Old Mar 08, 2008, 07:45 PM
Bob K is offline
Find More Posts by Bob K
San Diego
Joined Jan 2001
Happy programming in C ?
Uh, what's C ?
Just joking! No, I do not program with C, but, I have a
few friends that do ( and who owe me a favor )
But can you give me a guess-timate as to how much
time I would be asking for? I don't want to ask for too much.
Also, I have a different set of desires than you do as I
am only operating at a range of less than 2 meters.
But, if I loose control, I eat concrete or worse.
And 2 channels is all I need ( I would like a horn for fun! )
Anyways, here is a picture of the arm band transmitter
I cobbled up using an R/C car transmitter. The two finger
control device just uses the existing potentiometer from
the transmitter. It works very well and has been rock solid
as far as control goes. But, I have no way to control the
acceleration/braking rate and Let me tell you, when you are on that board and you hit the power a bit too hard,
it wants to spit you off the back! And if I hit the brake
just a wee bit too hard, it wants to spit me off the front!
So, that's why I want to "soften" up the control response.
I want it more like a gliding magic-carpet than a rowdy
low-geared, high compression, large displacement,
rip-snorter that it currently acts like!
Bob K
Bob K is offline Find More Posts by Bob K
Old Mar 09, 2008, 02:30 PM
Alan Hopper is offline
Find More Posts by Alan Hopper
UK
Joined Mar 2007
Bob, the work to put braking and acceleration limits on an already working system with these modules would be tiny. The application notes on the Jennic website do include two samples that could be easily modified to do this however I would not trust my teeth to them without some refinement. I shall publish my code soon, it is up to you to decide if it sufficiently teeth friendly . I'd point your friends at the Jennic website and get them to download the IDE/SDK. You've got me thinking about how I can usefully use this stuff on my electric bmx and reminded me of an old dream of mine to build a pair of electric shoes.
Alan
Alan Hopper is offline Find More Posts by Alan Hopper
Old Mar 09, 2008, 05:33 PM
Bob K is offline
San Diego
Joined Jan 2001
Thank you Alan,
I am off to study the Jennic site.
Bob K
Old Mar 10, 2008, 02:15 PM
crazifunguy is offline
Find More Posts by crazifunguy
Joined Feb 2006
So you have the 2 sticks controlling 4 channels? x and y axis on both sticks are working? I have stripped my controller and ordered a rx/tx.
crazifunguy is offline Find More Posts by crazifunguy
Old Mar 10, 2008, 02:42 PM
UK
Joined Mar 2007
crazifunguy, yep I'm reading and sending all 4axis, currently I have left the controller electronics intact and read the joysticks and switches in the same way the ps2 would through a spi port. This only gives 8 bit resolution on the joysticks, you could connect the pots directly to the analog inputs of the module to get 12 bit resolution. I might well do this but keep reading all the buttons through spi.
Alan
Old Mar 10, 2008, 05:23 PM
Joined Feb 2006
How are u getting all the extras transmitted? PWM?
Old Mar 18, 2008, 06:53 AM
UK
Joined Mar 2007
crazifunguy, all the channels are transmitted the same way, as serial data. The modulation and clever dsss stuff is all done for you by the modules, you just pass packets of data to it.
Can anyone recommend what value capacitors I should put across the receiver servo outputs? I cannot read the values off the receiver I have opened up!
Alan
Old Mar 21, 2008, 05:15 PM
kevingill is offline
Find More Posts by kevingill
kevingill's Avatar
Joined Dec 2004
Fantastic work Alan, you must have put in a load of hours - it is very much appreciated.
These Jennic modules look good value even without the Zigbee built in! I noticed that they are also for sale here:
http://www.sequoia.co.uk/eshop/browsedl.php?item=510
Is this the best module to buy? I guess that if I'm gonna play around with these things, I don't want to spend too much cash (save my money for some more lipos/beer). I'm used to progamming microcontrollers and PICs so these shouldn't be too difficult? (famous last words).
