Go Back   RC Groups > Aircraft - Electric - Airplanes > Glow to Electric Conversions
Old Jan 17, 2008, 09:41 AM   #1
3DHS Koolaid Fan
Tower Hobbies Uproar - EP
I crashed my favorite "screw around" plane ..... a Super Star EP aileron model. It was fun because it had a Himax 3630-1000 in her with a 10x8 prop on a 2100 3s lipo. I have to admit, I was doing faster speeds and more stressful manouvers than that little trainer was ever intended for.....so I'm looking for a plane in which to install the 'go-go' parts that I now have laying around. I came across this article
Anyone tried this little beast? Looks like an easy conversion....?
Any other suggestions for this power system?
HMX Dave is offline Find More Posts by HMX Dave   Reply With Quote
Old Jan 17, 2008, 04:24 PM   #2
Uproar
The Himax motor 3630-1000 is rated for 600 watts according to the Himax website. They say it can replace a .40 - 50 gas motor. They also recommend a 35 amp esc. With this combo the Uproar should preform well.
You might want a larger battery perhaps 3000 - 4000 ma.
monokote is offline Find More Posts by monokote   Reply With Quote
Old Jan 17, 2008, 09:57 PM   #3
3DHS Koolaid Fan
Thanks for the help! I've got some 2200 4s 25c batts and a few 3s 2100's with a Deans parallel harness....should work. I was trying to work it under the constraints of the 35A ESC....but I think a 60A might be a better choice.....would allow me some flexability to get medieval with the props and power!
Edit: I ordered the Uproar.....I'll post pics on the project when it gets here.....prolly 3 weeks.
Old Jan 27, 2008, 12:47 AM   #4
zup
hmx dave
been there,done that with the super star ep and a himax 3516.put that motor in a greatplanes super sportster ep and its a rocket! over stressed the horizontal stab tho so on the next one i exopyed a 1/8 carbon fiber rod in the stab.got over 500 flights and never folded the stab again.i use carbon fiber in evrey thing i build now.
zup
zup is offline Find More Posts by zup   Reply With Quote
Old Jan 28, 2008, 12:41 PM   #5
elfwreck's Avatar
Hey now,
I've got two Uproars, Phasor 45-3s for power running on 4s LiPos. Great thrashers! solid flyers, durable, insane roll rates, and they can handle winds too. Not "3D" or anything, but very nice general thrashers for sure.
They even slow down and float nicely...
RobII
elfwreck is offline Find More Posts by elfwreck   Reply With Quote
Old Jan 28, 2008, 01:22 PM   #6
3DHS Koolaid Fan
It should be here this week. I'm wondering if this plane will be similar to the Twist 40? With some extra throws on the control surfaces and near 2:1 thrust to weight ratio we should be able to 3D it, no?
Old Jan 28, 2008, 02:20 PM   #7
txfly's Avatar
twist 40 is heavy. people put 60 glow motors on them to fly them. have you seen the model tech magic v2?
txfly is offline Find More Posts by txfly   Reply With Quote
Old Jan 28, 2008, 10:41 PM   #8
3DHS Koolaid Fan
The Magic V2 looks cool......but I have an Uproar coming. I was wondering how close it was to a Twist40 as I have found one for the RF simulator...
Old Jan 29, 2008, 12:35 PM   #9
elfwreck's Avatar
Hey now,
The Twist is a very different plane in the air. It's a purpose built 3D model for one, heavier for another.
The uproar is an old design, pre-3D. With the aileron cuts like they are it doesn't have enough aileron authority to hover well. It *really* doesn't like sub-stall stunts in any form. It flies a lot like a 'Stick, but more axial in roll.
The Magic v2, if it's anything like the first Magic would be a *great* plane. I had one for years, retired it flyable cuz I got tired of it's looks. But it's a great flier. Nothing spins like a Magic upright or inverted. I can do ascending spins pivoting on the center of mass, strangest looking thing I've ever seen.
If only it weren't so ugly...
RobII
Old Feb 02, 2008, 01:26 PM   #10
3DHS Koolaid Fan
Well....progress is happening.
Uproar is here. Got most of it assembled and working on electrocuting it.
Himax is mounted on the provided mounts. I put 2 washers behind the top mount bolts to give it some down thrust. I mounted the motor with little right thrust.
