Old Mar 25, 2010, 07:13 PM
millerhill is offline
Find More Posts by millerhill
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
I also am finishing up a 16" version of the Cirrus. What should I be using for a CG?
Steve
millerhill is offline Find More Posts by millerhill
Old Apr 07, 2010, 07:39 AM
jusos is offline
Find More Posts by jusos
Joined Apr 2007
Here is one more satisfied Cirrus builder!
I redrawn the plane with Alibre Design 3D CAD and cut parts by DIY CNC router.
More info here:
http://www.cnc4rc.com/forum/index.php?topic=7.0
jusos is offline Find More Posts by jusos
Old May 17, 2010, 12:35 PM
blackcaz is offline
Find More Posts by blackcaz
Joined Mar 2010
does anyone knows where is the cg placed? and do i need to widen the wing span for better perfomance ?
blackcaz is offline Find More Posts by blackcaz
Old May 18, 2010, 08:10 AM
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
I used the 1/3rd rule from leading edge and it flies fine.
Old May 18, 2010, 12:16 PM
blackcaz is offline
Joined Mar 2010
can u explain deeper ? newbie here =)
Old May 18, 2010, 12:22 PM
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
For most planes, the CG is 1/3 of the wing chord which is measured from the leading edge to the trailing edge at the fuse.
Old May 31, 2010, 09:41 PM
FRONTERA2 is offline
Find More Posts by FRONTERA2
Joined Aug 2008
plans please
FRONTERA2 is offline Find More Posts by FRONTERA2
Old Jun 01, 2010, 09:12 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Cirrus plans
Originally Posted by FRONTERA2 View Post
plans please
The plans are located in the first post of this thread!
aerolite
aerolite is offline Find More Posts by aerolite
Old Jun 01, 2010, 09:18 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
He is probably asking because that link doesn't work anymore.
MegaTesla is offline Find More Posts by MegaTesla
Old Jun 01, 2010, 10:48 AM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Cirrus pdf plans
My bad. how about this pdf. (see below)
Old Aug 11, 2011, 09:36 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Browsing around found the plans for this beauty of a plane and after reading the thread I made a go at building the micro 16" wingspan version. Using guts out of a UM sukhoi so not the greatest gearwise but it all looks like it is going to work. LOL My first scratch build so hopefully i'm not goofing it up too badly. Will post some pics after I finish it which should be this weekend.
*I know old thread, but what can ya do*
LOL
Aaeolien is offline Find More Posts by Aaeolien
Old Nov 12, 2012, 05:13 PM
stajerc is offline
Find More Posts by stajerc
Slovenija/Ormož
Joined Jan 2009
Hi thear. Becaus the winter is comming i had to make some plane to flying around the house...And last year i found the Cirrus on RCG...I say..that is something what i must have And there it is...my new Cirrus with funny colors. Snow is white i need to have some funny color
Ok, just one qustion...how did you made the conection betven wing and eleron. I made with tape, but is not so good... is thear some trick to made it?
Tnx for help.
Regards Samo
stajerc is offline Find More Posts by stajerc
Old Nov 12, 2012, 06:52 PM
Aaeolien is offline
3d addict
Joined May 2011
I found this thread a while ago talking bout hinges and hinge making.
http://www.rcgroups.com/forums/showthread.php?t=483062
Old Nov 24, 2012, 06:00 PM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Have a problem with the build. Printed and cut out all the patterns, transferred them to 3 mm depron, cut out the depron and when attempting to match the wing/elevator portion to the fuse/rudder portion I find out one is longer than the other.
Nose to rudder hinge = 29-1/2 " (75 cm)
Nose to elevator hinge = 27" (68.5cm)
Anyone got a correct measurement out there ?????
It is easiest to extend the section with the elevator.
12/1/12--Didn't get an answer so I sectioned in a piece in the fuse/elevator part. Looks good.
RonJ
RonJ is offline Find More Posts by RonJ
Old Nov 25, 2012, 04:50 PM
bossee is online now
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi Samo,
3M Blenderm surgical transparent tape (25 mm width) is the best hinge tape I have used so far. Last plane I used it for was my RT Sirius Eleven (see images below). The tape sticks very good on depron and is thin and flexeible as needed to be able to use it on both sides of control surfaces for seamless hinging. And throws can be almost 90 deg if one should want that with almost no restistance in the hinges. I just bought a box with 12 rolls now so I have on the shelves at home when needed.
There is also a nice thing with this tape that it is not so sticky to the surface it can not be removed if one slowly take it away - I have done some hinging and was not satisfied at first so I ripped of the tape from the model and made another try. I have not found any better tape then this, it is just as if it was made for our small depron and such planes.
The tape can be found in pharmacy/drugstore or You can also find it on ebay.
/Bo
bossee is online now Find More Posts by bossee
