Espritmodel.com Heli Air
Old Feb 09, 2009, 10:41 AM
"what ever just crash it"
luger007's Avatar
South Kingstown, RI
Joined Apr 2005
Aiden,
Thanks for the heads up! (now I know) I guess I'll try both methods out and find how clumsy I am with my F3P planes I planned on trying very light weight Spectra thread and small (.375" dia. x .014 thick) carbon disks to keep the thread from ripping the foam. I'm pretty sure what ever I use for an adhesive for the disks with will let go long before the Spectra or the disks break.
I’m going to try an Index 2.2, a Cirrus and a Bling Bling V3 with 9/64” hotwired foam sheet since I can't find "Climapor" anywhere, and my Depron stock is non-existant. I’ll put the sheets in an oven between two sheets of glass to remove any warps and give the foam a slight ‘skin’. In the past this has worked very well for 1mm foam sheet, so why not a little thicker.
I’ve seen a few planes that have ‘skeletonized’ airframes, done with a CNC router or by hand with a Dremal and a jig. Does anyone know what sort of weight savings this yields? I realize if you rout 10% of the plane away, you save 10%, but does anyone know what Depron or Climapor weighs either by square foot or square meter at 3mm thick? (lol, no I don’t even have 1 square foot left of Depron to weigh) I’d also be curious how much more fragile this ‘skeletonizing’ makes the aircraft since places will be ½ the thickness or less. My guess is it’s not worth the effort unless I somehow manage to make it to the F3P TOC (if there is such a thing) or just think it looks cool and fly well enough that it is not an issue.
Matt
luger007 is offline Find More Posts by luger007
Old Feb 09, 2009, 03:28 PM
TurboCinqy's Avatar
Tiel, The Netherlands
Joined Apr 2007
Here's a dutch guy who did this.
more in this topic (dutch)
http://www.modelbouwforum.nl/forums/...k-elipsia.html
Savings on his model elipsia: 43.57 before and 36.34 after = 7,2 gram with depron sheet.
TurboCinqy is offline Find More Posts by TurboCinqy
Old Feb 10, 2009, 02:37 AM
Do it for fun
Aio_1's Avatar
Kilkenny, Ireland
Joined May 2002
I used small pieces of plastic tube (control snake inners) to reinforce the anchor points when I used thread bracing. Each piece of tube was about 4mm diameter ands 3mm long. This was plenty to deal with flight loads but could still start tearing in a crash or rough handling. Your disks should do a better job spreading the load. Are you sure thin carbon disks won't cut through the spectra over time?
Tim Hart's guide to kevlar thread bracing for monoplanes is attached to the plan posting for my original Index design here. You may have seen this guide before but if not it's worth a look.
Depron weighs about 120 grams per square metre.
I think Extrupor is about 15% to 20% lighter but I'm not certain.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Feb 12, 2009, 09:11 AM
luger007's Avatar
South Kingstown, RI
Joined Apr 2005
Aio 1, I've seen the plastic tube used in a few places, but considering the stress the foam and thread will be subjected to, I figured the small carbon disks would distribute the load better. I'm not concerned about the Spectra thread being cut by the carbon for 2 reasons. 1. I plan to chamfer the hole with a tiny countersink while in the process of drilling the holds and while it is still in sheet form, and 2. because once the thread is glued into the foam/carbon disk, it shouldn't move or chafe at all. I could be totally off base since this will be my first scratch F3P build, but I'm going to give it a shot. (then I'll try the carbon rods)
Turbocingy, thanks for that link! After running it through Bablefish, I managed to glean quite a bit of useful info out of it. I don't remember who the person was, but it looked like they built a skeleton frame and covered it with Solite film. 107gr! Now that is a light plane! I also imagine the film covering added massive amounts of strength to the sub-structure it was 'laminated' to.