Removed the mount for the throttle servo. I'm sure the battery will end up in this area. I was going to run some servos which I have laying around, but I'm going to go for low weight and they're standard sized digi servos.....so more mods.
I have a Scorpion 35A ESC.....but the Scorp doesn't like 4s, so I've got a Park BEC going in there so I can run 4s if I like.
Off to buy some HS81's and some light ply....I'll keep the thread going.....
  • Name: IMG_1694 (Small).jpg
Description: Himax 3630-1000 mounted. Himax 3630-1000 mounted. 46.5 KB · Views: 156
  • Name: IMG_1695 (Small).jpg
Description: Front (throttle) servo tray removed. Front (throttle) servo tray removed. 29.2 KB · Views: 81
Old Feb 02, 2008, 08:58 PM   #11
3DHS Koolaid Fan
Done!
Well....she's done. I need to weigh 'er yet.
Battery ended up in the fuel tank area for the CG to balance. Had to slot the wing where it passes through the fuse to set the battery back a bit....but my CG is now nice and adjustable.
I don't have the Park BEC on yet....when I try a 4s I'll put it on. Pulls 34A at WOT with a 11x7 APC on 3s....should be about 66oz thrust.
I have 1.5" up and down on the elevator, 1.25 each way on the rudder, and 1.25" up and down on the ailerons on high rates.
  • Name: IMG_1698 (Small).JPG
  • Name: IMG_1702 (Small).JPG
  • Name: IMG_1699 (Small).JPG
  • Name: IMG_1700 (Small).JPG
  • Name: IMG_1701 (Small).JPG
Old Feb 02, 2008, 09:12 PM   #12
Use whatcha got!
msmith's Avatar
Looks great Dave... thanks for sharing...
Had a few 'uproars' in the past... .40 and .60 sizes (.60 had a .90 super tigre on it though )
Think I'd like to try this conversion as well... Have most of the components already sitting on the shelf... Just would need to order the ARF.
Keep us posted... would love to get the flight report once you get it dialed in.
-mike
msmith is offline Find More Posts by msmith   Reply With Quote
Old Feb 03, 2008, 01:47 AM   #13
3DHS Koolaid Fan
Hopefully tomorry....I'm not much of a pilot yet....but I'll give my feedback!
Old Feb 03, 2008, 07:40 PM   #14
3DHS Koolaid Fan
Got 'er done! Quick 5 min flight on a AirThunder 2200 3s. Zero trimming required! ROG in about 10 feet....no funny traits in the air. As this was the maiden, I never tried too many things (keeping in mind, I don't know much anyways....) but it flew great!
  • Name: IMG_1704 (Small).jpg
Description: My fuel tank cover....with custom made removal system. My fuel tank cover....with custom made removal system. 40.3 KB · Views: 101
  • Name: IMG_1705 (Small).jpg
Description: As she flew.....I haven't put on the canopy yet.... As she flew.....I haven't put on the canopy yet.... 30.7 KB · Views: 155
Old Feb 04, 2008, 07:21 PM   #15
3DHS Koolaid Fan
Finished up.....had to put some contrast on the bottom. Maiden flight in snowy-grey cold skys with a white bottom made for some squinting...LOL. (Sorry 3DHS for the sticker.....its still advertising...) Got the canopy on....pilot out of a trashed PZ Spitfire.
  • Name: IMG_1706 (Small).jpg
Description: Got some contrast on the bottom....sorry 3DHS for the false advertising.....they still make my fave planes.... Got some contrast on the bottom....sorry 3DHS for the false advertising.....they still make my fave planes.... 41.8 KB · Views: 134
  • Name: IMG_1707 (Small).jpg
Description: Got the canopy on....a little contrast on the rudder. Got the canopy on....a little contrast on the rudder. 47.3 KB · Views: 111
Tower Hobbies Uproar - RTF snowfly Aircraft - Fuel - Airplanes (FS/W) 0 Oct 04, 2004 11:03 AM
Tower Hobbies Uproar 40 ARF! AMCross Product Announcements 0 Sep 28, 2004 08:56 AM
Tower Hobbies UPROAR Kit Joel rec.models.rc.air 2 Oct 23, 2003 07:01 PM
Tower Hobbies Uproar??? Steve H. Sport Planes 10 Apr 27, 2001 01:11 AM
Congratulations SimpleM!
