Old May 30, 2001, 08:00 PM
Mesa, Az, USA
Joined Mar 2001
Multiplex Cargo SOON!
I called Multiplex today and asked for a release date. They said End of June.
Keep your fingers crossed
Slice is offline Find More Posts by Slice
Old May 30, 2001, 09:48 PM
Philipp's Avatar
Grand Prairie, Texas, USA
Joined Mar 2000
Awesome looking plane. (For a foamie) This looks like an ideal camera plane.
I wonder when the "B-36" will be out?
Philipp is offline Find More Posts by Philipp
Old May 31, 2001, 07:45 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Interesting for sure.
How do you think the 4 x S400 will be wired and what will work for the battery packs.
jrb is online now Find More Posts by jrb
Old May 31, 2001, 09:42 AM
Texas
Joined Aug 1999
Four in parallel would be a bit much. Perhaps they wire two pairs in a series and each pair in parallel.
dave_lilley is offline Find More Posts by dave_lilley
Old May 31, 2001, 10:08 AM
Canada, ON, Ottawa
Joined Mar 2000
Cargo uses 6V speed 400s. Only calls for 7 cells. Going to have to wire them all in parallel so that each motor will see 7 volts.
JeffD is offline Find More Posts by JeffD
Old May 31, 2001, 10:21 AM
England
Joined Mar 2001
What sort of size speed controller is the Cargo going to require?
rob barham is offline Find More Posts by rob barham
Old May 31, 2001, 10:25 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
That's why I asked the question; can't imagine 4 in parallel. 50 to 60 amps, not nice.
2x2 on 12 cells I could see; maybe OK performance w/6 volt S400 & Gunther props. 30 amp ESC wouls still be needed.
Old May 31, 2001, 11:04 AM
Mark Haigh's Avatar
Barnsley, Great Britain (UK)
Joined Dec 2000
I am currently half way through the assembly of a Cargo. Its amazing really how sophisticated foamies have become. The wings plug into a grp joiner and the centre section (bomb bay) is a liteply cradle.
The batteries are designed to go into the nose section (like the twin star) so a bit of modification may be needed to accomodate 14 cells and retain the CG.
Multiplex advise if ROG is required geared 400 would be better (the model is supplied with 6v 400s and Gunthers) but the max prop size is around 7" diameter due to the nacelles being on 7.5" apart. I am planning to fit 4 x 450 Turbos with 7x4 props on direct drive. This should pull around 55A on 8 cells, with 50 oz of static pull. So it looks like a quick take off and some half throttle cruising is the order of the day.
The bomb bay is quite large and my plan is to build a RC parchutist of about 8" tall (Robbe used to make one, but it was about 18" tall).
Mark Haigh is offline Find More Posts by Mark Haigh
Old May 31, 2001, 11:24 AM
Texas
Joined Aug 1999
Old May 31, 2001, 02:15 PM
Texas
Joined Aug 1999
http://www.multiplexrc.com/cargo.htm
Specifications:
Wingspan: 63 inches
Length: 40 inches
Weight approx.: 70 oz
Wing Loading: 11.47 oz/sq.ft.
Controls: A/E/R/M, Doors
Power: 4 Speed 400 motors
http://www.multiplexrc.com/twinstar.htm
Specifications:
Wingspan: 56 inches
Length: 39 inches
Weight approx.: 49 oz
Controls: A/E/R/M
Power: 2 Speed 400 motors
Old May 31, 2001, 02:28 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Just thinking:
slide the tail/fin back so LE = stab LE.
flatten/decrease the radius at the top of the tail.
carve a little on the fuselage top.
re-shape the nose a bit.
add a shaped extension to the fuselage tail aft of stab & fin.
add top, chin, and ball turrets.
Results -- Stand-off/look a sorta like a B-17G!!
Maybe since its late, they've changed the molds so we won’t have to do as much carving. Or probably not since, its likely to have been designed in Germany.
Old May 31, 2001, 03:39 PM
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
jrb,
Ahem...
http://www.ezonemag.com/disc/Forum12/HTML/001317.html
tim
tim hooper is offline Find More Posts by tim hooper
Old May 31, 2001, 03:48 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
OK, so we all have a good eye.
Never saw that posting before.
Who's going to do it 1st?
Why is it delayed to our side of the pond?
Old May 31, 2001, 05:12 PM
All under control, Grommit!
leccyflyer's Avatar
NW England
Joined Sep 2000
Dunno about that but be thankful for the chance for some of the wrinkels to be Beta tested out before they arrive over there.
Our LHS received four last week- two had their backs broken in transit- supposedly some problem with the packaging- not unknown in other foamie kits and something that might just come out with the first ones shipped in anger.
That plus the comments on the need for throttle-elevator mixing mentioned in an earlier Cargo thread is enough to make me hang fire until any potential teething troubles are sorted out by the time the second or third run of kits come out.
We do have the parachutists though!! They work just great.
cheers
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jun 01, 2001, 12:31 AM
Austin, Texas USA
Joined Mar 2001
Dognabit!
What's the deal? Does Multiplex have something against rudders?
Proportionally, it looks even smaller than on the Twinstar.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
What speed controller for multiplex Cargo? Michael Heer Foamies (Kits) 8 Jun 01, 2001 01:29 PM
Multiplex Cargo Bill Glover Foamies (Kits) 7 May 18, 2001 06:19 AM
Multiplex cargo sandman Scale Electric Planes 20 May 16, 2001 03:02 PM
Multiplex Cargo in Europe Michael Heer Foamies (Kits) 0 May 05, 2001 12:22 AM