Slightly off topic, but does anyone make a light weight carbon prop for these planes? It seems to me that if everyone is trying to shave weight off their plane, the thick plastic prop would be a good place to start. Perhaps if everyone sent GWS or APC an e-mail or letter, they would build some F3P props out of carbon or just redesign the prop entirely to be lighter and made from a stronger material. I mean they are making props already, it is not a big stretch for them I had considered making a mold to build a few super light carbon props, but then again, I hardly have time to work on the projects I already have
Matt (who's always willing to learn)
Old Feb 12, 2009, 09:27 AM
Do it for fun
Aio_1's Avatar
Kilkenny, Ireland
Joined May 2002
Matt,
Wes-technik make suitable carbon props - they're mighty expensive though so try not to crash!
Aidan
Old Mar 10, 2009, 04:55 AM
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
I picked the Cirrus as my first 3D foamy
Hopefully I will finish it later this week.
I scaled it to 60cm wingspan. I'm going to use the HobbyCity 10gram motor.
MegaTesla is offline Find More Posts by MegaTesla
Old Mar 11, 2009, 01:06 PM
2.4g shaun's Avatar
United Kingdom, England, West York
Joined Aug 2008
Micro Cirrus
Thanks for designing a great looking plane.
I've just built this Micro Cirrus 16" span.
Weighs 26g excluding the battery. All constructed from 2mm Depron except the lower fus half which is 3mm. U/C and pushrods are 1mm x 0.5mm carbon tube, struts are 0.8mm carbon rod.
Radio is modified PZ board with TOKI for rudder, AP03 for motor and a 1g 3A esc.
I've got a choice of batteries all 1S, 100mAh, 180mAh and 240mAh.
I plan to test fly it at Rochdale this Sunday.
PS the plane coffin is 6mm Depron !!!
2.4g shaun is offline Find More Posts by 2.4g shaun
Old Mar 12, 2009, 03:44 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
Very nice Shaun! Be sure to post it in the "Micro and Indoor" forum as well.
Old Mar 15, 2009, 12:43 PM
2.4g shaun's Avatar
Joined Aug 2008
Micro Cirrus first flight Video
Flew great...rolls about 2 per sec only change was to prop...now a 4.5 X 3 gws...Extra thrust made a difference.
I have a short vid...
http://www.rcgroups.com/forums/showthread.php?t=1018147
Shaun
Old Jul 06, 2009, 02:56 PM
marco_ul's Avatar
Canada, QC, Montreal
Joined Jun 2006
Nice design!!!
I just downloaded the plans for this little baby. It's going to be my fist F3P plane. I can't wait to get it together. It'll be made out of stripped down foamcore (3.75mm thick) and powered by a cdrom motor.
Here's what I've done with the DFX file... it's much easier now to adjust to any thickness of material!
Marco
marco_ul is offline Find More Posts by marco_ul
Old Jul 12, 2009, 09:37 AM
Tulsa Oklahoma
Joined Nov 2008
I am building one. What kind of pushrods would you reccomend?
Cessna_Flyer is offline Find More Posts by Cessna_Flyer
Old Jul 12, 2009, 06:42 PM
marco_ul's Avatar
Joined Jun 2006
I was playing with my 3D cad software and noticed that the rudder has a very limited throw due to interference with the elevator. Why is it that way? Is it because you don't need to use the rudder that much? I would be tempter to modify the elevator to allow more throw...
Old Nov 19, 2009, 11:59 AM
texomalaser's Avatar
Joined Sep 2007
Heres my first Cirrus. Already am building another.....
texomalaser is offline Find More Posts by texomalaser
Old Dec 20, 2009, 10:45 AM
Joined Sep 2007
Ok.. i have finnaly flown it and it does really well. Slow and has a fast roll rate. No coupling. The airbrakes really make it slow... all out weight with battery is 5.5 ounces
Old Mar 25, 2010, 02:24 PM
Joined Feb 2010
Nice. What size prop? And 2mm foam?
pilotpie4 is offline Find More Posts by pilotpie4
