Old Jan 11, 2008, 03:53 AM
GhostRider32 is offline
Find More Posts by GhostRider32
Joined Dec 2006
OS .91 4 stroke valve adjustment
How hard is it and what do I need? Is there a kit available?
GhostRider32 is offline Find More Posts by GhostRider32
Old Jan 11, 2008, 10:20 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
Not hard to do at all. You do need the feeler gauges, some small wrenches and a little understanding of the system. The valve clearances are the same for OS, YS, Saito, Magnum and Thunder Tiger four stroke engines. They are all poppet valve engines.
Do this job at room temperature. The engine needs to be cold or room temperature.
Remove the valve cover.
Slip the feeler gauge between the valve stem and the rocker arm.
Make sure the engine is at top dead center (TDC) and on the "compression stroke." The compression stroke occurs when the rocker arms are not moving and the engine is on TDC. TDC occurs twice, the second time is when the rocker arms are moving about.
The clearance is between .04mm (or .002 inches) and .10mm (.004 inches), the .10mm feeler gauge should be tight in the gap between the top of the valve stem and the rocker arm.
Loosen the locking nut and set the clearance and tighten the locking nut again.
Oil up everything when you are finished. I use afterrun oil, 3 in 1 or similar oils. Does not matter, the oil will eventually be expelled from the engine.
You should also download an "Operating Insturction" sheet from one of the manufacturers. The one I am looking at at the moment is from Magnum, it is a little better than the OS one, it has a picture to help you understand what you are looking at.
Good luck, take your time, you can do it. There is "no kit" but you can get feeler gauges at any auto parts store. I got a package of little wrenches from Sears, all different sizes.
Cheers,
Chip
Chip01 is offline Find More Posts by Chip01
Old Jan 11, 2008, 11:28 AM
VillagePerson is offline
Find More Posts by VillagePerson
Tao Jones industrial ave.
Wisconsin, USA
Joined Apr 2005
O.S. Engines does have a "4 Stroke Cycle Engine Valve Adjusting Tool Kit" for sale. It contains two feeler gauges, a small box end wrench and a hex wrench. I think it cost 10 or 15 dollars. Tower Hobbies has them if you are interested.
VillagePerson is offline Find More Posts by VillagePerson
Old Jan 11, 2008, 07:11 PM
Joined Dec 2006
Thx guys.
Old Jan 13, 2008, 07:46 AM
Timco is offline
Find More Posts by Timco
Timco's Avatar
Calif
Joined Oct 2005
Here's a photo GhostRider32:
Timco is offline Find More Posts by Timco
Old Jan 13, 2008, 07:07 PM
Joined Dec 2006
Thanks everyone.
Old Apr 26, 2015, 06:19 PM
UNCLE GENE is offline
Find More Posts by UNCLE GENE
UNCLE GENE's Avatar
United States, GA, Warner Robins
Joined Nov 2012
Originally Posted by chip01 View Post
not hard to do at all. You do need the feeler gauges, some small wrenches and a little understanding of the system. The valve clearances are the same for os, ys, saito, magnum and thunder tiger four stroke engines. They are all poppet valve engines.
Make sure the engine is at top dead center (tdc) and on the "compression stroke." the compression stroke occurs when the rocker arms are not moving and the engine is on tdc. Tdc occurs twice, the second time is when the rocker arms are moving about.
You should also download an "operating insturction" sheet from one of the manufacturers. The one i am looking at at the moment is from magnum, it is a little better than the os one, it has a picture to help you understand what you are looking at.
Good luck, take your time, you can do it. There is "no kit" but you can get feeler gauges at any auto parts store. I got a package of little wrenches from sears, all different sizes.
Cheers,
chip
good job chip...you got it right !!!
UNCLE GENE is offline Find More Posts by UNCLE GENE
OS 91 4 stroke stripped muff threads fmidgett Fuel Plane Talk 13 Apr 27, 2015 05:20 PM
Help! OS 91 4 Stroke/ Tank Placement??? wrpsr1911 Fuel Plane Talk 3 Apr 26, 2015 06:28 PM
OS 91 4 stroke with electronic egnition jmf2001 Engines 4 Jun 06, 2004 06:50 PM
