Old Jan 17, 2008, 09:34 PM
customminatures is offline
Find More Posts by customminatures
foamanologist
customminatures's Avatar
United States, FL, Sarasota
Joined Apr 2006
AA rx board help......actuator mod-4mm pager motor
Hi all,
I posted this in the indoor section but have had no replies. Thought I would try here!
Im sure some of you have seen some of my micro creations either here or on other boards. Although this is not plane related, the rx board I want to use is. I am building some 5" racing boats and would like to use the AA electronics for testing. I need to know how to do the act mod but in place of the act Id like to use a 4mm pager motor for more torque and it will be cheaper to mass produce with a pager motor vs. an act. I have seen Nitros Tutorial on this but dont fully understand it. Also do I need to perform the no thottle steering mod to make this work?
Here are the boats I am talking about.
Thanks for any help,
Matt
customminatures is offline Find More Posts by customminatures
Old Jan 18, 2008, 01:35 AM
Finnspeed is offline
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Get an AirHogs UBI, I believe it is still @ Target web site for $11.99. That plane is single motor plus actuator and the actuator drive circuit should be able to handle the 4mm pager motor.
Finnspeed is offline Find More Posts by Finnspeed
Old Jan 19, 2008, 08:57 AM
OkFrst'r is offline
Find More Posts by OkFrst'r
Houston, TX
Joined Jul 2007
One note on the AirHogs UBI, this post describes how that board will not take a bigger motor as it is - it will cut off the power:
http://www.rcgroups.com/forums/showt...75#post8796075
So, if you're looking for good power, you'll have to look elsewhere or get into mods.
OkFrst'r is offline Find More Posts by OkFrst'r
How To Reduce The Weight Of A 4mm Pager Motor... ALOT! TimayTheToolman Scratchbuilt Indoor and Micro Models 20 Jul 03, 2006 05:27 PM
4mm pager motor actuator? LenBFP Scratchbuilt Indoor and Micro Models 16 Jun 26, 2004 06:14 AM
efficient 4mm pager motor ? bmaaa Scratchbuilt Indoor and Micro Models 23 May 03, 2004 11:52 AM
My First Home Made Prop For bitG Rudder Steering 4mm Pager Motor jas_Qfix Scratchbuilt Indoor and Micro Models 11 Jul 27, 2003 07:20 PM
RFFS100 & 4mm pager motor Andycart Scratchbuilt Indoor and Micro Models 6 May 13, 2003 04:49 AM
