Old Jan 11, 2008, 06:23 PM
JMPaccassi is offline
Find More Posts by JMPaccassi
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Build Log
Dornier Do335
Alright, not getting started on this till this weekend, but I thought I'd get the ball rolling with some details of the Do335 & a couple of pics of the real thing.
General characteristics
Crew: one, pilot
Length: 13.85 m (45 ft 5 in)
Wingspan: 13.8 m (45 ft 1 in)
Height: 4.55 m (15 ft)
Wing area: 55 m (592 ft)
Empty weight: 5,210 kg (11,484 lb)
Max takeoff weight: 8,590 kg (19,500 lb)
Powerplant: 2 Daimler-Benz DB 603A 12-cylinder engines
(1,726 hp, 1,287 kW) each
Performance
Maximum speed: 765 km/h (474 mph)
Combat radius: 1,160 km (721 mi (half load))
Service ceiling: 11,400 m (37,400 ft)
Armament
1 30 mm MK 103 cannon
2 20 mm MG 151 cannons
Up to 1000 kg (2,200 lb) bombload
Only one Do 335 survives today. The aircraft was the second preproduction Do 335 A-0, designated A-02, with construction number (Werknummer) 240102, and factory radio code registration, or Stammkennzeichen, of VG+PH. The aircraft was assembled at Dornier's plant in Oberpfaffenhofen (southern Germany) on April 16, 1945. It was captured by allied forces at the plant on April 22, 1945. The aircraft was test flown from a grass runway at Oberwiesenfeld, near Munich, to Cherbourg, France while escorted by two P-51's. The Do 335 was easily able to out distance the escorting Mustangs and arrived at Cherbourg 45 minutes before the P-51's. VG+PH was one of two Do 335's to be shipped to the United States aboard the Royal Navy ship HMS Reaper, along with other captured German aircraft, to be used for testing and evaluation under a USAAF program called "Operation Sea Horse." One Do 335, with registration FE-1012, went to the USAAF and was tested in early 1946 at Freeman Field, Indiana. Its fate is a mystery.
JMPaccassi is offline Find More Posts by JMPaccassi
Old Jan 11, 2008, 06:48 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Crew: one, pilot
Performance
Armament
JP... This is going to be a great project. I can't wait to see it. I think you are supposed to add it to your hanger which is post #16 (your original post)over in the multi-engine contest thread. At least that is my understanding... Congrats again on a great choice. Bob
Foamenator is offline Find More Posts by Foamenator
Old Jan 13, 2008, 08:41 AM
Frank_K is offline
Find More Posts by Frank_K
Frank_K's Avatar
Antwerp, Belgium
Joined Sep 2004
Signing on.
This is my favorite WW2 plane ever!
I had started a design of my own, but then a new job came between me and modelling
good luck !
Frank
Frank_K is offline Find More Posts by Frank_K
Old Jan 13, 2008, 01:17 PM
JelleB is offline
Find More Posts by JelleB
Time for another motto!
Utrecht, The Netherlands
Joined Jul 2006
Ah, you wanted a safe bet? Last year Pfeil II won the foamies contest, so this time you are going for pfeil I?
JelleB is offline Find More Posts by JelleB
Old Jan 13, 2008, 07:44 PM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Fomenator, Frank, JelleB,
Thanks for the encouragement, I hope I can do this bird some justice. Pfeil I & II? I'll have to do some searching now & check out last years competitions, I can't remember that far back
Old Jan 13, 2008, 08:10 PM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Electronics
Specs of my build-
WS 40"
Length 36" (not including spinners)
Target AUW 25 oz.
Projected Wing Area 310 sq. in.
Electronics-
TP2100 3S
Suppo 2212-13 x 2 \max amps each (12)
9 x 5 or 10 x 6 \3 blade props (whichever looks best scale wise)
Suppo 20amp ESC x 2
Tower Pro 5g servo x 2 \ailerons
Tower Pro 9g servo x 2 \rudder & elevator
Micro 05s receiver
I've got everything I need except the 2 motors & 1 ESC, but will order those up tomorrow.
With any luck I'll be able to get started tonight, and post progress soon!
JP
Old Jan 14, 2008, 10:58 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
In the not too long distant past People have Built SCALE (as in full Fuselage/wings in Balsa) Do 335's in that same 1:12 size...using twin S400's and Nicad batteries achieving V similar weights. Surely yours could be in the 12 oz range ?
