Old Jan 18, 2008, 08:51 PM
rnorth is offline
Find More Posts by rnorth
USA, KS, Wichita
Joined Nov 2004
How often do you balance lipos?
I have a quick question that I'm sure has already been asked. When charging a lipo battery, how often do you put a balancer on it while charging?
rnorth is offline Find More Posts by rnorth
Old Jan 18, 2008, 09:29 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Why not just leave it connected?
Old Jan 18, 2008, 09:41 PM
Joe Minton is offline
Find More Posts by Joe Minton
Newbury Park, California
Joined Apr 2002
I use an FMA 4S. The battery is balanced every time I charge it.
Joe
Joe Minton is offline Find More Posts by Joe Minton
Old Jan 18, 2008, 09:44 PM
rnorth is offline
USA, KS, Wichita
Joined Nov 2004
I mean how often do you charge a lipo battery with the balancer on it. I have read where you need to balance the cells every time you charge and others say every 5 or 6 times.
Old Jan 18, 2008, 09:50 PM
Southern Pride
True you will read both of these statements.
Truth is it depends on the LiPoly and how you care for it or abuse it. Top quality LiPolys which are not abused rarely need balancing. Most cheap LiPolys need balancing every charge. Any LiPoly that is abused needs balancing every charge.
Charles
Old Jan 18, 2008, 09:51 PM
rnorth is offline
USA, KS, Wichita
Joined Nov 2004
Joe
Joe, this is what I do. I use a blinky balancer on my lipos every time I charge them.
Richard
Old Jan 18, 2008, 10:01 PM
rnorth is offline
USA, KS, Wichita
Joined Nov 2004
Charles
Charles,
Thanks for your input. I guess for me the safe thing to do is balance everytime. I guess my main reason for asking this is to fine out if there is anything negative about balancing every time? Or is it good to give the lipos a break from balancing every once in a while?
Richard
Old Jan 18, 2008, 10:18 PM
Time Pilot is offline
Find More Posts by Time Pilot
Joined Jan 2004
Originally Posted by rnorth
Charles,
... Is it good to give the lipos a break from balancing every once in a while?
Richard
It is easier on the batteries to balance them, so, just like a girlfriend or wife, having them in balance is a good thing.
Time Pilot is offline Find More Posts by Time Pilot
Old Jan 18, 2008, 10:23 PM
sting35 is offline
Find More Posts by sting35
I need more ceiling!!!
sting35's Avatar
Okinawa, Japan
Joined May 2006
Good luck finding one of THOSE that's balanced.
sting35 is offline Find More Posts by sting35
Old Jan 19, 2008, 01:18 AM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
OK, I'll be the outlaw.
A couple of small 2S 1200 mAh packs have never been balanced in well over a year. They have taps, and are checked infrequently - they are fine.
My larger packs, 5S and 6S, have the original Tanic Packs JST taps - a bit of a pain to connect to. If needed, they are balanced, but that is not very often.
Bill
ebill3 is offline Find More Posts by ebill3
Old Jan 19, 2008, 05:06 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
I use the e-Station BC-8 with built in balancer, balance every charge. No reason not to.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Jan 19, 2008, 05:28 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Like everydayflyer says, depends on the battery and how it has been used. If you are lucky and get perfectly matched cells, balancing is often not needed. however, if there is even a minor difference in the cells capacity, it is best to always balance else the lower capacity cells will become overcharged and could cause a big problem.
Rodney is offline Find More Posts by Rodney
Old Jan 19, 2008, 06:12 AM
Chophop is offline
Find More Posts by Chophop
Glad I'm not a Boll Weevil
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
I understand more than 0.03v different indicates a need for balancing.
About balancers, the ones I see, discharge the cell to balance it with the others. That would seem to be adding to the number of discharge cycles. All that time balancing would also be discharging. Add up 100 cycles of balancing and how many full cycles did it equal ?
Based on all I have studied, the accurate individual cell charger would a better bet. That may increase cell life by independantly charging the cells to balance. Not by discharging them. If one can't be charged equally, something may be wrong with the pack.
I mean the type that charges all cells simultaneously.
EDIT :
An afterthought is the balancers may only discharge in a range from 1/4 to 1/2 C or so, an approximation. At .5C I understand the number of cycles increases to the thousands, so the discharging balancer probably does not have much effect on cell life.
Ch
Chophop is offline Find More Posts by Chophop
Old Jan 19, 2008, 06:31 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
I balance EVERY charge.
How hard is it to do? And are you willing to accept the consequences of not balancing (possibly burning down your house or shop)?
Pinecone is offline Find More Posts by Pinecone
Old Jan 19, 2008, 07:06 AM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
If they are that dangerous, then maybe a cell overvoltage alarm should be connected during charging. It should make a loud audible alarm if any cell goes over voltage and maybe a thermal alarm also. Well, probably throw in an expansion detector too.
I can supply DIY info on those, if I tried to sell them, I'd be swamped with competitors anyway.
CH
How often do you fly? asmokindeal Foamies (Kits) 10 May 09, 2004 04:48 PM
How often do you change your rubberbands? Ralph_D Parkflyers 6 Dec 09, 2003 05:45 PM
How often do you fly? davidleitch Electric Plane Talk 24 Jul 18, 2003 12:05 PM
how often do you charge your tx pack? torcgolf Radios 2 Jan 06, 2003 10:44 AM
Monthly survey results are in: How often do you fly... born2net Electric Heli Talk 0 Aug 01, 2002 03:40 PM
