Old Jan 18, 2008, 09:03 AM
Broncomech is offline
Find More Posts by Broncomech
United States, CA, North Highlands
Joined Aug 2004
Question
Speed 1.5 /Nan Models. Alex Mini 1.5 setup question
Does any one have the recommended CG and control throws for a Speed 1.5 / Alex Mini 1.5?
Broncomech is offline Find More Posts by Broncomech
Last edited by Broncomech; Jan 19, 2008 at 11:18 AM. Reason: add information to title
Old Jan 18, 2008, 01:22 PM
KurtMc is offline
Find More Posts by KurtMc
KurtMc's Avatar
Sacramento, CA
Joined Sep 2003
Hey Dave: Nice plane ! Is this yours or Ray's? Lets hope for some wind this weekend as I'd like to see this maiden.
+/- 5mm for the ruddervator is a good starting point - maybe have a dual rate switch w/+/- 7mm but not much more than that or it'll be flick city.
Check out Tom's setup page on F3x.com -- most of the planes are set up with similar throws and 60" planes don't need or like much throw on ruddervator.
Can't help ya w/the CG,
Kurt
Who says DS mode on CRRCSIM is a blast
KurtMc is offline Find More Posts by KurtMc
Old Jan 18, 2008, 08:36 PM
RSteel is offline
Find More Posts by RSteel
RSteel's Avatar
Sacramento, Ca.
Joined Jul 2005
Hey Kurt,
Hoping for some wind myself. Just have some reservations throwing her over the rocks :P
Ray
RSteel is offline Find More Posts by RSteel
Old Jan 18, 2008, 09:31 PM
Joined Aug 2004
No maiden this weekend, even if the wind howls.
Still waiting on servos to arrive, FedEx ground is slow this week. I got the Speed unwrapped tonight so it is a ways from first flight. I still need to figure out where all the electronics are going to be placed and construct ballast system, think I will give Target's home rolled tube a shot.
Tom's setup page does not contain any info on the speed seres ships and no information was shipped with it so I am hoping someone here on RCG has some info they can share, the main thing is getting a good starting point for CG.
Old Jan 18, 2008, 09:57 PM
KurtMc is offline
KurtMc's Avatar
Sacramento, CA
Joined Sep 2003
You guys have a pair of them, then? Sweet
(Gotta have a pair to go up against those rocks on a maiden with a crunchie, that's for sure. But, you guys toss off your woodies all the time - same thing !)
There's got to be a build thread on the Speed series out there somewhere? Or, check for SPider 60 threads...
Here's another speed 1.5 thread
or, this one.
Dave: It's dremel time!
Old Jan 19, 2008, 11:26 AM
Joined Aug 2004
No dremel yet, I can't seem to locate any useful info on building this bird. I have seen CG ranges from 65 to 100mm for Spider 60s which many say are the same thing. That is a bit too large a range to be useful for establishing a start point. I sent e-mail to the manufacturer this am will wait and see if they provide any info.
Dave
who got no stinking instructions
Old Jan 19, 2008, 11:48 AM
KurtMc is offline
KurtMc's Avatar
Sacramento, CA
Joined Sep 2003
Hi Dave:
Looks like Sunday might be a good day for the Costco hill...
Old Jan 19, 2008, 12:12 PM
skirmish is offline
Find More Posts by skirmish
skirmish's Avatar
West Yorkshire, UK
Joined Dec 2004
I have the CG at 70mm on mine and it behaves itself very well at that position. There are many occasions when I fly in VERY light lift conditions and with quite a lot of down flap to increase lift and it has never flicked on me.
Incidentally you've forgotten that the model is also known as a Toplight (from Frankemodelbau) and an X-Race (from Airtech in France)
Mine is a hybrid of the two ever since I mid aired with Tims Dragon!
skirmish is offline Find More Posts by skirmish
Old Jan 19, 2008, 12:37 PM
dlrepp is offline
Find More Posts by dlrepp
Brea, CA
Joined Feb 2007
Speed/Spider 60 set-up
Go to Soaring USA sight, click on 1.5 sailplanes, then on Spider 60, scroll to bottom and click on the set-up sheet on right. Shows CG range and control throws.
Don
dlrepp is offline Find More Posts by dlrepp
Old Jan 19, 2008, 08:23 PM
Joined Aug 2004
Thank you for the information I will check Soaring USA those manufacturers sites as well, might just get lucky and find a build thread or some sort of instructions.