Also, is the downloadable free compiler OK? Are there any limits on the usage of the compiler?
kevingill is offline Find More Posts by kevingill
Old Mar 21, 2008, 10:13 PM
le fou is offline
Find More Posts by le fou
United States, OH, Cuyahoga Falls
Joined Apr 2006
Hello Alan Hopper,
I invested in XPS but I am going to sell it back for its lack of redundancy. I read your earlier post where you said that you implemented an hopping sequence to avoid interferences. I am interested in building a system for my radio and implement it in my planes. Do you think you will share your code and your PCB schema with other people? I don't have much experience in coding, I used VB a little. Can you recommend any reading that I can do to understand better how to put a project like that together?
Thank you,
Le fou
le fou is offline Find More Posts by le fou
Old Mar 22, 2008, 11:39 AM
UK
Joined Mar 2007
Kevingill, I picked these modules partly as they were the cheapest and partly as the processor seemed the most capable. My thoughts on other modules
xbee - proven by xps and a number of people on these forums - more expensive - bigger - all solutions seem to end up with an external processor
meshnetics - smallest and with good radio spec - more expensive - processor not as powerful - I may get one of these to see if it will interoperate with the jennic modules
Telegesis - similar in size to jennic - less powerful processor - more expensive - the ember em250 chip looks a good option for a micro rx
The free compiler and ide are not in anyway restricted and I have had no probs with them, there is a facility to do in circuit debugging over the serial port but I havenít tried it. There is no emulator which is a shame
Le fou, I shall share my code and pcb stuff. It is my first attempt at designing pcbs so I shall post them as soon as I have something in the hope of some constructive criticism!
I am working on a hybrid hopping scheme that I shall write up soon.
Alan Hopper
Old Mar 22, 2008, 03:08 PM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
Alan Hopper
Alan, I'm sorry, can't understand what you mean about ide and tools. What compliler and tools you are going to use?
Thank you,
Kostya
salat is offline Find More Posts by salat
Old Mar 22, 2008, 04:22 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
IDE:
Integrated Development Environment
Commonly text editor, compiler, linker, loader, simulator.
Think like AVRstudio for the AVR MCUs.
village_idiot is offline Find More Posts by village_idiot
Old Mar 24, 2008, 09:53 AM
UK
Joined Mar 2007
Salat,
I am using the free compiler and tools from jennic http://www.jennic.com/support/view_s...nID=0000000010 the tools include flash programming software that only needs a logic level serial connection to the modules. If anyone is looking at this stuff I recommend downloading every user guide, datasheet, reference manual, reference design and application note from the jennic site as info is rather spread around. The api details are spread over a number of reference manuals. This is also useful http://standards.ieee.org/getieee802....15.4-2006.pdf
I have been tweaking the servo output code and it is now clock perfect, so the only jitter is that due to the crystal. Still with upto 21 outputs.
Alan
Old Mar 28, 2008, 01:39 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Hi Alan
Great work you've done! Thank you very much for the inspiration and for the wealth of information. I have a few questions on the modules and their capabilities.
96KB RAM seems to be a lot but I'm wondering how much we have left for our application?
Do you use an external flash memory to store your code? or do you have to load it to the module every time it's powered up? It's kind of odd to see a micro controller with no flash nowadays.
Thanh
thanhTran is offline Find More Posts by thanhTran
Old Mar 28, 2008, 03:23 AM
UK
Joined Mar 2007
Thanh,
the modules incorporate a 128kbyte flash chip. At startup it automatically copies the program to ram. This happens very quickly, I think it only copies as much flash as there is program. The top 32k of flash can be used for whatever you like. You can connect external flash and have it load from that. The bin files for my current programs are about 11k so there seems to be plenty of space. There is a large on chip rom that I believe holds most of the api stuff so most of the ram is available(I think!).
Alan
Idea Spektrum DX6 DIY Transmitter antenna replacement using 2.4GHz Wireless network parts? jaskew Radios 18 Jun 17, 2009 12:28 PM
Discussion Sort of DIY 2.4Ghz Spectrum Analyzer village_idiot DIY Electronics 11 Feb 23, 2008 11:55 AM
Discussion DIY +12dBi, increase the range of your rubber ducky 2.4Ghz antenna dalbert02 Aerial Photography 1 Jan 01, 2006 11:58 AM
Antenna for 2.4GHz video transmitter Wile E Power Systems 7 Sep 25, 2001 04:42 PM
2.4Ghz xmit system for a small fortune jas_Qfix Electric Plane Talk 28 Jul 02, 2001 08:37 AM
