| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Thread Tools |
| This thread is privately moderated by jsnaphook, who may elect to delete unwanted replies. |
#31 |
Alot of people seem to like the neu 1509/1.5D/6.7 with 4 or 5 cell lithium and 16x17 slim prop. 3 cell lithium might be a cheaper and tamer version for sport flying and less risk of burning up something. Also people use the CC125 with this so a CC180 should be a good long term investment.
The guys that fly neu's scoff a bit at the hackers. I have no experience so take this for what it is. I'm in the process of my first f5b plane: Enigma, Neu 1509/1D/6.7, 3s1p neu 5000, 16x17 slim, CC125, 4xJR168s, 1xD60. All in for close to $1800, but the parts should be a good investment. All the parts are amazing and I can't wait for the synergy to start! Hot lining is no joke! I think you can warm line for much much less investment so just think about what parts you'll upgrade later so you can make good investments now. Good luck and have fun! |
#32 |
Noonan!
arocholl, take a look at the Kamelot, Diamond, Absolute in here:
http://www.fvk.de/Englisch/FVK-Model...h-Version.html Juan |
#33 | |
Electric powered
#34 | |
Electric powered
Diamond looks good, although apparently a bit over the price I expected to limit myself in this case. Kamelot, looks right on target in price, but still two-piece wing, sub $400 price apparently, lot of room inside. I will look closer for differences on these birds. |
#35 |
The difference between the 1.5d and the 1d is the kV (rpm/volt). Basically the 1d runs on 3S and the 1.5d is more for 4S or 5S if you want to push it. Another difference is the number of winds. The wires have a D shape wind 1 or 1.5 times? I'm not sure about this. The y's I think are a y shaped wind. Check out www.neumotors.com for more info.
#36 | |
Electric powered
It takes time (for me at least) to become familiar with a motor brand naming schema. I am so far very familiar with MEGA for inrunner and AXI for outrunner, unfortunately there is little to be reused with Neu. There is clearly additional wire turns for higher Rm and lower Kv, but how each brand, and family inside a brand name it... well... there is really a learning curve. Problem is getting familiar with Neu takes real money so I want to be on target. So I guess one variable on the equation is clear Neu 1509/1D/6.7 + CC180. |
#37 |
Electric powered
Just out of curiosity: no use then of any MEGA + gear in F5F anyone?
Any good reason to prefer Neu over Hacker? Or is it more a religious thing than a technical decission? |
#38 | |
So with that said ..... Any chance of a FREE motor, Steve Neu
#39 | |
Y = WYE wind (a Y shape, yes) |
#40 | |
Electric powered
#41 |
F5B Launch Technique
There is much reference to the difficutly in launching square/over square propped planes.
Does the torque of the motor tend to roll the plane to the left? Do you compensate by launching with the wing tilted to the right? Does the prop wash push the rudder and yaw the plane to the left? Is it important to give the plane a hard throw, or focus more on launching with proper attitude? |
#42 |
RFM spinner joint
On my enigma I have a 16x17 slim mounted on a RFM spinner. The spinner attaches to the motor (1509/1D/6.7) shaft by 2 set screws. The shaft came with no flats on it. I put some loctite on the screws and torqued them in until the allen wrench looked like it was going to break.
Have you ever had a spinner come of the shaft under these conditions? Should I have machined flats on the shaft? Last edited by Whorges; Aug 30, 2008 at 02:28 PM. |
#43 |
Grow old disgracefully!
Yes I have had a prop come off the shaft after fixing as you described. Now I only use 1 of the screws, and grind a flat for it on the shaft. Don't have problems now.
Practice throwing a piece of 2x2 timber until you can throw it hard and STRAIGHT. Then with your transmitter in hand practice switching on the motor just as you throw the timber. Once you have got the hang of that you will be OK launching F5B. For what it is worth I think proper attitude is more important than hard throw (but both is better ) - these things accelerate quick enough to get themselves out of a lot of trouble.Dick |
#44 |
Noonan!
I grind a flat and use one screw and a very small amount of goop. No more hunting for spinner and prop ($$$) in tall grass.
Juan |
#45 |
Hmm, this is two votes for a flat and only one screw...
Why not 2 flats and 2 screws? I imagine if the prop came off in flight and you kept on the motor at all, that the motor is done? How do you make the flat? |
| Thread Tools | |
| Discussion help with getting started | 2wingsonly | Video Piloting (FPV/RPV) | 1 | Jan 03, 2007 09:57 PM |
| Need help in getting started | gulfstreampiper | Fuel Plane Talk | 7 | Sep 16, 2004 09:41 PM |
| Please Help with getting my web page up. | Shawn Davis | Webhosting | 1 | Feb 29, 2004 08:43 PM |
| help with getting pic pro | PhillyB | Micro Helis | 8 | May 16, 2003 02:37 AM |
| Help in getting started please | Zhack | Micro Helis | 3 | Apr 25, 2003 10:24 AM |
