Old Jun 03, 2001, 07:47 PM
dmccoach is offline
Find More Posts by dmccoach
Kutztown, PA
Joined Feb 2001
Zagi Trim Question
Thread,
My ZAGI 400x tends to "balloon" with increasing speed (i.e. add power through the throttle and one needs to add additional down elevon to keep it level).
Any tips on this issue? CG placement? Engine thrust? They all do this!?
Thx
dmccoach is offline Find More Posts by dmccoach
Old Jun 03, 2001, 08:21 PM
mpj220 is offline
Find More Posts by mpj220
Joined Apr 2001
I found it hard to stop with a flying wing. I just add a little down trim when full throttle is applied. Hmmm... that means I add down trim for most of the flight until I approach for landing.
Balance a little forward does help though. I mounted the receiver back in my 400X and lengthened the battery tray forward so the battery can be moved closer towards the nose.
When I go to full throttle, I only need to give the trim about 3 clicks or level flight.
If anyone else knows better tips, please share.
Mark
mpj220 is offline Find More Posts by mpj220
Old Jun 03, 2001, 09:31 PM
barn buster 50 is offline
Find More Posts by barn buster 50
tyler, texas, united states
Joined Mar 2001
its just the nature of the beast!
you see,
more POWER = more SPEED = more LIFT, there for you will need more down
barn buster 50 is offline Find More Posts by barn buster 50
Old Jun 03, 2001, 10:29 PM
foambattery is offline
Find More Posts by foambattery
Tacoma,WA
Joined May 2001
Add a little down thrust to your motor with a small spacer under the front of your motor. I ended up using a piece of double sided foam tape. You'll have to play around with different thickness's, but thats what I used.
[This message has been edited by foambattery (edited 06-03-2001).]
foambattery is offline Find More Posts by foambattery
Zagi Prop Question rckid Foamies (Kits) 2 Aug 06, 2001 11:07 PM
ZAGI - Ailerons - Question cclap Beginner Training Area (Aircraft-Electric) 6 Jul 13, 2001 03:07 AM
NSP Falcon trim question shelby Electric Sailplanes 4 Jun 24, 2001 02:16 AM
Zagi 3C question Mighty Mik Foamies (Kits) 11 Jun 24, 2001 12:17 AM
Speed 400 - Zagi timing question vicman Power Systems 3 Jun 15, 2001 02:40 PM
