Old Jan 19, 2008, 07:25 PM
Bigmaxy is offline
Find More Posts by Bigmaxy
I'm getting there....
Wagga Wagga, NSW, Australia
Joined Aug 2005
Can I use a Spektrum Air RX with a Spektrum Surface TX?
Hi
I currently run an Airtronics M8 with Spektrum Module and SR3000 and SR3100 Rx's. I'm thinking of purchasing a DX7 for aircraft use and was wondering if I could use the aircraft receivers for car and boat use also to maximise the investment. I know they are a 6 channel rx vs 3 but that shouldn't matter. Will they bind?
Cheers
Scott
Bigmaxy is offline Find More Posts by Bigmaxy
Old Jan 19, 2008, 07:57 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
No, the protocols are completely different. Older Spektrum surface gear and the newer DX6, DX6i, DX7, x9303 do not interoperate.
You can, however, use your DX7 TX (or any of the newer TXs) and their associated receivers in a surface craft. There is no "band" or "frequency" restriction like there was with 72Mhz US "Aircraft only" or (correct me if I'm wrong on the number) 35Mhz Australia "Aircraft Only" bands. 2.4Ghz can be used to control any type of craft.
Many folks are using the newer DX series radios in Robots, Cars, Tanks, I've even seen a post regarding scale trains.
Danal Estes is offline Find More Posts by Danal Estes
Discussion Can I use a 146iP PCM RX with the stock Blade 3 in 1? DonA Micro Helis 10 Jan 05, 2007 10:21 PM
Question Can i use any brand of Receiver with a Hitec TX ? martin_uk Radios 5 Jul 21, 2005 06:35 PM
Can I use the 7th channel on my RX with a 6 channel Tx Doc Watson Power Systems 2 Feb 22, 2002 11:34 PM
Can I use this type of battery with a Soarstar? f2racer Foamies (Kits) 9 Oct 01, 2001 02:30 PM
