Old Jan 11, 2008, 01:03 AM
stevefortner is offline
Find More Posts by stevefortner
Joined Dec 2007
t-maxx brushless conversion
Is an Align 430L brushless motor (300 watt and 3550 kv) too small to put in a t-maxx .15? I just bought one but it's a very small motor in comparison with the traxxas 3500 kv brushless conversion. It's technically a heli 450 size motor, but I thought with the integrated cooling fan it'd be perfect for a truck. Also, any hints on mounting it? Looks like I might have to make or come up with a custom motor mount.
Also, in converting this to brushless, do I need to convert the tranny to single speed? This motor and esc support 14.4/14.8 volts, and that's what I thought I'd try running. The mo the better.
stevefortner is offline Find More Posts by stevefortner
Old Jan 11, 2008, 12:14 PM
ghostofpf1 is offline
Find More Posts by ghostofpf1
Joined Mar 2007
generally people seem to use 540 long or Xtra long type motors for brushless 1/8 MT conversions.
My LST for instance uses a 540 XL 7 turn motor and my Cen Matrix uses a 540XL 8 turn.You need a largish motor for torque and heat dissipation as you'll be pulling some high amps at times.
HTH
ghostofpf1 is offline Find More Posts by ghostofpf1
Old Jan 11, 2008, 12:54 PM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
the align wont deal with the amps you need to run an emaxx you need to get the following to be ballistic
same setup as my e savage is as follows
feigao 8L
Mamba max esc
12 ib 3800 cells
ubec
fan for esc
heatsink fan for motor
insanity http://s158.photobucket.com/albums/t...=esavyrawr.flv
turbored21 is offline Find More Posts by turbored21
Old Jan 11, 2008, 03:32 PM
Joined Dec 2007
pretty cool
Cool stuff there ghost. I guess if that thing catches on fire you've always got the fire dept right there. I think you guys are right about the motor. Seems it needs to be rated at around 750 watts - or 60A instead of 30A - more than twice what I've got now. Maybe that motor would work on my old 1/10 scale 2wd Traxxas Hawk 2. It's pretty small with 2.2 tires. I bet with 14.4 volts it'd smoke.
It looks like no one is converting T-maxx trucks? I found out the tranny has a centrifigal slipper per the rc-monster guys. They are recommending the E-maxx tranny on the t-maxx and use your esc for reverse. I guess that tranny doesn't have a centrifigal system, maybe it's just more direct? And the T-maxx tranny if it's disengaged, you can't use your engine braking. And you don't have a servo for the disk brake unless you Y connect the wire going to your esc. Looks like you also have the problem of where to put the batteries. And then there's the motor mount problem too. But I know there's guys that would like to go brushless with their t-maxx trucks though. It's funny too that Castle posts on their site that the Mamba Max motors are not for monster trucks. I wonder why not? Maybe the way the trucks are set up, the torque from that motor would ruin it. With the E-maxx tranny I bet it would be fine, especially if you got the new E-maxx tranny with the steel gears. What do you guys think?
I think it's interesting though that Traxxas hasn't put the Velineon brushless on a 4wd monster truck yet though. The E-maxx still uses the dual Titan motor system, but they advertise it's brushless ready. If that's the case, put a friggin' brushless motor on it!
Old Jan 11, 2008, 04:39 PM
Joined Oct 2006
you cant use a mamba max MOTOR in a monster truck or 8th scale
you can however use the mamba max without issue as far as the duel velineon system.. its a joke.. dual brushless isnt necessary and is just plain dumb.. one motor will always and i dont care what kind of trigger their using fight with the other.. its the law of the machine so the one motor is pinning faster than the other one is gonna screw up.. burn up.. then its time for an upgrade.. yet again when a single big bore would draw much less amps and be much more reliable
Old Jan 11, 2008, 05:16 PM
Joined Dec 2007
why?
Why can't you use a Mamba max on a monster truck or 1/8 scale? I know their site says you can't, but come on, it's got the power to pull that truck.
I agree on dual brushless - pointless considering the torque brushless motors make.
Another idea on the stock T-maxx tranny is to use the forward only conversion. Part number 4994x. It looks like it has a single gear that's locked to the shaft, so you could use your esc reverse and motor braking. Maybe you should use the forward only and the single speed conversions. Or is there something else in the T-maxx tranny that makes it too weak to use with a high power brushless setup. Yeah, the plastic gears are weak, but is there anything else for us guys on a budget?