Bare is offline Find More Posts by Bare
Old Jan 15, 2008, 10:16 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Weight
Bare,
I would definately like to come in lighter than 25oz's , but just adding up the gear I mentioned in post 6 without the props comes out to 11oz. I will also be doing a full fuse & built up wings, but I will be using Elmers foam board. The built up wings is where I am going to have the most trouble & since I only have elmers foam to wrk with they may a little thick(1.75in) I'll have to look around locally & see if I can come up with some thinner foam to skin the wings with.
JP
Old Jan 15, 2008, 10:24 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Wings
I decided to go with the eppler 374 airfoil for my wings just because I was able to find a pic online that I could save & print out easily & it was close to what I wanted as far as properties go. So far I 've just got the ribs for one wing cut out, I still need to cut the spar holes & then on to forming the wing by rolling it to the basic airfoil shape before gluing. I am going to start out just doing one wing to see if I like the results before moving on. Should have one done tonight........
JP
Old Jan 15, 2008, 10:25 AM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Oh Yeah! I'm subscribed to this one this is going to be great!
---pass me the popcorn!
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Old Jan 15, 2008, 04:23 PM
Do 335 is offline
Find More Posts by Do 335
Do 335's Avatar
Erlangen, Germany
Joined Jul 2001
Great plane. I always wanted a small one, so I started today to build myself an 1:21 high altitude version:
Wingspan 83 cm / 33''
Length 64 cm / 25,5 ''
Weight fuselage + wing (unfinished) 80 gr / 2,8 oz
Equipment: 85 gr / 2,9 oz
GWS Indoor motor, GWS RX, LiPo 2s, 350 mA, 5 gr servos
Martin
Do 335 is offline Find More Posts by Do 335
Old Jan 16, 2008, 11:42 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Do 335,
Looks good, please keep us posted on your progress. I hope I can get my fuse looking that good, but till then I am concentrating on getting my wings built, then everything else will fall into place, hopefully .
Looking at the 3 view again last night It looks like my wing root thickness is almost perfect @ 1.75" for a 40"wing, don't know how that happened! (lucky I guess). As with most things I build, I end up engineering as I go along, kinda backwards I know, but seems to work for me most of the time.
Also, from what I can tell using the 3 view I have, I will need about 3 degrees of dihedral, and will also have to angle my root rib so that when butted up against the other root rib of the other wing they will be flush at the correct dihdrl angle.
Unfortunately no progress last night as I had my son & I can't seem to get anything done when I have him, he's 2 years old & very demanding, kids these days, I tell ya See pic-try keeping this guy away from your build table, need to build a fence around the perimeter, but that probably wouldn't be enough either
JP
Old Jan 16, 2008, 01:10 PM
Do 335 is offline
Do 335's Avatar
Erlangen, Germany
Joined Jul 2001
Hi JP,
my two ladies (the younger one is 6 month old) visited my parents in law yesterday, so I had the time for building...
I'm not sure about the original dihedral.
The angle to the fuselage is quite high (see pic).
At the original plane the elevator angle could be changed +- 5
(at 2,3,5,6).
I would prefer max. 2 dihedral from a fighter plane, but I'm not sure, so are there any experts around?
Martin
Old Jan 16, 2008, 03:48 PM
Bare is offline
Canada
Joined Nov 2000
Dunno Mate you've picked some Heavy Bits there. Why the Huge Props or the 2100mah batts AND the 2.. 20 amp esc's Unecessary overkill imo. Identically wound outrunners work "fine' on 1 esc.
Foam (gasp! ) may not be the errr.. Lightest Choice..
as contest Balsa IS usually much lighter :-)
Although Have you checked out this Kid's Blog
http://www.rcgroups.com/forums/attac...mentid=1654732
Exquisite craftsmanship.. MUCH.. to learn there Study it all V carefully
I would be hard pressed equal his product and I've been 'doing this' for 40 years.
G'luck
Old Jan 17, 2008, 11:14 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Hi Bare,
Yeah, I could probably shave 1/2-3/4 oz by using smaller ESC's, but I like to have overhead & they were cheap My ESC's & my motors cost the same- $16 each, from lightflightrc. Oh yeah, the reason for the big props, I like thrust
JP
Contest 2008 Multi-Motor Contest Rusty-Gunn Foamies (Scratchbuilt) 98 Mar 20, 2008 12:23 PM
Foamie Contest Entry Number I Don Sims Foamies (Kits) 13 Jul 31, 2003 02:03 PM
ESWC LMR contest entry update Dave Wenzlick / Slickraft Electric Sailplanes 0 Aug 16, 2002 11:40 AM
EDF contest entry Arngeir Blakseth Electric Ducted Fan Jet Talk 24 Apr 07, 2002 11:42 AM
Foamie Contest Entry? Allan Wright Foamies (Kits) 29 Oct 22, 2001 10:27 PM
