipo.
MEV_F4 is offline Find More Posts by MEV_F4
Old Mar 07, 2008, 09:59 AM
MattinAZ is offline
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
Originally Posted by nem3
For those of you who are currently working on F22's. I would like to share my plans with you at this time. This way we can compare notes. You are not required to share yours with me. But I would like comments and suggestions on where I am going wrong and what can be done better. Please let me know if any of you would be interested in this.
Thanks, Nick
Absolutely, Nem you are doing a great job. Even if you get it 90% correct on your first attempt at F22 you will be way ahead with the 3D model.
I have used SolidWorks 3D (self taught hack) for a few years now on everything from airplanes to a shed for the backyard. What fun 3D modeling is.
Good luck, I have this one subscribed.
Matt
MattinAZ is offline Find More Posts by MattinAZ
Old Mar 07, 2008, 10:54 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I don't mess around with the 3200 to 3700 stuff since my stuff is mostly 5 or 6S, I use 5000 mah cells. 70 amp draws eat up the juice quick and a 2 1/2 minute flight isn't appealing to me.
There's little room in F-22s with gear for a tall brick pack, so I've had to use two packs taped together and wired in series.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Mar 07, 2008, 10:58 AM
nem3 is offline
Joined Mar 2002
Thanks for your help Ed. I was hoping that folks weren't using one huge pack. The more I design this jet, the more universal I am trying to make it for others. Today I will be working on the battery tray some more. I will also have to engineer a way to hold the batteries in place. Will post pics when I finish.
Thanks, Nick
Matt, Pm'ed you back.
Old Mar 07, 2008, 11:36 AM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Nem,
If you listen to anyones advice on the F-22 it should be Ed's. He has scratch F-22's already flying and they fly incredibly well. He maiden his latest F-22 at the AZ Electric Festival in Jan. It wt something like 10lbs, looked absolutely scale, and had amazing flight characteristics. Fast, Slow, it could do it all. Dont be so modest ED, I know your blushing
I just wish I had the time and talent to do what you, ED and all the others who actually scratch build thier planes because they want better. I barely get time to charge batteries and fly anymore.
Matt
Old Mar 07, 2008, 11:39 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
yeah nem dont kill yourself with those smaller packs. 3700 would be min for most solid setups. and in 1p they wont be too big. or as Ed says just aim for 5000 and it will cover just about anything. heck gimme a single 5000 pack I can run twin 90 on it!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Mar 07, 2008, 12:34 PM
nem3 is offline
Joined Mar 2002
Barry, I seem to have gotten Ed's and MEV_F4's post confused together. So you guys are saying that I should be aiming for a single pack setup? In the 4-6S 5000 range.
{EDIT}
Well, looking at the drawing, that shouldn't be a problem. I'll have to take a few steps back and modify the battery tray. But I'd rather do it now.
Thanks again guys. Nick
Old Mar 20, 2008, 09:24 PM
nem3 is offline
Joined Mar 2002
Old Mar 20, 2008, 09:41 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Oh, now it's on!
Those cut parts look great, should just slot together!
Odysis is offline Find More Posts by Odysis
Old Mar 21, 2008, 06:05 PM
tauscnc is offline
Find More Posts by tauscnc
tauscnc's Avatar
IL
Joined Nov 2002
Wow, nem3, awesome work man. Hey thoes cuts look so clearn...what kind of bit are you using ...I bet they are expensive
taus
www.cuttingedgecnc.com
tauscnc is offline Find More Posts by tauscnc
Old Mar 21, 2008, 08:26 PM
nem3 is offline
Joined Mar 2002
What Tauscnc is hinting at is the $30 bit I broke by accident when I went to route out the second set of bulkheads. DUH
Old Mar 22, 2008, 03:02 PM
Ron Pogue is offline
Find More Posts by Ron Pogue
United States, AZ, Phoenix
Joined Jun 2002
nem3 -
Looking GOOD!
Is that plywood or balsa you are using?
My Raptor has frames of 1/8" and 1/4" lite ply from Balsa USA, they may be to heavy, just have to wait and see I guess.
Been thinking of making the top hatch very large, even including the wing, sort of like the JHH A-7. What do you think?
Ron
Ron Pogue is offline Find More Posts by Ron Pogue
Old Mar 22, 2008, 04:05 PM
nem3 is offline
Joined Mar 2002
Thanks Ron,
The bulkheads, wing attachment rib and crutch peice are all lite-ply from Balsa USA. The servo trays and landing gears plates will be made from regular 1/8 plywood. The whole fuselage will be sheeted with 1/16 contest grade balsa. Still undecided about what to sheat the wings with. Tossed between just glassing them or using 1/16 contest grade balsa.
I am actually going to have a couple of hatches. Since everything is so spread out. The canopy will be removable for the batterys. Then another hatch over the fans and elevator/rudder servos. And 4 more for the vectoring nozzle servos.
F22 Raptor videos outthere? with BL setup dgoderich Electric Ducted Fan Jet Talk 1 Jul 27, 2008 04:49 PM
F22 Raptor stephenzagy Electric Ducted Fan Jet Talk 2 Jul 16, 2003 10:29 AM
F22 Raptor stabilator tips? Basketcase Foamies (Kits) 4 May 28, 2003 06:14 PM
Wattage F22 Raptor Sale/Trade b0gh0s Aircraft - Electric - Airplanes (FS/W) 1 Nov 04, 2002 03:54 PM
F22 Raptor Flys Inverted, into trees... rtucker Foamies (Kits) 4 Oct 23, 2002 10:15 AM