Old Jan 14, 2008, 11:01 AM
Joined Dec 2007
answer to why
Castle Creations responded to my email and Joe Ford there said that a Mamba Max will pull too many amps in a monster truck. So... they are working on a new Monster Max motor they say will be out in early to mid February. It's a larger motor and higher rated esc, and they've already had an E-Maxx up to 65 mph! You can email them and get on the notification list when it's ready. Sounds like good stuff.
That all said, you could probably gear down with a Mamba Max and make it work, but then it's going to have a slow top end. Maybe there's some guys using it now for Revos, E-Maxxes or T-Maxxes, but they may be running fans too or not maxing it out.
Old Jan 14, 2008, 11:49 AM
Joined Oct 2006
yes the simple answer istn that itll pull too many amps its the fact that the rotor is too short and it doesnt produce enough torque to pull the big guys around you need an L or XL size motor with a bigger rotor than the mamba max offers
no you couldnt gear it down to make it work it simply wont it doesnt have the power.. its a 600W constant motor less than 1hp a monster truck needs at least 1000 watts constant preferably 1300-1500W constant and the ability to spike up to 2000W
However i have ran the mamba max system in an 8th scale 2wd trophy truck
the big guy from back in the day called the ThunderKing BUT its light the whole truck only weighs like 6lbs and its geared well simple single plate chassis light components and strong gearing setup thats about the only time ive seen or tried a mamba max in something of that size my meters showed a constant of 480W "motor wasnt hardly working" and spikes of 78A so being it was light and geared it worked
now heres the neat information if the truck had weighed one lb more.. it would have drawn over 90A constant and spiked 130A on launch which would have smoked the mamba motor without issue
Old Jan 15, 2008, 12:19 AM
mtfly2000 is offline
Find More Posts by mtfly2000
mtfly2000's Avatar
washington
Joined Dec 2006
you will still void the mamba max warrenty if you put it in a M/T or other 1/8th. That's good news about the Monster Max, it seems like it's been in production longer than normal. The boys at Castle all say the same thing, "it pulls too many amps". It's easier than going into the various quantum details that take up their time.
mtfly2000 is offline Find More Posts by mtfly2000
Old Jan 19, 2008, 05:50 AM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
This is the same MMM that was supposed to released summer '06.
I've watched as this current release date has slipped from early Jan to now mid - Feb.....and counting.
Duster_360 is offline Find More Posts by Duster_360
Old Jan 19, 2008, 11:16 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
We have been selling motors for use in the 1/8 scale with very good results. Check out the pictures that some of our customers have sent us of their conversions. http://www.neumotors.com/20061222/Ca...Trucks%21.html
Steve Neu
sneu is offline Find More Posts by sneu
Old Jan 20, 2008, 06:20 PM
highflier is offline
Find More Posts by highflier
Speed cost money.
highflier's Avatar
United States, FL, Marathon
Joined Dec 2002
If you run to small of a motor it will get hot. While the Mamba maxx controler can be used it is limited to 4S Maybe 5S if you like to gamble.
4S can get the truck faster then stock. But if you want to really Rock. You want to get to atleast 5s. With a XL sized motor.
The long waited MMM controler or one of several released controllers will get you to 6s for a price, but once you make the plung..... You will have all the power you need... next your have to start fixing the components that can not handle that kind of power. Slipper, Drive shafts, Diffs etc... Once you get that kind of power these trucks are a lot of fun Plus you will have a setup that can even grow into a slighty larger vehicle if you need to some day.
Highflier.
PS. If money is not a concern... The Nue motors are supposed to be great. I just have had that kinda $$$ allocated for my bash monster truck
highflier is offline Find More Posts by highflier
Old Jan 21, 2008, 03:51 PM
Joined Mar 2007
4s seems to be the sweet spot in reasonable power.My LST runs over nitro revos like they were speed bumps on 4s and is just stupid on 5s...can't even imagine 6s
check out rcmonster.com if you get a chance...good site full of people running brushless t-maxx , revos and what ever else you can think of
I have pics of my cen matrix and LST conversions here http://www.putfile.com/troutgeek/images/80778
For Sale T-Maxx 21 Conversion Kit, XTM .247 Nitro Motor and Other Upgrade Parts bc-slowflyer Cars - Cars and Parts (FS/W) 5 Mar 11, 2006 09:47 AM
Brushless Conversion of a Nitro T-Maxx varmato Electric Power Cars 4 Nov 29, 2005 12:36 PM
WTT / T-Maxx for Brushless motors or ??? Steve H. Aircraft - Electric - Airplanes (FS/W) 0 Jun 30, 2002 11:28 AM