Dave
Old Jul 21, 2008, 02:58 PM
uav-oscar is offline
Find More Posts by uav-oscar
Joined Jul 2008
Hi Dave,
I also got Alex mini 1.5 from NAN Models when they came Turkey for the last F3J WC.. I really like the plane but almost no hardware ( just servo covers only ) This is the new version Carbon D Box wing (good for DS) but my problem is how will I make aileron & flap connections ?? no metal pushrod end or similar equipment !!
One of my friend have Alex mini here but old version just 2 servo flaperons on wing but mine for 4 servos (flap & aileron seperate)..
How was your kit hardware?? did you have any connection parts? and please if have pictures of your wing and servo setup please let me see...
Oscar
Turkey
uav-oscar is offline Find More Posts by uav-oscar
Old Jul 21, 2008, 11:55 PM
Joined Aug 2004
Hi Oscar,
The linkage provided with the kit consisted of the brass horn shown in the pics and a short piece of control rod with one end threaded. I did not like the slop in the Z bend to servo control horn so I built my own push rods using a couple of 2-56 threaded brass couplers with a small piece of threaded rod soldered in and a clevis on each end. The servo end was soldered after the trim was set as there is no room for a jam nut, clearance between the cover and the clevis is tight but it works.
The tail surface hardware consists of two brass balls with nylon links to fit, and the push rods installed in the fuselage. Be careful with the mounting posts on the elevons they are easily broken if side loaded, good thing they are easily fixed with CA.
Dave.
Old Jul 22, 2008, 02:32 AM
Joined Jul 2008
Thanks Dave for your quick reply & nice pics..
my problem the kit that I bought have no linkage and brass horn..for that reason I will have to find a solution for connection..
Anyway how is your Alex flying? you enjoy it? and do you have any recomendation such as: c.g. , tarvel adjusts (flaps,ailerons,etc.) and also do you have nice pics of Alex with you and flying pics..
Thanks best regards
Oscar
Turkey
Old Jul 22, 2008, 05:20 AM
sixty9mustang is offline
Find More Posts by sixty9mustang
Surf's up!!
sixty9mustang's Avatar
United States, Mt, East Helena
Joined Oct 2005
Hey Oscar
I set my Spider 60 (same plane, different name) up per the set-up sheet, with the exception of the ailerons, more travel, I like them very sensitive.
I am attaching the set-up sheet from Soaring USA for the Carbon version.
As for mine, I really enjoy it, it has a very wide speed range. I have flown it in as little as 12mph and in 30-35mph, without ballast. It just loved it. Mine weighs 21 oz with the 2 servo wing, I am running the HS-125's in the wing for ailerons and the HS-65HB's in the fuse for the elevators. An Electron 6 RX and a AAA 700mah battery. Mine came with hardware, but the hardware for the ailerons was less than desirable, so I changed that hardware. You can pick up the aileron brass horns at Esprit Model here-- http://www.espritmodel.com/index.asp...OD&ProdID=2554
On the linkage for the elevator, if you can find threaded ball links for it, make sure to use some dish washing detergent on the threads, they will thread in without resistance, or without breaking the posts on the elevator. They will stay in also, they won't back out.
I can post pics of mine tomorrow night if you would like.
Oh and the Soaring USA website for the carbon 4 servo wing Spider/Alex
http://www.soaringusa.com/products/p...ategory_id=257
Happy Flying
Chip
sixty9mustang is offline Find More Posts by sixty9mustang
Old Jul 22, 2008, 09:50 AM
Joined Jul 2008
Thanks Chip,
it helps me a lot and also I would like to see your pics too of course..
Oscar
Discussion Anyone have a Speed 1.5? bryanduke Slope 19 Jan 01, 2007 11:03 AM
Discussion Speed 1.5, 2.0 and 2.6 at F3X SchiessCo Slope 4 Aug 15, 2006 03:47 PM
Alert blade 1.5 setup? florian Slope 1 Mar 30, 2005 12:22 AM
Omega 1.5 cg question NickW Electric Sailplanes 1 Apr 04, 2002 03:09 PM
Omega 1.5 setup and flight report thread. Bleriot Electric Sailplanes 5 Sep 09, 2001 10:54 PM
