Old Jan 23, 2008, 10:44 AM
metroidrc is offline
Find More Posts by metroidrc
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
here are the specs using that motor:
3.5g edf with motor
1.2g rx
2g esc YGE4
2g servos
9g airframe
6g battery
2g misc
25.7g
27g of thrust?
metroidrc is offline Find More Posts by metroidrc
Old Jan 23, 2008, 10:56 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Are you really going to spend $206 just because the motor is 6mm and 2,5g?
indoor_fr is offline Find More Posts by indoor_fr
Old Jan 23, 2008, 10:57 AM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Are there any specs about this motor? 2.5g sounds a little much for 6mm. Must be pretty long then. Also, those rpm, are they no load rating or what? If I payed 200$ for a motor, I would want to know exactly what I can expect with a given fan. Also, it might be worth consideriong a single phase motor. They are really efficient and can be build exactly to your needs. And building them might be faster than earning 200$. Martin just delivered the proof, that these motors open up new possibilities. I have a controller design if you are interested.
Chris
Chris T is offline Find More Posts by Chris T
Old Jan 23, 2008, 11:04 AM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
here is the page with all of the specs in pdf form.
http://www.micromo.com/servlet/com.i...5/i404667.html
However, I do not think its worth it to buy the motor, when something close enough can be achieved with a mighty midget or a pager motor on two cells.
Old Jan 23, 2008, 02:05 PM
supertiga is offline
Find More Posts by supertiga
other sites and forums
Joined Jul 2005
Put something in it and fly!
the suspense is killing me!
its gona fly
gona fly
gona fly
LOOKIN GOOD!
supertiga is offline Find More Posts by supertiga
Old Jan 23, 2008, 02:42 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
Thanks! well normally I would just put something in it and try to fly but this time I'm taking my time to make sure that all is right, looks good and works well. Today I cut out the ailerons, put in the aileron servo and did a test fit of the wings. I need to wait for my batteries to come in so I can build a little 2 cell. Right now I'm hoping to maiden it next thursday. I also tried making a lightweight canopy today, but no luck. I'll try again tomorrow.
-Josh
Old Jan 23, 2008, 03:23 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Originally Posted by kelberts
I wonder what has the maximum thrust/weight larger or smaller - Lessee, the EDF 30 above weighs about 6 grams and makes 40 grams - like about a 7/1 ratio -
I believe my 102" combo might have that beat --- I'll confirm
Turns out the little guy wins!! The 102mm fan and 1500 watt motor make 6 lbs of thrust and weigh 1.5 lbs = 4:1 - OK, I'll stop hijacking the thread!
kelberts is offline Find More Posts by kelberts
Old Jan 23, 2008, 03:43 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
tom should i bring the F100 tomorrow just to look at? it won't really be finished till next thursday probably...
Old Jan 25, 2008, 10:50 AM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
my two little cells arrived. 110mah. I just rigged up a 2 cell that weighs 6 grams. Gonna try it out in the motor thats already been run on 2 cells already.
Old Jan 25, 2008, 12:40 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
2 cell is made, wings are painted, canopy is finished. what's next? apply decals to wings, make stab, elevator servo... auw at this time is 23 grams.
Old Jan 27, 2008, 10:20 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
I'll be using my new Jet Saver for this - an idea that I thought of the other night. Because these little jets ALWAYS crash on the nose the first time out, I'll put a cf rod sticking out of the nose about 4 inches. That way it will stick into the ground and then fall over, not harming the plane.
Old Jan 27, 2008, 10:41 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
I found that making the whole nose out of EPP takes a lot of the sting out of flights
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jan 27, 2008, 11:02 PM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
most of the innards are made out of 1mm depron but the shell is made of molded tissue. so if it hits the nose, its gonna crush in. so I'll try the cf rod sticking out like a refueling hook. if I built the fuse out of foam I'd do it your way mike.. now its like a lawn dart maybe I should make a target
Old Jan 28, 2008, 08:16 AM
kelberts is offline
Effumall
kelberts's Avatar
Joined Nov 2005
Let's look!!!!!!
Old Jan 28, 2008, 09:38 AM
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
I'm still waiting for those Namiki motors.. but its getting down to the wire so I'll have to just finish up early this week. The way it is now there is barily enough thrust to stay in the air. Only about 8 grams on one cell and 14 grams on 2 cells. Auw is 22 grams with a 2 cell and 19 with one cell. The namiki motor should be able to handle two cell better.
I'll do some crash tests to see if that carbon fiber rod will actually soften the impact.
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Jet Design Contest: Micro Sport Jet FredN Electric Ducted Fan Jet Talk 60 Apr 21, 2005 08:14 AM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
