Go Back   RC Groups > Aircraft - General > Radios
Closed Thread Post New Thread  Previous Thread Next Thread
This thread is privately moderated by krysta, who may elect to delete unwanted replies.
Old Jan 17, 2008, 11:05 AM   #16
Please note, that I edited my posting. In no way would I personally blame any user.
Krysta
Originally Posted by bjpaul
"forced" how disingenuous..... Looks like this is going to be "blame the user" and deny, deny, deny.
krysta is offline Find More Posts by krysta
Old Jan 17, 2008, 11:11 AM   #17
DS JUNKY
Z06kal's Avatar
Krysta do you know if this problem occured in the manufacturing process when the units were originally encoded or if this occurs do to an unstable situation (premature shutdown during boot, low voltage condition etc) where the code becomes lost. Or Both? Also do you know if the effected transmitters will control a fresh unprogrammed receiver so that we have something to test our units against? Basically any information you know for sure would be very useful.
Z06kal is offline Find More Posts by Z06kal
Old Jan 17, 2008, 11:31 AM   #18
There is no confirmation that low voltage can cause this error, the factory is still checking this, but at this time, they cannot confirm this. The problem of the zero encoding was in the manufacturing. You can test this only if a receiver is set to zero, which none were. This cannot be done unless you have a special receiver.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Old Jan 17, 2008, 11:38 AM   #19
Thank you for the prompt and responsible response to this issue.
abeille is offline Find More Posts by abeille
Old Jan 17, 2008, 12:35 PM   #20
Silent-AV8R's Avatar
It is clear that this is not a systemic design flaw since there are literally thousands and thousands of these systems out there and they were first sold over a year ago. Logically it appears that something happened recently to cause this situation. Futaba and its retailers and service centers are working to resolve the issue and are being proactive and transparent in their efforts.
What more do we expect??
Silent-AV8R is online now Find More Posts by Silent-AV8R
Old Jan 17, 2008, 12:38 PM   #21
Daemon's Avatar
Futaba's response is totally unsatisfying.
If the Tx resetting to ZGUID problem can be made to happen on purpose (as
some people have now proven) then it can happen accidentally (as it appears it
has happened to Julez and others). That means it could affect anyone at any
time. It could happen to two people at a large event while they're setting
up new models and they'd never know it, until they shoot each other down.
It's probably already affected more people than we know of, who just
haven't flown with other ZGUID Txs yet.
ian
Daemon is offline Find More Posts by Daemon
Old Jan 17, 2008, 12:40 PM   #22
Daemon's Avatar
Given the warning to be careful turning the Tx on and Off, it's clear that
it *can* happen to Tx's in the field, and is not isolated to a few units
from the factory. We already know that the GUID has been reset in the
field by 2 or 3 people, Julez being one of them. There are undoubtedly others
that we don't know about yet.
ian
Old Jan 17, 2008, 01:15 PM   #23
Silent-AV8R is correct. They are being proactive and transparent. Being a guy that makes 2.4GHz radios for a living, I know how difficult it is to nail these issues down. They are doing what is professional and prudent at this time. They've given us a Service Bulletin which we can use. I'm sure the engineers in Japan are not done with this yet. But in the meantime, we can move on. They've been able to recreate the problem, they have a temporary corrective action plan for us, and we can check to see if it is happening. Keep in mind that the only failure scenario requires multiple (more than one) operators have systems in use simultaneously which have had their ID wiped out. It seems that if you are concerned there are ways to check. If you follow their guidelines then it shouldn't happen to you.
Futaba has established a good track record with this so far and this current issue is their only flaw to date. Now, I'm sure folks don't want to hear this, but as a developer I would be ecstatic if I only had a single issue crop up when making a release of a completely new system.
shannah is online now Find More Posts by shannah
Old Jan 17, 2008, 01:49 PM   #24
Ian,
We have performed literally hundreds of hours of testing on the Futaba FASST systems since this issue was reported to us. Thus far, we have NOT been able to negate the identification code in any of the transmitters that we have tested.
To be safe, however, we have inspected 100% of our inventory. All Futaba 6EX and 7C FASST transmitters, and TM-7 FASST transmitter modules shipped from our distribution center beginning Monday, January 14 and after, have been checked to insure that they do not contain the incorrectly coded identification.
Additionally, it is important to note that the TM-14 modules and transmitters with those modules are not affected.
Sincerely,
Krysta
ian
Old Jan 17, 2008, 02:06 PM   #25
It must be a glitch
bjpaul's Avatar
Originally Posted by krysta
Ian,
Sincerely,
Krysta
This is from Ripmax in the U.K.
1) On the 6 EX, it was discovered that if you turned the tx on and then turned it off 0.5 second later (+-20ms) the GUID could be reset to zero. It is THAT critical, is has to be exactly that 40ms window on the 0.5 second mark. It would seem that it is very unlikely to happen in the field although it is possible. What seems to have happened is that at some point in the auto testing of the TX units after they have been programmed with the GUID, there are power cycles in the test. This power cycle was close to the time window, as such it could (on occasion) wipe the pre-programmed GUID. Futaba have changed this to prevent it happening again.
2) The same applies to the 7 C 2,4 and the 7 Module but the time is 2 seconds (+-20ms).
Your earlier comments seem to be evasive on this possibility which is documented in England.
If this is not a possibility then why the don't turn on/off in less then 5 seconds advisory?
Brad
bjpaul is online now Find More Posts by bjpaul
Old Jan 17, 2008, 02:29 PM   #26
Mamba Powered!
TheSteve's Avatar
Send a message via MSN to TheSteve
Clearly a flaw in the hardware design and something Futaba should fix for all users so it won't happen no matter what speed the radio may be turned on/off at.
btw, I've been a huge Futaba fan for more then 20 years - I hope they make this right.
TheSteve is offline Find More Posts by TheSteve
Old Jan 17, 2008, 02:34 PM   #27
Gold Member
Jurgen Heilig's Avatar
Well, a FASST transmitter loses its ID only under very specific conditions. It does not happen very often and obviously it never happened during the initial tests (hopefully). Despite thousands of systems sold, usually there still aren't that many at the fields. You also won't see a problem until you have two "ZGUID" systems running at the same field at the same time.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 17, 2008, 03:32 PM   #28
Gold Member
Brad
Where did you see the Ripmax info about the critical times?
Jürgen
Old Jan 17, 2008, 03:56 PM   #29
Mamba Powered!
TheSteve's Avatar
Krysta - can you confirm if a power cycle at the wrong time will also wipe the GUID from a FASST 3 channel ground model? They appear to be more or less the same as the modules used in the 6EX etc but are programmed for ground use.
I know several people with these modules, they often perform a quick power cycle of the transmitter to verify failsafe is set before a race.
Old Jan 17, 2008, 04:45 PM   #30
Hi Steve,
Due to the car systems having different data packets, you will not have any problems with them.
Sincerely,
Krysta
Article Futaba's 7C Radio System Comparison and Review AMCross Radios 46 Oct 02, 2007 06:51 PM
For Sale MileHighWings USB interface cable for Futaba 6EX, 7C, 9C nirenkinikar Aircraft - General - Miscellaneous (FS/W) 3 Aug 12, 2006 08:18 AM
Futaba 6EX Supper comparison? PrasadL Radios 3 Jul 07, 2005 11:00 PM
Help with ESC and Futaba 6EX-A receiver. (FP-R127DF) The Enemy Power Systems 6 Mar 24, 2005 02:23 AM
Futaba 7C Service Advisory HUNT Radios 1 Nov 06, 2004 11:47 PM
Bored? Want to fight?
Join the RCGroups clan!
