Old Jan 09, 2008, 06:31 PM
scharlach is offline
Find More Posts by scharlach
Joined Jan 2005
1.2 gm servo improvements
The 1.2gm servo has been updated to use the original gears from
4.3/4.7 gm servos without purchasing a 2nd set of gears. The output
gears are made by modifying G5 and G6 from orig. servos.
I will have a number of the updated units completed for sale in 2
weeks.
See attached photos of completed servo and individual parts. The servo
weight includes 2" wire leads and connector pins. The servo operates on
3 to 5.5V and has >1 oz. thrust. The servo is made from the following
parts: 4 x 8 mm, 10 ohm pager motor; 3mm, 10k ohm feedback pot;
five 1/64" laser cut ply parts, 2 CF & 1 Alum gear shafts, 6 gears from 4.3 gm
servos, servo amplifier from United Hobbies 4.3 gm servo, # 36 AWG
stranded wire. If you are interested in some of these servos
let me know. I sell completed/tested servos and complete kits for
DIY. Note: The DIY kits should only be attemtted by those who have
mechanical and soldering skills, to work with very small parts!
I have tested these servos in 1/2 oz to 3 oz airplanes with great results.
The 1/2 oz airplane operates on a single 90mah Lipo cell.
scharlach is offline Find More Posts by scharlach
Old Jan 09, 2008, 06:53 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Is it correct to assume that the gears and circuit board are from the same servo?
village_idiot is offline Find More Posts by village_idiot
Old Jan 09, 2008, 07:23 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
Very impressive!!!
NumbSkull is offline Find More Posts by NumbSkull
Old Jan 09, 2008, 07:59 PM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
I love it...it's what I love about this board
aerogel is offline Find More Posts by aerogel
Old Jan 09, 2008, 08:10 PM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I think hes done a fine job one suggestion i would like to make is ,if you take the allum cover off a floppy disc a u shaped chanel could be formed into wich the servo could be built ,this not only would be light but dimensionally stable to keep gear mesh tolerences lash free.
olmod is online now Find More Posts by olmod
Old Jan 09, 2008, 09:13 PM
Joined Jan 2005
servo gears
Yes, you can use pinion gear, and gear 2,3,4,5 from 4.3gm servo but
you need to order a second gear 3 as this size gear is used twice in
this design. BP Products carry gear sets for Arrow 4.3gm servos.
Old Jan 09, 2008, 09:21 PM
may-day is offline
Find More Posts by may-day
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
will you sell any pre built servos?
may-day is offline Find More Posts by may-day
Old Jan 09, 2008, 09:27 PM
Inciting Riots
Joined Dec 2006
OK, thanks. I wonder if we could source that extra gear from someplace like http://www.smallparts.com so that the waste could be kept down. I guess the extra gears would be useful for repairs.
Old Jan 09, 2008, 09:40 PM
Dongo is offline
Find More Posts by Dongo
Dongo's Avatar
Here, There, Somewhere
Joined Jul 2004
Hey,
What servo board are you using the Blue Arrow 4.3g or the EM 4.3g? What about the pot, source or datasheet?
Daniel.
Dongo is offline Find More Posts by Dongo
Old Jan 09, 2008, 10:00 PM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
How about using less gears? less weight and complexity.
Here´s a picture of my attempt at modding an 7.5g servo; end weight is 2.5 but doesn´t work, way too jittery. I think it should be OK with a second gear reduction.
AleG is offline Find More Posts by AleG
Old Jan 10, 2008, 04:16 AM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
diy servo
This is the servo that i make:
http://it.youtube.com/watch?v=vvHrTpgxhZo
little 2g servo (0 min 22 sec)
Ivan2280 is offline Find More Posts by Ivan2280
Old Jan 10, 2008, 05:41 AM
U.S.U.L is offline
Find More Posts by U.S.U.L
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Scharlach, thanks for posting.
I already bought two nokia 3210 vibra motors(4x8mm), will they be strong enough?
I also wonder about choosing the right SMD pot, they make much resist while being turned and this reduces speed and torque a lot. Did You try to mod them anyhow?
U.S.U.L is offline Find More Posts by U.S.U.L
Old Jan 10, 2008, 06:00 AM
Ivan2280 is offline
ITALY
Joined Sep 2004
info
For my experience in work with diy servo you have to use 4x8mm motor 24 ohm or 4mm motor 13ohm.Please verify the ohm between the + and - of your motor.Ivan
Old Jan 10, 2008, 06:24 AM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Hi scharlach,
Thanks for posting you servo, it looks very nice! I was working on doing a similar servo but with a worm drive. My problem was the shaft connection to the pot, can you show how you did yours?
Edit: On closer examination of your parts picture I see how you did it.
mcross is offline Find More Posts by mcross
Old Jan 10, 2008, 06:42 AM
methuso is online now
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
For trimpot, would a Vishay TS3Y do ?
http://www.vishay.com/docs/51041/ts3y.pdf
(Im Electically challenged)
/Ulf
methuso is online now Find More Posts by methuso
Discussion 1.2 gm servo scharlach Scratchbuilt Indoor and Micro Models 33 Jan 10, 2008 01:22 AM
Discussion Need Info on S125 1/2 Turn Sail Winch Servo suresh13 GWS (Grand Wing Servo) 2 Mar 06, 2007 09:54 PM
For Sale 2 HS-81 servos and 1 D-60 servo RandyK1 Aircraft - General - Radio Equipment (FS/W) 3 Jun 17, 2006 06:56 PM
1/2 turn sail winch servo in a Victoria? robster94gt Sailboats 5 Nov 18, 2004 10:51 PM
New JR max radio set w/ni-cad (TX, RX, 2-507 servo, 1 L501 servo and 1 used odd ball) braxx Aircraft - Electric - Airplanes (FS/W) 1 Jan 21, 2004 10:19 PM
