Old Jan 20, 2008, 03:24 AM
cloud-9 is offline
Find More Posts by cloud-9
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Troubleshooting "dead" lipo
What does a dead lipo act like, and what could I have done to kill it?
I have a new 800 mah Polyquest 3s1p I bought a couple months ago, it was one of a few. A month ago I started using them, and charged them up with no incident. I have used some of them 1 or 2 times each, charging them back up after use. Today, I put one in my plane, and there seemed to be no charge at all, like a completely dead battery. It has been charged and run once or twice, or charged and never run. I put it on the charger, and the green light did not budge from green (it should turn red to indicate charging). The leads and connector seem to look fine and feel fine. I tried some of the other batteries and they worked fine with charger and plane. I could test the continuity between the balance plug and the wire to it, and the charge/power plug and the lead connecting it, to see if a wire is not connecting well to a plug, but I think it's unlikely both plugs could go bad at once. Any suggestions on how I can determine what's up with this battery?
Thanks much,
Jim
cloud-9 is offline Find More Posts by cloud-9
Old Jan 20, 2008, 05:25 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Do you have a volt meter? If so what is the voltage at the discharge plug?
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jan 20, 2008, 03:31 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
only a slow discharge capacity test will diagnose a bad pack and bad cells
hall woo is offline Find More Posts by hall woo
Old Jan 20, 2008, 06:38 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
You need to get a volt meter to check voltage across the balance tabs for cell voltages and check the main tab for pack voltage.
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Jan 21, 2008, 03:47 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
How do you do that? Do you need a power analyzer?
I will check the main and balance plugs with my VOM later today...and report back. Thanks all.
jim
Old Jan 21, 2008, 04:16 PM
hall woo is offline
Permanently Banned
Joined May 2003
no, just a watts up meter and voltage protector
Old Jan 21, 2008, 08:26 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Thanks Hall Woo. What do you mean by a voltage protector?
Jim
Old Jan 22, 2008, 04:38 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
At the charge plug the voltage is 12.63. The voltage between the two farthest apart leads on the balance plug is also 12.64. The voltage between each lead and the adjacent lead is 4.21. This sounds to me like it's OK, but that's not based on any expertise.
Should I just try to use it again in the morning and see if it still acts dead? At least being fully charged would explain why the light on the charger stayed green instead of going to red. Doesn't explain why the plane acted like no battery was connected though.
Jim
Old Jan 22, 2008, 08:27 AM
Dickinson, Tx.
Joined Sep 2004
Could be bad connector/bad solder joint on the pack since the other packs worked normally. Try re-soldering the pack connector.
Challenger413
Old Jan 22, 2008, 08:50 AM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
SOunds like a broken lead to me. Check the wires in the pack, sounds like one came off the battery tab/tap.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Jan 22, 2008, 12:52 PM
hall woo is offline
Permanently Banned
Joined May 2003
Jim
fma voltage guard
Old Jan 22, 2008, 01:22 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Hi again, I read the voltages from the connectors, that is, by touching the probes to the two deans tabs in the female holes, and on the balance plug, by touching the silver connections in the plug. Doesn't this eliminate a problem with the connection between leads and plug or leads and battery? But it also makes everything more perplexing. Maybe it's intermittent, and that day the leads were not connecting well. Resoldering seems like a good next step if the problem happens when I connect it to the battery again.
Jim
Old Jan 22, 2008, 02:46 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Jim, my bet is your deans has a bad connection. Knockoffs are more known for this, I have had this 3 times in the past year so I am over them.
Replace the packs Deans and re-try. It should work then.
Rick
rampman is offline Find More Posts by rampman
Old Jan 22, 2008, 02:47 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Sure does Jim - try wiggling the wires while measuring the V but be careful not to short the pack while doing that.
There have been reports of "bad' imitation Deans connectors--they make contact if pulled slightly apart but fail to make contact when fully inserted. A search should find those threads. Were your Deans real or just like's?
hoppy is offline Find More Posts by hoppy
Old Jan 22, 2008, 02:56 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
If you leave them fully charged for too long of time, you can get very little capacity as the cell degrade from that.
Pinecone is offline Find More Posts by Pinecone
Alert HELP!!! Apache Smart Charger 2500 and dead Lipo mrbaseballny Batteries and Chargers 3 Apr 11, 2005 09:57 AM
Accu-Cycle Elite and trickle charging a dead Lipo Valid8r Batteries and Chargers 1 Mar 12, 2005 12:45 PM
dead lipo -- a complete mystery shams42 Batteries and Chargers 4 Jan 31, 2005 10:12 PM
Dead LiPo? root729 Batteries and Chargers 1 Jan 14, 2005 08:30 AM
Dead LiPo ? mrfirkin Batteries and Chargers 4 Dec 08, 2004 06:59 PM
