Old Jan 16, 2008, 11:51 PM
CuStOm is offline
Find More Posts by CuStOm
I steer with my thumbs
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
DonsRC KA20-22L technical "review"
*****TEST RE-DONE*****
(In my haste and late night excitement of playing with a new toy a left the motor poles at 12 whereas this motor has 14.)
I purchased one of these KA20-22L "Hacker Clones" from DonsRC here on the forums (Great guy to deal with). I was unable to really find any technical information for the motor so I figured I would share my findings. Don was having a great sale and for $34 with a Pentium18 ESC I just could not pass it up for a home made foamy project I have.
I "think" this motor is the same as the United Hobbies variant and is actually made by Danlions marketed under the Pulso name. The motor came with no markings to indicate actual manufacturer.
The motor is very very smooth seems very well made. On with the data.....
Flightpower EvoLite 1345mA 3S Lipo (Full Charge)
HobbyWing Pentium 18A ESC
GWS 10x6 HD
Using the Go Brushless thrust calculator, this yields an estimated Thrust at 200' ASL of 775.11 grams or 27.36 ounces.
Cheers,
Keith
CuStOm is offline Find More Posts by CuStOm
Old Jan 17, 2008, 01:13 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Mr. custom.
Im sorry but I dont believe.
8680rpm is very much. 154watt out. with only 135 watts in.
maybe one problem with reading tests.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Jan 17, 2008, 01:24 AM
CuStOm is offline
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
We'll I am pretty new at this so please educate me. I've only had my Eagle V3 data logger for a couple weeks but its not exactly rocket science. Do you think that the RPM sensor is reading an inaccurate number? I know the current is accurate as I also conducted the test with my Fluke before I had the Eagle Tree.
How did you derrive at 154 watts out?
Thanks for the insight and assistance.
Cheers,
Keith
Old Jan 17, 2008, 02:00 AM
CuStOm is offline
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
I re-checked my setup in the software and I accidently left the poles at 12, whereas this motor has 14. This explains the higher RPM reading than actual.
Thanks for pointing that out!
Cheers,
Keith
Old Jan 17, 2008, 01:27 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Custom.
Im using Drive calculator. (free program ) Simple propel calc option.
Manuel V.
Old Jan 17, 2008, 01:36 PM
CuStOm is offline
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
Do the new numbers look more accurate??
Old Jan 17, 2008, 04:59 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I put your numbers into www.badcock.net and it came out at ~70% efficiency which sounds about right. I didn't save the file but I can do it again later if you want the link.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 17, 2008, 05:46 PM
CuStOm is offline
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
Thanks for the heads up on that Dr Kiwi.
I haven't had time to look at your spreadsheet this week, I have been fighting a cold and catching up at work. I'll get to it soon though!
Cheers,
Keith
Old Jan 17, 2008, 09:50 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
I have four of these now (the UH offering) and am very pleased with them. My numbers look about the same as yours except for the most recent one I received. The new one must have a higher kV because it pulls 15.3A with a 1060HD. My others can swing a 1170HD or 11x4.7SF for just over 16A. The new one pushes 20A to swing those props--too much for this motor I think even in short bursts.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Jan 17, 2008, 11:27 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Tuppertn.
Maybe you have the KDAA20-20L.
http://www.rcgroups.com/forums/showt...r+clone+20+20l
Manuel V.
Old Jan 17, 2008, 11:43 PM
CuStOm is offline
CuStOm's Avatar
Beaverton, OR
Joined Oct 2007
Here is the APC 10x5E data. I am surprised it did this much better than the GWS1060HD. I am used to seeing them a little closer.
Thrust at 200' asl is 927.67 grams or 32.75 ounces
Also here is a GWS EP-1147. Great thrust but I am not sure if this motor could handle extended WOT. Only time would tell. Does anyone know what the maximum safe RPM for this prop is?
Thrust at 200' asl is 1176.30 grams or 41.52 ounces
Old Jan 18, 2008, 07:28 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I'd suggest about 5000-5500rpm... an 11x8 is even worse (maybe only 4500-5000rpm), before it starts to flutter badly.
Old Jan 18, 2008, 08:01 AM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Originally Posted by manuel v
Tuppertn.
Manuel V.
Hmmm. I hadn't thought of that. It's supposed to be the 20-22L. That's what I ordered anyway, but there are no identifying markings on it. Hold on a second...
A quick comparo with one that I know to be an A20-22L shows them to be identical. I assume I'd be able to see a 2mm difference in case length.
EDIT: Nevermind. I just realized the "22" is for wire turns not case length. The 20-20L and 20-22L apparently have the same dimensions. Maybe UH did send the wrong motor.
kendall
Old Jan 18, 2008, 10:57 AM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
If they did, just throw an APC 10x3.8 on there and enjoy it.
Blessings, Terry
still4given is offline Find More Posts by still4given
Sold Pulso KA20-22L Brushless Outrunner hercdriver7777 Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2007 08:58 PM
