Old Jan 15, 2008, 10:27 AM
pcolla1 is offline
Find More Posts by pcolla1
Joined Aug 2003
The best slow flyer for first plane?
Hey guys, what would you recommend as a good slow flyer for a beginner.
I like the eflight, bi plane slow flyers, in the videos so far. but never flew one yet. I am used to the tiny parkzone micro's and havent had much like with larger full size parkzones. I like something I can see and fly close.
any suggestions?
thanks
pcolla1 is offline Find More Posts by pcolla1
Old Jan 15, 2008, 12:17 PM
RC Sumo is offline
Find More Posts by RC Sumo
RC Sumo's Avatar
United States, MD, Salisbury
Joined Apr 2004
I would do some searches in this forum for the GWS Slow Stick. One of the all time greatest electric slow flyers and fantastic 1st plane. My SS is currently being fitted for duty as a aerial photography plaform as well as being fitted with a bomb bay. The plane is simple but hugely capable. With different configurations you can have a really slow and docile trainer. Do some mods or change the wing and suddenly you have a faster plane that can do some rather impressive aerobatics. With the SS, you really are only limited by your imagination.
RC Sumo is offline Find More Posts by RC Sumo
Old Jan 15, 2008, 12:59 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Welcome to the Forum!
The Slow or Pico stick are good slow flyers for a beginner, IF! there flown at first in calm wind, in a huge field with NO trees, etc.. Butch
Butch777 is offline Find More Posts by Butch777
Old Jan 15, 2008, 03:51 PM
Block is offline
Find More Posts by Block
Syracuse, NY (USA)
Joined Dec 2004
GWS pico moth flies better than Slow Stick. Hated the way everything would slide around on the stick, the stick got bent easily even with wood inside it, plastic parts were fragile...yuk...and it is ugly.
Block is offline Find More Posts by Block
Old Jan 15, 2008, 07:54 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
New SS kits have a fiberglass tube fuselage and the slip on parts are very tight and don't slide. But I guess "ugly" is in the eye of the beholder. As I recall one of the first "stick" models back in the 80's was the "Ugly Stick." And the SS may seem ugly to some but very cute to others.
Rickochet is offline Find More Posts by Rickochet
Old Jan 15, 2008, 09:54 PM
Block is offline
Syracuse, NY (USA)
Joined Dec 2004
Yeah, I knew that and almost mentioned it. The pico moth flies nice with the stock motor and a cheap (small) 2 cell lipo.
Old Jan 15, 2008, 10:57 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Closed Account
Joined Dec 2005
slow stick, pico stick, mini-mag, easy-star ....
If you don't have a radio/receiver set yet you should look at the kits that come with the radio, motor, receiver, ESC.
While the slow stick will only cost you about 30 dollars, if you don't already have electronics, then you may be looking at a 200+ dollar investment.
Try to find a RTF, ready to fly kit that has it all, if you don't have electronics already.
All that being said ... take a look at this link ... here are some planes and setups that may interest you ....
http://epyaya.com/index.php?cPath=145_205_473
Lou is offline Find More Posts by Lou
Old Jan 16, 2008, 04:59 PM
gabrielh is offline
Find More Posts by gabrielh
gabrielh's Avatar
Pensacola, FL, USA
Joined Jan 2007
My 1st one was the GWS Beaver.Awesome plane.
gabrielh is offline Find More Posts by gabrielh
Old Jan 16, 2008, 06:09 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
I have the Beaver as well. The wing is the same as the Pico stick! I have several extra Pico stick wings and ordered a couple Beaver wings, only to find out they were the same, with exception of not being notched for the bamboo sticks front and back.
Old Jan 16, 2008, 10:17 PM
Zerts is offline
Find More Posts by Zerts
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
The Multiplex MiniMag isn't even recommended as a beginner plane by Multiplex. I am having good success with the Multiplex Easystar. Also, a lot of newbies at the park are starting out with HobbyZone SuperCubs. They appear to take collisions with terra firma very well, and usually just need a new prop as the only repair. If you don't want the RTF version with cheap xmtr, just buy the components separately...they are reasonable in price.
The smaller planes are more sensitive to wind, and the Supercub flies a bit faster than the SlowStick and is less prone to unexpected wing tip stalls.
