Old Jan 18, 2008, 03:26 PM
redtail is offline
Find More Posts by redtail
Joined Dec 2005
Question
Phase 3 F16 EDF-motor placement
Hi i have just bought a Phase 3 F16 and i have just read the instructions about the fan placement which depends on the weight of the lipo,is this nessary why cant you just move the battery back or forwards to get the correct C of G.or is there a reason for this that i am missing?
redtail is offline Find More Posts by redtail
Old Jan 18, 2008, 03:34 PM
CFisher1421 is offline
Find More Posts by CFisher1421
CFisher1421's Avatar
Geneva, IL
Joined Jul 2007
I think it's a matter of room...I've got the on/off switch for the JETI mounted in the cockpit, wires galore and Rx...my fat fingers can barely move as it is so sliding the batt isn't gonna happen...
CFisher1421 is offline Find More Posts by CFisher1421
Old Jan 18, 2008, 03:47 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
with the stock setup, i always had it at the ledge and it balanced fine with a 3s 2100 pack...
gunracer is offline Find More Posts by gunracer
Old Jan 18, 2008, 04:10 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah if the motor is in the right place and your batt has room for fwd and aft movement that would be the best set up ....you may in the future put a different motor and run 4s batt.ck the up grade thread for ideas on place ment
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 19, 2008, 12:40 PM
redtail is offline
Joined Dec 2005
Thanks guys , i will see how much room i have with when i put the radio gear in before i decide if i should move the motor-i'm using the stock set up.
Old Jan 20, 2008, 10:04 PM
LuckyDuc is offline
Find More Posts by LuckyDuc
LuckyDuc's Avatar
United States, WI, Hustisford
Joined Dec 2005
Is there a con invloved with moving the motor back when using larger packs?
LuckyDuc is offline Find More Posts by LuckyDuc
Old Jan 21, 2008, 07:40 AM
PerlAddict is offline
Find More Posts by PerlAddict
PerlAddict's Avatar
USA, TN, Murfreesboro
Joined Sep 2006
I was also curious about this ... I'll be using DN Power 3S 2150Mah 15c lipos, which weigh in at 159g, as well as Loong Max 3S 2250Mah15C and 20C lipos, which weigh in at 164g and 186g, respectively.
I was looking at moving the motor back the recommended distance, but I wasn't sure if I was supposed to move the front edge of the fan back 40mm from the molded lip, or the back edge 40mm back from the molded lip (figured it was the front, but wasn't 100% positive). If you do this, it seems like the fan ducting extends too far out the back of the plane for the exhaust cone to fit - do you need to trim the ducting after you've got the fuse glued together in this case?
With an AR6100E receiver, I ought to have a decent bit of room up front for moving the battery around, but I don't want to end up in a situation where I need to move the battery forward to balance it and run out of space ... moving it backwards isn't as big of an issue, but there's not much room to hog out more foam in the front if it's tail heavy.
PerlAddict is offline Find More Posts by PerlAddict
Old Jan 21, 2008, 08:37 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i believe its the front edge there talking about. trim the exhust tube flush with the aft end of cone.
Old Jan 21, 2008, 10:36 AM
PerlAddict's Avatar
Joined Sep 2006
Thanks, AS. I didn't see any mention in the instructions about trimming it when I read through them, though I admittedly didn't read all the little tips sections when I pre-read the manual before starting the build.
I think I may just go 20mm back instead of 40mm and seeing how it balances.
Video Phase 3 F16 - Alfa 5 blade fan with Don's Wicked EDF motor on 4S - Onboard Video Tweakrr Electric Plane Talk 16 Apr 21, 2010 02:09 PM
Found Phase 3 F16 Fan Impellor John Boy Aircraft - Electric - Jets (FS/W) 3 Nov 29, 2007 08:05 PM
Video phase 3 F16 TURBINE Electric Plane Talk 2 Nov 25, 2007 08:55 PM
Video Crash! Twinkletoze Electric Plane Talk 18 Nov 23, 2007 04:16 AM
