| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
I can't resist. This is taken from Futaba's website.
Futaba gets it right the first time. Futaba takes great pride in making sure that every new product performs flawlessly before it's offered to our customers. Others hesitate to invest so much effort in testing. Some may even consider their "first run" products a step in the process of working out bugs, using feedback from the earliest buyers. Futaba is different. When you choose a Futaba 2.4GHz FASST radio system or module/receiver set, you've selected a fully tested, well-engineered, totally reliable product – one that's absolutely ready to give demanding R/C hobbyists the performance they expect. Our hands-on experience with 2.4GHz technology stretches back 15 years, long before anyone considered its value in hobby applications. That's when engineers in Futaba's industrial R/C division – designers of radio-control tools for construction, civil engineering, and similar uses – began employing and perfecting their own 2.4GHz equipment. Those same engineers were brought in to share their knowledge as soon as we were comfortable that 2.4GHz technology had perfected for the unique demands of R/C hobby applications. No other radio manufacturer had such an instant supply of expertise. |
#32 | |
Proud to eat Kraut ;-)
I was actually the third one, and my radio simply lost its code after I switched it on exactly the same way as I did hundreds of times during the last 6 months. Again, the main error is not that a radio has the ZGUID, but that it has the ability to get the ZGUID all by itself. If this main error will not be corrected satisfactory, Futaba has a reputation to lose, as described here. Weak phrases like "we are not able to reproduce the problem" simply won't cut it. While it is nice to hear that the inventory wil be cleared of ZGUID TXes, this is not the main problem. When XPS, Spektrum, and even ASSAN are able to keep their GUID, it would be very sad if Futaba was not able to manage the problem. Who can guarantee me, that my TX will not lose its GUID the next time I switch it on, like id did yesterday evening? I would hate the thought that I would have to worry about each and every switching process. |
#33 |
Electric Hippy
Not to sure how these systems operate, but here is my theory.
Battery runs down, system turned off and the battery(NiMH?) bleeds some more. System is turned on and only has enough power for a momentary burst of operation, PRESTO! instant zguid. |
#34 | |
I wonder how they will reprogram it to its original exclusive code or will they just use a new one? They need to explain how it happened and why it won't happen again. This is not a small problem. Jim |
#35 | |||
Electric Hippy
sets can be made faulty, every set is faulty.Quote:
#36 |
I'm not here to bash, I have some valid questions.
As a CD, one of the main reasons for guys switching to 2.4 is so that they do not have to radio impound at events. My question is with #2 and #3. Right now you are saying there could be a problem if these 2 conditions happen. What you are not saying is what the problem is or even might be. So for the average flyer I cannot protect them from their own radio failing or interference outside of my control from bringing their airplane down. What I can control is freq conflicts so that one pilot does not inadvertantly (or on purpose) "shoot" another pilot down. Since not every FASST owner will read this forum, your website or any other online forum I have to assume that FASST systems (models mentioned here) will have freq conflict. Since I will not have the equipment to test who has a Zguid and who doesn't I have to assume they all do. Even if I checked them prior to the contest you are now saying that with #2 and #3 there could be a problem..... My questions...... Is that problem radio specific (i.e radio loses programming modes etc)? Is that problem the possiblity that it may Zguid and effect another user on Zguid? Futaba is unsure of what exactly will happen during these #2 and #3? Just to be fair......XPS/Spektrum have their own issues with planes falling out of the sky but they affect only the pilots plane. Not someone else flying. Fast cycle of the 14/12mz's ........ what happens here? -data lost? -do freqs reset? Any cause for concern to someone else's plane on 72mhz? Last edited by sweetpea; Jan 17, 2008 at 05:47 PM. |
#37 |
When the test stations are setup will their be a decal or some other document given to state that our TX's don't have ZGUID?
#38 |
The 12 and 14 series of radios already make it clear that the system must be fully booted up, or shut down before the power switch is cycled. If you change the switch position during either of those times you risk the TX locking up and requiring you to do a hard reset.
This is irrespective of what type of module is plugged into the TX. |
#39 | |
I have to admit I'm not 100% fluent on the 14/12 (I'm slowly trying to though). What does a hard reset reqiure and is it obvious to the user? I know you have to tell the transmitter to transmit after power on. If there was a hard reset does it reset the freq to something other than last used? |
#40 |
I am happy to see Futaba stating that there is a problem, but I agree that they haven't gone far enough. This "Switch" issue is still unresolved in my mind. That my code can be reset anytime/sometime in the future is ridiculous.
Krysta please resond. PEACE |
#41 | |
other than what you tell them to do, do they. Since this fault lies in the Rf module (whether integrated or not), there may still exist some power on/off sequence that'll cause it to fail, in all radios. If it's possible, it'll happen to someone. Until Futaba actually is able to reliably reproduce the failure, and understand exactly what component or software problem causes it, I certainly wouldn't trust any statement that says "these units are not affected". And my hypothesis for the run Tx battery to death problem (if it exists, and the evidence suggests that it does), is probably because as it gets into the brownout phase, the Tx is actually turning itself off and back on again randomly. (voltage drops.. ICs turn themselves off,.. once off voltage rises, they turn themselves back on.. increased current drop, lowers voltage again.. rinse, repeat). And it's not something you can reproduce on the bench by lowering the voltage with a regulated power supply because you won't get the same up and down behavior of both voltage and current as you do with a battery. ian |
#42 | |||
SweetPea:
From the 14MZ manual: Quote:
If this turns out to be a necessary precaution for the 6EX, I can't see how it is a big deal MANY electronic devices have similar precautions. |
#43 | |
#44 | |
#45 |
DS JUNKY
I think the large response of many users on multiple forums should make it obvious to Futaba how upsetting the situation is and how they need to take care of "us" and make it right. Futaba if you are reading this make sure you treat us right otherwise every upset user will tell 20 of their flyer buddies and pretty soon the Futaba name will be dragged right through the mud.
| Thread Tools | |
| Article Futaba's 7C Radio System Comparison and Review | AMCross | Radios | 46 | Oct 02, 2007 06:51 PM |
| For Sale MileHighWings USB interface cable for Futaba 6EX, 7C, 9C | nirenkinikar | Aircraft - General - Miscellaneous (FS/W) | 3 | Aug 12, 2006 08:18 AM |
| Futaba 6EX Supper comparison? | PrasadL | Radios | 3 | Jul 07, 2005 11:00 PM |
| Help with ESC and Futaba 6EX-A receiver. (FP-R127DF) | The Enemy | Power Systems | 6 | Mar 24, 2005 02:23 AM |
| Futaba 7C Service Advisory | HUNT | Radios | 1 | Nov 06, 2004 11:47 PM |
