Espritmodel.com Heli Air
Old Jan 17, 2008, 06:09 AM
Bernoulli took a break
morpheusdream's Avatar
Singapore
Joined Sep 2007
Help please - how to find info about this motor?
Hi, i bought this motor (Brand = REVOX) recently for my slow stick, it works well so far, but i was wondering if anyone knew any more about it? Or where /who manufactures it so i can get proper information to use motorcalc with..
So far nothing much came up in a search in this forum.. neither in google.. all i get is about the Revox Tape Deck machines..
here's all i could find out about it:
No. Of cells : 3 Li-Poly
RPM/V : 1000KV
Operating Current: 6A ~ 18A
Peak Current: 18A (15 secs)
Suggested prop: 10x4.7, 10x6.0, 11x4.7
Lipo Battery: 1700~2200mAh 3S1P
Weight: 71g
Dimensions: 27.6 x 36mm
Shaft Size: 3.175mm
and a pic..
thanks in advance!
morpheusdream is offline Find More Posts by morpheusdream
Old Jan 17, 2008, 10:29 AM
O. C. CA
Joined Jan 2005
It look like you have all the information you should need on this motor, what else are you looking for?
Himeros
himeros is offline Find More Posts by himeros
Old Jan 17, 2008, 11:31 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
What you need to do is run it no-load and measure Io and rpm at say 7v, 8v, 10v.
Then run it with a couple of different props and measure voltage/amp draw/rpm.
Armed with this information you can use one of the calculators (Peak Effic., Drive Calc etc) and they will calculate Rm and Kv for you.
THAT is what you need to put the motor into the Motocalc database.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 17, 2008, 01:37 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Apart from the label and bell color, it appears to be identical to the Turnigy 2217-16.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Jan 18, 2008, 03:09 AM
Singapore
Joined Sep 2007
Thanks much Dr Kiwi! Will do that, was also hoping to find out a max watt handling capability, but i just read somewhere that all you need to do is multiply the max amps to the recommended voltage (in this case 3S*18 Amps = 199.8 Watts). But that's what i was looking for.. the Rm and Io.
Thanks for the info Bruce... i'll go check it out!
cheers
mike!
Old Jan 18, 2008, 03:12 AM
Singapore
Joined Sep 2007
Bruce - just checked... yes... you're right..it is almost identical.. except the REVOX is 1000 Kv.. cheers!
Old Jan 18, 2008, 07:04 PM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
post 73.
http://www.rcgroups.com/forums/showt...=751254&page=5
manuel v is offline Find More Posts by manuel v
Old Jan 18, 2008, 07:24 PM
Dr Kiwi's Avatar
Joined May 2003
Correction... the REVOX is "said to be 1000Kv".
The Turnigy is "said to be 1050Kv", but it has been calculated at 1111Kv and 1145Kv.. so who knows what your REVOX actually is.
Old Jan 19, 2008, 08:43 PM
Singapore
Joined Sep 2007
K... I hear what you're saying... manufacturer's claims vs reality...
Old Jan 19, 2008, 08:50 PM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
More like magnet quality spread batch to batch.
Discussion Anybody have any data/info about this motor? hhamzeh Foamies (Kits) 5 Dec 20, 2007 06:48 PM
Rave How did you find out about this insane hobby? Spencer J Parkflyers 31 Oct 07, 2004 07:06 AM
Question How about this motor for your EDF ScienceGuy Electric Ducted Fan Jet Talk 9 Jun 27, 2004 01:52 PM
Help please, How do I fix this fuse?? RandyK1 Electric Plane Talk 2 May 11, 2003 03:10 PM
Help! need information about this motor Dave Lindsey Electric Plane Talk 0 Jun 07, 2002 11:14 PM