Zerts is offline Find More Posts by Zerts
Old Jan 16, 2008, 10:44 PM
Lou is offline
Lou
Lou
Closed Account
Joined Dec 2005
Zerts ....
Actually, Multiplex does class this plane as suitable for a beginner if they have someone experienced to help them.
http://www.multiplex-rc.de/
select English/Products/Aircraft Models .. and then Mini-mag
This kit is VERY simple to build and can be built with or with out ailerons.
BPHobbies has the RTF Mini-Mag available for $195.
http://www.bphobbies.com/view.asp?id...5&pid=B2111392
A person could start out with the Mini-mag w/o ailerons enabled and after a short time they can cut the ailerons in and begin their aileron training.
I would have no trouble suggesting this as an option for a beginner.
Old Jan 16, 2008, 11:04 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
LouieB,
I was wondering about the relatively high wing loading and not much wing dihedral - do you think the M-M flies faster and less forgiving than the SuperCub?
I want to go from the EasyStar to something with landing gear to do ROG and touch and goes . I can handle broken props but don't want to get frustrated with a "beginner" craft that damages easily.
Old Jan 16, 2008, 11:13 PM
Lou is offline
Lou
Lou
Closed Account
Joined Dec 2005
I have not flown the SuperCub so I am uncertain about the comparison. On my Mini-Mag I have the brushless setup, Himax 2815-2000. The wheels were too small to ROG from our grass field so I put a slight larger Dubro wheel on the MM. If you have a hard and flat surface then the standard wheels will be fine.
I do a LOT of dead stick landings with this plane, it glides in real nice and smooth, especially in a no wind dead stick. I have also enabled spoilerons and flaperons. With spoilers I have brought to plane in and landed it in an area the was less than 5 feet in length. Of course, I may never be able to do that again!
The plane has behaved very well for me in winds up to 12 -14 mph which is a lot of wind. In that kind of wind you have to fly the plane all the time and you need a 3 cell lipo with a 6x4 prop. In average winds, the planes flies quite well with a 2cell lipo and a 7x5 prop. Average flight times for me, for either set up is between 12 and 18 minutes, depending on how 'hard' I fly.
I really like this plane and it has become my current all time favorite. I keep the throws cranked down and it does easy aerobatics and when I go full throw on the control surfaces the MM can do some REAL tight loops.
I you have time on the EasyStar or some similar, the MM would be a very easy plane to move into. I belive that you would be very please with the way it flies and its durability.
Old Jan 16, 2008, 11:36 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
Ya the M-M looks good, I saw it flown only once, but saw the Super Cub flown a lot by newbies at the park. I wasn't so impressed by the GWS E-Starter. Do you happen to know if the stock brushed 400 direct drive motor and tiny prop on the M-M is actually viable? So many stock motor setups seem underpowered...does it help to have to have plenty of power to prevent a crash? That is my experience with the EZ* because I didn't use the direct drive 400 that it came with, I put in a brushless per the recommendations in this forum. Now I have 3 brushed 400 motors and a brushed ESC lying around. I can always upgrade to a BL motor when I get to doing aerobatics.
Old Jan 17, 2008, 04:39 AM
Lee R. Wheeler is offline
Find More Posts by Lee R. Wheeler
Lee R. Wheeler's Avatar
United States, CA, Redlands
Joined Nov 2001
slow flyer
Hi! Try The Park Shark great flyer, easy to fly. http://www.foamtasticmodels.com/prod01.htm
http://www.rcgroups.com/forums/showt...ght=Park+shark
Late!
Lee R. Wheeler is offline Find More Posts by Lee R. Wheeler
GWS Slow Stick or Slow Stick-S for first plane? daisycutter Beginner Training Area (Aircraft-Electric) 19 May 12, 2003 11:29 AM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 10:52 PM
Ideal Slow Flyer for Beginner BDiamond Parkflyers 3 Jun 10, 2001 10:24 PM
===== WANT recommendations for first plane ===== Kolchak Beginner Training Area (Aircraft-Electric) 30 Jun 06, 2001 06:20 AM
Wattage Hawk for first plane. austin9000 Beginner Training Area (Aircraft-Electric) 3 May 16, 2001 06:19 AM
