Letchworth, Great Britain (UK)
Joined Jul 2004
As gravitykills has mentioned, it could be a short-circuit in the motor windings which has caused it to draw more current than it should and, thus, burn out the windings and then overload the battery so that it too catches fire. But it could also be too big a propellor on the motor, or too many battery cells for that particular motor, both of which would cause it to draw more amps than it can stand and eventually burn itself up and then overload the battery. Did you check how many amps it was drawing at full throttle before you flew it? If you haven't got one already, a wattmeter (or an ammeter that can handle the expected amps) is a vital tool for anyone getting into the e-flight hobby. |
Thinking of it, wrong propeller sounds very plausible, with spectacular outcome... |
There are stories of ESCs having burst into flames, or just smoldered to a heap even on the tarmac, without the plane even in flight or the motor even turning! It happens. It's rare, less rare for some ESC's. I'm guessing the ESC glitched, turned on 2 or more phases at once continuously, overheated the motor windings but the ESC itself was really what went up in flames due to the hard short. Just out of curiousity and nothing more, can you list the - battery type and mfgr - ESC model and mfgr - motor type and mfgr? was this a brush motor? Dave |
San Jose Ca / RSA flyer
Joined May 2003
U'll be surprised what an overheated 20A brushed ESC can do if not vented, my PKZ P-51 ( no air cut-outs for cooling ) using Electtr-fly 20 amp started smoking, then crashed and burn, luckily I had half gallon of water with me at the time to douse the flames
on the other hand my PKZ FW 190 with cooling louver slits on the exhaust exits runs very COOL |
Joined Aug 2007
battery type: 3 cell 2500mah polyquest
Esc: Jeti eco 25 amp Motor: Atlas 2909/20 brushless I could not find the esc, as I said the plane was reduced to a heap of ashes. The esc was mounted behind hte battery and underneath the servos so it was in a small space. The reason i was thinking that the "battery may have discharged too quickly" was because when I was wrapping electrical tape (shrink wrap ripped) along the solder joints after soldering on the dean's connectors my scissors touched the two gold tips and started sparking. |
Slovakia
Joined Apr 2005
I had one of the two 30-amp ESCs on fire when taxiing my little catalina over the lake.
A lot of white smoke went out of it, cca 20 meters far from the ground, not far but not encouraging.. but remaining left side motor with second ESC were still working, and did bring the plane to the ground, out of the water. 3200mAh Lipos were OK, no harm at all, just the ESC turned into a pieces of black carbon, fallen inside the fuse. The drop of water inside ESC was most probably my reason why. |
Slovakia
Joined Apr 2005
Original ESC is not covered neither protected at all, there is just a shrink wrap with both ends wide open. Some brands are offering "W" versions of ESCs, protected against the water.
In water panes like Catalina, I always treat ESC and also all other parts where it doesnt hurt (receiver except servo connectors, electronics inside servos), using "Plastik 70", conform electronics protective coating lack. http://www.mdaelektronica.nl/nl/dept_8.html#item_21 But it probably dont last forever, especially when ESC permanently heats and cools, or perhaps it was not done perfect by myself (ESC shrink was not opened, it is possible that I forgot to even treat this one ESC). I have seen unprotected brushless esc burn in a flash after water wawe run thru propeller and just one small drop gets inside, passing by the wire. Dont try that. |
| Thread Tools | |
| Near-disaster with Ion at the slope | AntonL | High Performance | 26 | Sep 23, 2005 12:17 AM |
| Near Disaster | snowbirder | Aerial Photography | 17 | Jul 02, 2005 12:56 AM |
| Advantage of ZagNutz AP (a near disaster!) | CenTexFlyer | Aerial Photography | 16 | Jul 28, 2004 02:58 PM |
| Help! Tantrum near disaster!!! Razor/CC ?? | akeyzoo | 3D Flying | 3 | Oct 31, 2003 07:44 PM |
| near disaster logo 20 ESC burnout | nigel99 | Electric Heli Talk | 9 | Aug 02, 2001 04:12 PM |
