Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
Old Jan 20, 2008, 02:16 AM   #1
A123 set up for a Trex 450?
So I'm shopping around for a packs for my heli. originally I was looking at lipo pacs of the 3s 2200mah 20C variety, but these A123 cells are sounding better and better. I'm new to helis so a few extra grams isn't a big deal. Shorter charge time and higher durability out weigh higher discharge rates and lighter weight. I've been looking around for small helis set up with a123 cells and have only found a few. Is anyone out there running A123's on their 450? and if so what size and brand?
Ted
MTBsuspeng is offline Find More Posts by MTBsuspeng   Reply With Quote
Old Jan 20, 2008, 08:43 AM   #2
Older than rocks
n2wizard's Avatar
Location: Parrish, FL, late of Bensalem, PA, now in the old folks home
MTB
Try http://www.rcgroups.com/forums/showt...ight=a123+trex
Herman
n2wizard is offline Find More Posts by n2wizard   Reply With Quote
Old Jan 20, 2008, 04:10 PM   #3
tronyony's Avatar
I have just switched to the A123 M1 2300mah cells in my Rex. Right now I'm running 4S1P packs. I have been getting between 7 and 8 min of flight doing FF, flips, rolls and ugly attempts at tic-tocs. The first flight was in my small back yard so all I could do was hover around and climb outs. I got about 9 min doing that. My setup is a very over weight Rex with JGF 450th w/13t pinion, Jazz 40-6-18 esc, medusa 6v bec, HS-81 mg's on cyclic and a 9650 on the tail. Even with all this weight it hardly bogs on climbout. head speed is at 2800 in normal and 3000 in idle up. The packs weigh 323 grams compared to my DN 3s 2150 lipos at 165 grams. My AUW is 2lbs 2.4oz. The funny thing is, it doesn't seem to mind it all that much. It is nice in the wind though. I flew it today in about 10-15 mph wind and all was well. I am no where near being ably to take advantage of a light setup for 3D so this is perfect for me. I tried to search for info on this myself and only came up with a couple of people who have done it and a bunch of nay sayers so I just did it. Happy I did. I charge them with my Astroflight 110DX with an a123 chip in it. Takes about 18 min to charge a dead pack putting back about 2200 mah.
Hope this helps,
Tony
  • Name: 100_1446.jpg
  • Name: 100_1447.jpg
  • Name: 100_1448.jpg
tronyony is offline Find More Posts by tronyony   Reply With Quote
Old Jan 20, 2008, 04:16 PM   #4
tronyony's Avatar
By the way, you can use this calculator to either figure out HS or pinion to use. Very helpful for me.
Tony
http://www.bladebusters.com/calculator.html
Old Jan 20, 2008, 05:01 PM   #5
Speed cost money.
highflier's Avatar
Hope this helps,
Tony
Find charges thread on 10.00 charger.. It's for A123 cells 3s packs. If you gear up and drop voltage you can charge packs at the same rate you discharge them. 7-8 min charge.
There is also info about charging 2s or 4s packs if you look closely. That said you again you can charge at 15+ amps
Highflier
highflier is online now Find More Posts by highflier   Reply With Quote
Old Sep 26, 2008, 12:37 AM   #6
Hope this helps,
Tony
How have you configured your packs? They look like a 2x2 setup, can you fit that under the canopy without any dramas?
I'm only asking because I am thinking more and more to move across to the A123's for the safety and price, I'm not planning on 3D stuff for quite a while and most other configs that I have seen the canopy needs to be cut to make them fit!
Regards,
Des.
deswong is offline Find More Posts by deswong   Reply With Quote
Old Sep 26, 2008, 01:50 AM   #7
tronyony's Avatar
The packs are 2X2 and there is no problem for the canopy. It is a little tight but nothing major. When I return home from Iraq I am going to try 3S a123 instead of 4S do to this thread: http://www.helifreak.com/showthread.php?t=71462 I have the Scorpion -6 and 12T pinion awaiting my return from here. I'm no 3D pilot either but even with my current heavy setup it still flips and rolls nicely. 3S will make it a little lighter so that will be nice. Hope this helps.
Tony
Old Sep 26, 2008, 09:38 AM   #8
Most popular A123 setup these days for a T450 is indeed the Scorpion HK2210-6 (4400KV) with 12t/13t pinion and A123 3S 2300 pack. Most people look for a 40/45A ESC since this setup will burst over 50A. The 3S pack weight about 240g compared to a typical 3S 2200 lipo at 180g. the extra 60g isn't too bad and the 2210-6 has more than enough power to handle it (rated up to 540W!).
kgfly is offline Find More Posts by kgfly   Reply With Quote
Old Sep 26, 2008, 11:14 AM   #9
Seems like it'd be really nose heavy with 4s! I wonder how difficult it would be to balance out 323 grams??
-Raymond
raymond_h2002 is offline Find More Posts by raymond_h2002   Reply With Quote
Old Sep 27, 2008, 01:00 AM   #10
tronyony's Avatar
If I remember right, it is a bit nose heavy. A lot of that can be balanced out with the servo placement on the boom. It has been over 6 months since I have even seen my Rex so I could be wrong. All I can tell you is that it still flew good. 3S does seem like the way to go though. Not to mention the zip charge method (http://www.rcgroups.com/forums/showt...ght=zip+charge) for 3S and a DB Terminator(http://www.rcgroups.com/forums/showt...=db+terminator) appears to be great way to charge and fly. I ordered all the parts to construct the Terminator and am pretty excited to try it out when I get home.
Tony
Old Sep 27, 2008, 02:52 AM   #11
Electric Hippy
3S fits under canopy easily and is a touch nose heavy with a 9257 in standard position. I get 7+mins of hovering with a scorpion mentioned above.
I am in Brissy too and you can have a look at mine if you like. WHere do you fly?
  • Name: P7240752.JPG
  • Name: P7240756.JPG
Eagleburger is offline Find More Posts by Eagleburger   Reply With Quote
Old Sep 28, 2008, 11:34 PM   #12
At the moment I fly in the front yard lol - I'm too scared to take mine up in the air.
I'm happy in the sim - but there is a small difference when you actually fly the real thing. I am sick of having expensive lipos swell up because I haven't used them in a while, looks like the A123's are a better solution for me - something I can charge quickly and easily without too much maintenance.
Also I can retrofit the A123's into my Roomba so it can zip charge too
I have learnt with the Lipos though, I have just bought two and will charge them once a week to keep them charged.
I am thinking I need a new esc (I've posted a thread elsewhere on the forums in regards to this) and I might as well look at the CC 45 and then upgrade the motor!
With the A123's why did you go vertical instead of horizontal?
Discussion Quick noob set up ??? on Trex 450 jrjunky Mini Helis 7 Jul 26, 2007 05:37 PM
Wanted Night flying set up for Trex 450se Biggame121 Aircraft - General - Miscellaneous (FS/W) 0 May 09, 2007 01:19 AM
Discussion Looking for someone to build and set up my TREX SE. N2LRY Electric Heli Talk 11 Sep 20, 2006 06:55 PM
For Sale Trex 450x set-up for direct ccpm, lightened frame, trade for Hornet? 3d Pro? Maxir? Johnny B Aircraft - Electric - Helis (FS/W) 4 Nov 01, 2005 09:21 PM
best trex set up for flight times stevenkelby Mini Helis 18 Dec 31, 2004 05:29 AM
Congratulations SimpleM!
