Espritmodel.com Heli Air
Old Jan 11, 2008, 05:44 PM
Joined Dec 2007
900 MHz or 2.4 GHz what is better
I was just wondering what is better as XPS announced 900 MHz system for US and Canada.
Uff-Da RC is offline Find More Posts by Uff-Da RC
Old Jan 11, 2008, 06:01 PM
User
Colorado
Neither, both have their pros and cons.
There is however a major con of 868MHz for places like Europe. Their regulations are extremely restrictive not only to power but also as far as available bandwidth and duty cycle is concerned. At least on 2.4GHz, they have the same 83.5Mhz available to them as the US. On the 900Mhz band, the US (and Oz and Canada I believe) can use from 902-928MHz, so 28MHz is available. In Europe, only about 1MHz is available.
rmteo is offline Find More Posts by rmteo
Old Jan 11, 2008, 06:14 PM
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
What he said, pros and cons for each. Unless you are doing video or need extreme range 2.4 is the best compromise due to the way ISM regulations are laid out. 900Mhz is better for range and if you are doing any type of 2.4 AP or something similar but other devices on 900Mhz are much higher power than what is allowed on 2.4.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Jan 11, 2008, 07:31 PM
Toronto Buttonvle, Canada
Joined Aug 2003
Aren't there 900 MHz analog phones all over the place? I would be a bit worried about it if it's not really FHSS.
gotak is offline Find More Posts by gotak
Old Jan 11, 2008, 07:36 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Apart from the regs and phone stuff , does not the 900Mhz have more range and less power requirements? but bigger antenna's. oh yer and heavier Rx's
olmod is offline Find More Posts by olmod
Old Jan 11, 2008, 07:45 PM
Joined Nov 2005
More range but smaller antennae. There are some really small 900 chipsets.
IPFlyer is offline Find More Posts by IPFlyer
Old Jan 11, 2008, 07:50 PM
User
Colorado
For a given transmitter output and receiver sensitivity (with antenna gain of both sides also included in the equation), yes 900MHz does give longer range. Or to put it another way, for a given range, you would need less power. All else being equal, path loss is directly proportional to frequency (actually wavelength). So you theoretically have 2.667 times (2400/900) more range with 900MHz.
But as always, nothing is for free, eg. 900MHz is more affected by atmospheric conditions, etc.
Wavelength of 900MHz is about 13 inches compared to about 4.9in. for 2.4Ghz (this accounts for the 1.25in. long 1/4 wave whip on the XBees), so yes, antennas will be longer. However, this is not necessarily a bad thing. Less tendency for a receiver antenna to be shadowed and may allow one to poke it out of a carbon fuze.
Old Jan 11, 2008, 07:55 PM
sweetpea's Avatar
Joined Apr 2007
Well since no one is currently flying R/C (maybe UAV but that is not R/C) on 900mhz........you can't compare yet.
900mhz will have its own issues just like 72mhz and 2.4 ghz have their own unique issues
sweetpea is offline Find More Posts by sweetpea
Old Jan 11, 2008, 08:09 PM
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Little tiny Plantraco receivers... Is 0.4 grams big enough?
village_idiot is offline Find More Posts by village_idiot
Old Jan 11, 2008, 08:10 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Lots of Plantraco indoor stuff on 900.
Pat MacKenzie
edit - typing at the same time a v_i
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 11, 2008, 09:03 PM
pyote,tx
Joined May 2007
dam that's some tiny snizle for 4 channels
3ddd is offline Find More Posts by 3ddd
Old Jan 11, 2008, 09:20 PM
sweetpea's Avatar
Joined Apr 2007
Pat MacKenzie
Indoor-short range vs 1-2 mile outdoor are 2 different beasts!
That would be like saying that 27mhz is fine because Tyco and Aerobirds use it on their planes. I would't trust 27mhz on anything but my R/C car that is only driven 100yds at most away
But I guess I have mispoken about no R/C on 900, for that I apologize
Old Jan 11, 2008, 09:22 PM
User
Colorado
Most of the RF chips, whether 413MHz, 900MHz or 2.4Ghz are less than 1/4in. square (in fact the vast majority are just 5x5mm) and come mostly in leadless QFN packages. This allows some really small tranceivers (with bi-directional communications) to be designed around them. They are used in applications such as those ubiquitous Bluetooth wireless headphones that people stick in their ears.
Plantraco has some of the smallest around. Spektrum also has some in 2g. range. The reason that the XPS 6-channel (and the smaller ones as well) are so much larger and heavier, is that they are based on the XBee modules which are designed for completely different applications where size and weight are not as critical. This is one of the comprises that I alluded to in the other thread. There are also several other disadvantages in going the module route as opposed to the chip route.
However, as tlh101 has pointed out, XPS is awaiting FCC approval so it seems that for the 900Mhz product line, they have gone the chip route. Receivers will probably be much smaller and lighter as a consequence (and a whole lot less expensive to produce).
Old Jan 11, 2008, 09:36 PM
User
Colorado
Purely a design choice on their part. Does not have any bearing on 900MHz, or the technology, or the RF chips that they use.
Remember, their systems are designed for airplanes where the wingspan is just inches with auw that in most cases is less than that of a micro servo. Longe range (>150ft or so) is not needed in this scenario.
With the addition of a PA to the front end, they COULD be used in full-range (1-2 mile) systems.
Old Jan 11, 2008, 09:38 PM
FICKLE FLYER
tlh101's Avatar
Corpus Christi, Texas, United States
Joined Dec 2002
Jim did say that part of the problem with the 900 system, was trying to get it small, and not consume large amounts of power. It's supposed to be stable down to 1.5V.
Hopefully they recorded the interview, and we will be able to see it again. It's hard to recall everything mentioned.
tlh101 is offline Find More Posts by tlh101
Question FM or 2.4 GHz jazi Radios 5 Oct 23, 2007 10:02 AM
Discussion 50 MHZ or 2.4..... GhostRider32 Radios 8 Dec 28, 2006 08:01 AM
Discussion 900 MHz vs 2.4 GHz ISM bands INewton DIY Electronics 2 Apr 22, 2006 03:50 PM
Video downlinks: 2.4 GHz or 900 MHz aragon Aerial Photography 4 Apr 22, 2005 04:26 AM
