Old Feb 04, 2008, 02:17 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Man Troy,
I don't know if I want to let you around any of my planes at all!!!!!!!!
You may only get to sniff Lances Cirrus F3P planes!
Dennis
aerolite is offline Find More Posts by aerolite
Old Feb 04, 2008, 03:27 PM
phyxer is online now
Find More Posts by phyxer
USAF Retired
United States, AR, Batesville
Joined May 2007
Dennis,
I promise to clean up when I'm finished
Troy
phyxer is online now Find More Posts by phyxer
Old Feb 24, 2008, 09:46 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Cirrus photos
Cirrus photos from the Plainview, TX indoor fly-in. Plane flew well. We are doing a club build and have about seven members signed up to complete the Cirrus.
Old Apr 09, 2008, 03:56 PM
frodo_small is offline
Find More Posts by frodo_small
Joined Apr 2008
Cirrus 85%
hey all!
for a while now I'm looking to get myself a serious F3P ship. I had some successful designs weighing around 160g-200g. But the urge the get lighter never ceases. so I got myself a 9g motor, 6g ESC, 200mah 2 cells li-po, all economic equipment from hobbycity. servos are 2 bluearrow 2.5g for the tail feathers, and one HXT500 5g servo for the ailerons.
After a few attempts on my own designs, I've decided to try AnthonyF3P's Cirrus. (thanks Anthony!)
as I was aiming at about 80g flying weight, and the motor is not so strong, I've reduced the plans to 85% of the original size, aiming at a wingspan of 70cm.
I use 15 oz/cu.ft styrofoam I got at a construction supplies store. the styrofoam is then cut to 3mm~ plates, using a hot wire. The plates are fragile, and flexible. But it is much lighter than depron. With the correct manipulation of carbon fiber (actually I almost and didn't use CF at all, but only because I don't have it), and masking-tape (the brown type. it is light, and have a stronger adhesive), one can achieve a very strong, or in this case, strong enough result.
To stiff up the wing, as I didn't have a quality CF rods or tubes, I used a 26cm CF rod reinforcement in the center of the wing, and bracings.
In my previous models, when weight wasn't as important, cutting the foam to 6mm plates, and covering it all with brown masking-tape, the result is a non breakable, stiff, almost EPP like (only stiffer) plates.
In the pictures you can see all the foam parts weighing at only 16g. After assembly, with the motor and ESC it is only 50g.
I hope it will be finished by this Friday, so more pictures, maybe a video are to come up then.
frodo_small is offline Find More Posts by frodo_small
Old Apr 09, 2008, 10:07 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Club Build Cirrus F3P
Here is another Cirrus that came from our club build. This one is getting a Park 250 motor, and weighs around 4.2 oz. Should be a great flyer.
Old Aug 06, 2008, 04:09 AM
ATflyer is offline
Find More Posts by ATflyer
Joined Nov 2007
Hi!
Could anyone please post pdf plans for an 85% sized Cirrus?
I haven't got the possibility to reduce the plans myself or at least i don't know how..
Would be nice! thx!
ATflyer is offline Find More Posts by ATflyer
Old Aug 06, 2008, 01:45 PM
pappy35 is offline
Find More Posts by pappy35
United States, TN, Memphis
Joined Apr 2007
In the US, Kinkos can scan images up to 36" accross and scale them to anysize (up to 36" width of course) for about $.75 per sq. ft finished size after trimming.
pappy35 is offline Find More Posts by pappy35
Old Aug 07, 2008, 09:35 AM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
ATflyer, just take the regular plans to Kinkos, or Staples etc. and just tell them what you want the wingspan to be, and they will make it that size, regardless of what the plans actually show.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Aug 07, 2008, 10:06 AM
WreckRman2 is offline
Find More Posts by WreckRman2
WreckRman2's Avatar
United States, FL, Apopka
Joined Mar 2002
Seth
Not all Kinkos employee's are that smart!
WreckRman2 is offline Find More Posts by WreckRman2
Old Aug 07, 2008, 03:26 PM
dando is offline
Find More Posts by dando
Sofia, Bulgaria, East Europe
Joined Nov 2006
Originally Posted by ATflyer
Hi!
Would be nice! thx!
See if this quick work on the file will do the work.
dando is offline Find More Posts by dando
Old Aug 08, 2008, 11:43 AM
ATflyer is offline
Joined Nov 2007
Thanks a lot guys!
I'm from sweden though so i can't go to kinkos. but there must be such a place here as well!
aah! I just remembered that also need to tile the plans A4 ... would really appreciate if someone could do it for me or tell me how to do it!
Thanks anyway!
Old Aug 11, 2008, 05:05 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
test proposter.It tileprints
/Ulf
methuso is offline Find More Posts by methuso
Old Aug 11, 2008, 07:15 AM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
haha so true!
Old Aug 11, 2008, 01:07 PM
dando is offline
Joined Nov 2006
Thanks a lot guys!
Thanks anyway!
You should be fine with this one, just check if the wingspan is the needed one.
Old Aug 12, 2008, 08:28 AM
ATflyer is offline
Joined Nov 2007
The pdf seems great! thanks dando! I will post pictures of my cirrus build later!
/ATflyer
