This thread is privately moderated by raz, who may elect to delete unwanted replies.
Old Jan 10, 2008, 12:01 AM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Adding ailerons to a Super Cub
I'm not too good at "write ups" but here's how I made my ailerons. First I marked the ailerons out loosely basing it off my Cessna wing so the aileron measures 12" long X 1 1/4" wide. Then I carefully cut them out using a razor knife, it worked best in a sawing motion. Then I cut the under side of the wing and aileron at an angle so they could move up and down without binding. Next was I sanded all the cut areas with 220 grit paper to help smooth them out and also the areas that will be taped. I used a single strip of 'hinge tape' then to hold each aileron in place on the top of the wing then installed the control horns 1" in from the edge using foam safe CA to hold them in. When mounting the servos you want as straight of a shot to the control horn as possible. I marked out the servo locations in the thickest part of the wing then carved them out with the razor knife plus a valley for the wires to be inlaid in the wing. I used hot glue to hold each servo in place and clear packing tape to cover the wires so the wing would still be smooth plus no loose wires hanging down. The last step was to Z bend a small piece of piano wire on one end (aileron side) and the other end went into a Du-Bro mini EZ connector on the servo horn. Then plug in the harness to the rx and power up the tx with the aileron trim at neutral make sure the ailerons are even with the wing and tighten the set screw. Like I said I'm not good at write ups so I may have forgotten some things but I'm sure you get the idea. Now when my Pixie comes in I need to replace the planes servos, esc & rx but thats the easy part.
If your wing is painted (like mine was) make sure to remove all the paint before applying the tape or glue or it won't stick. After taping I repainted the wing.
raz is offline Find More Posts by raz
Discussion How do you convert a Super Cub to ailerons? Spackles94 Beginner Training Area (Aircraft-Electric) 4 Feb 26, 2007 05:36 PM
Adding Ailerons to Multiplex Pico-Cub Rexx Foamies (Kits) 2 Sep 03, 2003 05:51 PM
HL Super Cub wing folded in flight! Paul Electric Plane Talk 27 Jul 06, 2002 03:38 PM
Hobby Lobby Super Cub - struts esox Electric Plane Talk 8 Jul 30, 2001 08:41 AM
Adding ailerons to polyhedral, please help. atsiang Electric Plane Talk 2 Jul 07, 2001 07:47 AM
